Question about Garden
Lumatek 600 have old sockets and they work for everything but myballast. The ballast works for the most part but will go out from time to time on its own. It is a hydrofarm 600w bllast lumatek 600
  • 1 more comment
  • Mark Willison
    Mark Willison May 11, 2010
    is it the ballasts you are asking about or the sockets? i'm not really clear on the sockets part...
    the ballast just shuts off on it's own? how old is it?
  • Mark Willison
  • Mark Willison
    how many sockets do you have that won't work for you?
    when you say they work for everything but your ballast, what do you mean? have you tried to test them with a meter?
    if you wire up the socket directly to a 120V 3-Prong plug, you can test whether or not the socket is conducting electricity by touching one prong of your meter to the bottom contact inside the socket and the other prong of your meter to the inner shell of the socket. if you get voltage, the socket should be good to go.
    Problem Solver:
  • 10 Answers
Off hand it sounds like a loose connection. Do you know if you have aluminum wiring? This can be dangerous heating and contracting causing a spark when it comes loose.
It could be that the ballast doesn't have enough air flow around it. Gets hot and shuts down.
Do you have another ballast you can swap it out see if same thing happens?
Posted on Jul 27, 2009
Where is ballast resister on 1984 dodge 600
Hi Teri, I'm glad to help! Wow Teri, this has been a long time working on one of these. The ballast was usually mounted under the hood on the firewall somewhere, don't remember the exact location its been to long. Hope this helps and have an awesome day Teri.
Apr 19, 2014 | 1984 Dodge 600
How to release the wires from all the tomb stone connectors on a 4 bulb T5 fixture in order to change the ballast?
If you are sure the ballast is gone, just cut the wire as close as possible to the ballast, throw the old ballast and buy a same wiring ballast, use wiring nuts to connect the wire from the new ballast to the wire from the tomb stone socket. DO NOT TRY TO take the wire out from tomb stone lampholder.
Below link is for your reference.
http://www.bulbspro.com/electrical/sockets/fluorescent-sockets.html
http://www.bulbspro.com/ballasts/ballasts/fluorescent-ballasts.html
Aug 28, 2013 | Computers & Internet
We have 48" lithonia flouresent
even if there is power at the sockets, ballast may not have power to fire off the lamps, how old is this fixture, and you need to replace the ballast same as in fixture, if you replace ballast make diagram of wiring so you can rewire it like it was wired from store.
Aug 21, 2011 | Lithonia Lighting White Finish 2 12" High...
Fluorescent lights will not come on. There is power to the ballest.
Power to the ballast is good. The power you checked is known as the primary power. The secondary power from the ballast (transformer), should be around 600 volts. This 600 volts is what vaporizes the gas in the fluorescent lamp. Go to home depot and buy a magnetic field tester (we call it a thumper) It has a shirt pocket clip on it. Do not insert the thumper in the fixture lamp sockets, just put it in front of one of the light fixture sockets. It should beep and the light on the magnetic field tester (thumper) should come on if you have a magnetic field in the light fixture socket. This means that the light fixture ballast secondary is working. No beep and no light from the magnetic field tester (thumper) means your ballast is bad. Ballast are dangerous to replace. Have an electrician replace it. Your life is not worth losing over saving a few dollars.
Jan 06, 2011 | Lithonia Lighting White Finish 48" Wide...
Put new bulb in hitachi ultravision dlp tv and lamp light flashes and tv will not turn on. Have reinstalled old build and works fine. Is there any type of reset that needs to be set. New bulb no tv, old...
hey there it sounds like the problem is coming from your ballast board, the ballast board is the power source to the lamp. with time this part starts to wear out and get weak your old lamp is already burning out there for it does not need that much voltage to turn on but the new lamp has not been worn out or used there for it needs the ballast to be working at 100%
hope this solution helps
Sep 03, 2010 | Hitachi UltraVision CineForm 55VG825 55"...
One of my two hps bulbs is brighter than the other one the bulbs and one of the ballast are new the other ballast is a year old
Hi .. it could be the ballast .. an easy thing to do to troubleshoot this would be to swap the lamps. If the problem follows the lamp. then that is the problem. If the pronblem stays with the fixture, then I would replace the ballast in that fixture.
May 03, 2010 | Sun System 600 Hps Cool Grow Light System...
I have a Hunter model 21241 ceiling fan with circline fluorescent light. The light module is a VEB82122 (ballast "A"). This is part of switch housing assembly part number 93563-09-000. I get a dim...
The ballast is still available on the internet, just Google "veb82122." They want $37 plus shipping. You can also but a 22W Circiline ballast at Home Depot that will work for about $18. (Lowes does not carry them). The original ballast is a solid state design, light weight and instant on. The Home Depot ballast is the heavy transformer kind and a real pain to modify the bracket to make it fit. I have 8 of these Hunter fans and I have installed the Home Depot ballast on two if them so far, but I think that I will order the solid state version as a spare for the next time.
Aug 13, 2009 | Hunter 20531 Vista Brushed Nickel Ceiling...
No Red in the picture
Could be faulty red socket along w/ ballast. You need tech to see this.
Dec 15, 2007 | Hitachi UltraVision CineForm 55VG825 55"...
ZENITH E44W48LCD Ballast
Could be a bad ballast or light light control circuit. I have also seen a burned or bad socket cause a problem with this set. Good Luck
Jun 18, 2007 | Zenith E44W48LCD 44" Rear Projection HDTV
Garden Logo
336 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
