Question about Husqvarna "Chain Saw - 16" Bar, 3 Hp
Jonsered 525 coil is week any one know where to get one?
Least season was the last time it ran , it ran strong then just quit.I then tested for spark and there was nothing.... Checked the ground and it was insulated.Now i cant seem to find a coil for it. Does anyone know where I may get one? Or maybe interchange w/ another saw?
    Problem Solver:
  • 7 Answers
Try Ebay, Randy's Engine repair has the most complete list of parts and cheap shipping. Or Google chain saw parts. Bailey's and Jack's can look those parts up for you
Posted on May 07, 2009
Multiple misfire smells gas
When you had the coils checked did you get the module checked as well? Is the car throttle body or multi port injection?
Feb 12, 2014 | Cars & Trucks
1997 Kia Sportage Misfire on Cylinder 3
run a compression test on all cylinders to rule out head gasket or burned valve.
Mar 03, 2017 | 1997 Kia Sportage
The injector is bad , internal coil when heated shorts out . Feel lucky it's only one injector . It could be like this corvette all injectors Quit when hot ! Test the injector with ohm meter . Chevy Corvette No Start When Hot The Diagnosis
Mar 03, 2017 | Cars & Trucks
An older model Jonsered (525 sn 460611)but in excellent shape except for ignition coil. A local eaelr order a coil but it was a substitute and would no fit. He refunded my money including...
it is very possible that the coil will fit both units as the voltage will be the same and the application is the same the
I went google and typed in -jonsered 500 coil-- and the first site is e-bay which has over 50 photos pf coils to suit jonsered engines and husqvarna /jonsered engines
by clicking on the photos most like your coil then scroll to the details section , they normally have a list of engines that that photo will fit
Apr 15, 2017 | Audio Players & Recorders
Honeywell generator HW2000i Bought it cheap and now I know why. Started it up and it ran for a few minutes then shut down like someone turned it off. Wouldn't restart. Waited an hour. Started right up....
I would test the coil by removing it from the circuit, and attaching a properly gapped spark plug to the secondary, then apply and un-apply 12 volts to the primary. If you get a good strong spark on the spark plug tip each time you apply or remove the 12V, then you know that the coil is OK. This doesn't give you a measurement, but you don't know what the voltage is supposed to be anyway.
You might also try measuring the resistance across the primary and across the secondary and compare these numbers to a known good coil (anything similar should be in the same ballpark). Make sure to do that with the coil removed from any other connections and short the terminals together to remove any residual charge before you try to measure the resistance.
I hope this helps, good luck Al K
Jan 27, 2011 | Honeywell Electrical Supplies
Won't start
did you check the air gap between coil and flywheel? did you change sparkplug
Sep 09, 2009 | Parks Optical 13.5hp Briggs And Stratton...
19.5 HP brggs engine (craftsman) shuts down after long runs.
Sounds like the coil,pull the shutoff wire off the coil and try it.if you still dont have spark replace coil.
Mar 17, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Husqvarna "Chain Saw - 16" Bar, 3 Hp Logo
698 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
