Question about Acer TravelMate 2500 Notebook
Does not load windows, beeps 1-4-1-1. Some times starts. Shots downs showing Fatal Error (Blue screen with white text message) Builtin Keyboard Not working, using USB. Touch pad disabled. Cant go to BIOS. BIOS passworded if go from windows using
  • jagdaish_kum Feb 27, 2009
    Sell it ... buy a new one okay.
    Scholar:
  • 150 Answers
1-4-1-1 Is a RAM error. You don't need to sell the laptop. Check your RAM slot (usually pretty easy to access from the bottom of the laptop). If all of the RAM chips are correctly inserted, there's a good chance that you have the wrong kind of RAM inserted. Check the owner's guide to determine what kind of RAM your laptop supports.
If the RAM chips are inserted snugly and you haven't modified the RAM chips in any way, call ACER support. They will have you send the laptop in and they will determine the problem. It could be a bad motherboard, but most likely it's just a bad RAM chip.
Please rate, Thanks!
Posted on Feb 27, 2009
The laptop stays on for few minutes and then it turns itself off but before it does that, it shows a large blue scree and some large white text, the text flicks a little but fast to the point where I can...
First of all Turn of your laptop.
Now this time when you turn on your laptop start tapping F8 Key on you keyboard when you Toshiba logo. Tap F8 key for at least 5-6 times.
You will get a Windows Advance Option Menu. You will see lot of options over their written in white text. Your mouse will not work on this screen. Use UP and DOWN arrow keys on you keyboard and highlight Last known good configuration. Once highlighted press enter on it. See if you computer boots. If it boots try doing a restore.
If it doesn't boot.
Turn off your computer and then turn on your computer. On Toshiba Logo screen tap F8 key once again and go to windows advanced option menu screen once again and this time hightlight Disable automatic restart on system failure. Now when you see Blue screen coming up on your computer once again your computer won't restart. Now you can write down the information to trace out the blue screen that is occurring on your computer. Write down the Error code which will be in form of STOP 0x000000XX, you find this error code somewhere at the bottom of the blue screen.
Once you get the reply here, we will see what we can do.
Jun 21, 2011 | Toshiba Tecra M2V-S310 Notebook
My dv6-1247 cl when i turn on the power it beep 8 times and the screen does not come on help
Yu will need to determine which BIOS you have a see below
The computer beeps several times
If you hear several beeps from the PC speaker, it means that the computer failed its power-on self test (POST) because a problem was detected. The POST is a procedure that tests several components such as power, BIOS, CPU, memory, and video. Only if all those tests pass, the computer will then allow the operating system to load. But if one or more of these tests fail, beeps indicate a problem and the boot process is halted. These errors are a little more difficult to troubleshoot.
To diagnose the problem, listen to the beeps carefully and write down the sequence. Is it one long beep? Is it several short beeps? How many? Once you have the beep sequence documented, you need to find out what it means. What BIOS do you have? When you first turn on the PC, look at the top of the first screen to find out. Common BIOS types are Award, Phoenix, and AMI.
Award:
1-2-2 Indicates a video error has occurred and the BIOS cannot initialize the video screen to display any additional information Any other beeps Most likely a RAM problemYou can find more detailed information about Award error messages on Award's web site.
Phoenix:
1-2-2 Indicates a video error has occurred and the BIOS cannot initialize the video screen to display any additional information 1-2-2-3 BIOS ROM Checksum 1-3-1-1 Test DRAM Refresh 1-3-1-3 Test Keyboard Controller 1-3-4-1 RAM Failure 1-3-4-3 RAM Failure 2-1-2-3 Check ROM Copyright Notice 2-2-3-1 Test for unexpected interrupts 1-3-4-3 RAM FailureYou can find more detailed information about Phoenix error messages on Phoenix's web site.
AMI:
1 beep Refresh failure 2 beeps Parity error 3 beeps Base 64K memory failure 4 beeps Timer not operational 5 beeps Processor error 6 beeps 8042 - gate A20 failure 7 beeps Processor exception interrupt error 8 beeps Display memory read/write failure 9 beeps ROM checksum error 10 beeps CMOS shutdown register read/write error 11 beeps Cache memory badYou can find more detailed information about AMI error messages on AMI's web site.
If you get beep errors, you should try to think what happened right before they started. Did you add a new piece of hardware? If so, it might be faulty or not installed right. Remove it, then try again. If everything is fine without the hardware, try to reinstall and configure the hardware again. If that does not help, try exchanging it and see if that corrects the problem. If the error persists, narrow it down systematically. Remove everything but the CPU, memory, keyboard, and video card, then boot again. Does the error still occur? If not, then add one piece of hardware and try again. Repeat until one new component causes the error and you now know who the culprit is. If yes, then reseat your CPU, memory and video card and try again. If the error still happens, try replacing the CPU, video card and memory one by one to see if one of them is the troublemaker. If that does not help, you could have a bad motherboard. Check the motherboard carefully for any signs of damage. Also check for shorts, a metallic object could have found its way onto the motherboard, or the motherboard is not installed correctly and touches the case somewhere.
Page 1: Computer boot problems
Page 2: This page
Page 3: System hanging after POST
Page 4: POST running OK but Windows not starting
Good luck
Please rate FIXYA
Thanks
Apr 02, 2011 | Computers & Internet
When I load my Toshiba Satellite L305D-S3958 It loads up saying it didn't shut down successfully. I tried all the modes from safe mode, safe mode with networking, safe mode with command prompt, and Star...
I hope that you have a goood back-up of file. Getting blue screen error is a fatal OS problem. You need to re-install windows.You need to get the CD that came with your computer or the operating system disc you used to install the windows. Insert the disc on the CD-DVD drive and restart your computer. Watch for a Press any key to boot from CD or DVD... message. Installation will start. Good Luck!
Mar 14, 2011 | Toshiba Satellite L305D-S5938 Laptop
Blue screen appears at start up boot screen and restarts again
press "F8" while statrting , and then select "safe mode"
Feb 01, 2011 | Computers & Internet
I have a problem on this cod c000021a fatal system error i have window when i shut down my computer show blue screen with this cod c000021a fatal system error and computer restarts i need help for solve...
Blue Screen system error. If you've been running windows Xp, please do the following:
1. Insert Windows XP CD in the Pc.
2. Restart the PC and while in Bios, go to Boot Priority and select Boot from CD as your first priority.
3. Save and exit.
4. The PC restarts and follow the instructions on the screen. (Press any key to boot from the CD).
5.After system has finished, such will happen <Enter-To Continue R-Repair ESC-Cancel>.
6. Choose R to repair.
7. A black screen pops up, just read and type 1 and wait for the next step (password).
8. Put in your Admin Password or press "Enter".
9. Then type CHKDSK and press "Enter".
10. the system will repair the errors within the HDD and windows and later restart the PC. Good luck
Jun 21, 2010 | Dell Inspiron 1501 Notebook
3 medium beeps on pc; repeating
Hi John. If you already swaped the Memory, it's the video card. I'm giving you what the beep means according to the different types of BIOS, because basically Ascent is a clone PC. I hope it helps.
(you will have to open the computer to see the BIOS type.)
BIOS AWARD
1 long beep and 2 shorts -- Video error
2 short beeps -- non-fatal error.
1 beep corto -- OK.
BIOS AMI
1 short beep -- Memory error.
2 short beeps -- ECC error.
3 short beeps -- Memory error.
4 short beeps -- change atery
5 beeps cortos -- bad processor.
6 beeps cortos -- bad keyboard.
7 beeps cortos -- video memory bad.
8 beeps cortos -- video bad.
BIOS PHOENIX
1-1-2 beeps -- Problem with cpu/motherboard.
1-1-3 beeps -- Cmos issue.
3-4-1 beeps -- Video issue.
BIOS IBM
1 short beep -- Post normal, ok!.
2 short beeps -- POST error, will show on screen.
NO beep -- CPU issue or Expansion card issue
1 long and 1 short -- motherboard error.
1 long and 2 shorts -- Video issue.
1 long and 3 shorts --EGA video issue.
3 longs -- Keyboard error.
Apr 29, 2010 | Systemax Ascent Pro A20 (988185) PC...
Tried to startup and computer shuts down citing ''Fatal Error''
just try to boot the system in safe mode and run thse chkdsk command.
Jan 15, 2010 | Computers & Internet
Erro sound/pip when ibm 8310 netvista starts, no error message are show on the screen, the screen are black.
how many times it beeps is an indication of the problem
1 short beep
Normal POST - system is ok 2 short beeps POST Error - error code shown on screen No beep Power supply or system board problem Continuous beep Power supply, system board, or keyboard problem Repeating short beeps Power supply or system board problem 1 long, 1 short beep System board problem 1 long, 2 short beeps Display adapter problem (MDA, CGA) 1 long, 3 short beeps Enhanced Graphics Adapter (EGA) 3 long beeps 3270 keyboard cardhope this helps.
Sep 14, 2009 | IBM (09N5424) Motherboard
Windows won't come out, with message fatal error.
If its appearing in blue screen..mostly it may be because of your memory. chek your hard disk also with any checking softwares like NDD, or seagate softwares
Apr 09, 2009 | Computers & Internet
Blue screen c000021a fatal system error
usually blue screen comes from unstable video memory or windows system or HD.
you may try
1) reinstall windows
2) change another HD to install windows
3) change new ram memory or change memories slot between one and another
if not fixed, to be sure your video memory damage which is insualted on board(separated with RAM), only the hardware repair can be fixed.
Jan 23, 2009 | HP Compaq nc6320 Notebook
Acer TravelMate 2500 Notebook Logo
143 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
