Question about Belkin (F5D5231-4) Router
How to set 5631 tcp and 5632 udp
My client has a belkin wireless g router and I'm trying to connect to
his pc via pcanywhere. The pcanywhere tech's told me to open
the router ports 5631 tcp and 5632 udp
I will be going to my client in 2 hours, I'm trying to find out how to
make the settings on the hard-wired pc in his office
thank you for any assistance
stu
    Scholar:
  • 93 Answers
You need to access the router via a web browser. Standard addresses are 192.168.0.1 or 192.168.1.1.
If neither work, you need to go to start>run> type in "cmd" then OK. Once you get command prompt up, type in ipconfig (Then enter). The Default gateway is the address to your routers configuration page.
Once you get in go to/find virtual servers and and the ports in there. for the ip set it to your computers local ip, you can find it in run>cmd >ipconfig thing i told you earlier. It would be under IP Address
Posted on Feb 28, 2009
How do I enable IPSEC Passthrough on this wireless router?
look in the settings of the Belkin to see if you can enable VPN Pass-through.
Try disabling some of the firewall functions on the belkin to isolate the issue and turn the rest back on.
If for some reason this model doesn't work even after the above, try changing the VPN client's connection settings,there are only two to choose from... (click modify on your connection entry, go to the Transport tab > then choose from:
IPSec over TCP and IPSec over UDP (port 10000)
Sep 30, 2013 | Belkin (F5D7230-4) Router (587009)
Port 88 UDP problem
1) You have to enter UDP and TCP on seperate lines with same port numbers in each line respectively. So you will have four lines, UDP 88, UDP 3074, TCP 88 and TCP 3074. Also, make sure you have your 360's IP entered. You can find that in the 360 network info.
2) Also, place your 360's IP in the DMZ. That should help.
3) For testing, turn off the routers Firewall. It will make it easier to figure out what is going on.
Nov 17, 2012 | Gateway Belkin F5D7230-4 802.11g Wireless...
Ive connected my xbox 360 through wired connection to my modem/router and it tells me my NAT settings are strict and to enable upnp but i dont know how to enable it?
PS3 and Xbox ( NON BELKIN)
You Will Have to Disable the Firewall In Your modem / Router
And IF it is a router then Open The Ports
• TCP 80
• UDP 88
• UDP 3074
• TCP 3074
• UDP 53
• TCP 53
And also make sure that UPnP is Enabled
Jul 30, 2010 | Zyxel Prestige 660HW Wireless Router...
I have Timewarner cable and can't set up a vpn so that a client can connect into my Lynksys vpn router. Is it possible that the firewall in the TW router is blocking a client or that maybe I need a static...
No you need not buy a static address... just forward these ports in linksys router...
50 both TCP and UDP 51 both TCP and UDP 500 both TCP and UDP 10000 both TCP and UDP 1723 both TCP and UDP 1701 both TCP and UDP
also disable firewall in linksys router....
May 10, 2010 | Linksys -Cisco Wireless-G VPN Broadband...
Unable to get VPN working - have set up port 1723 TCP/UDP without success
1. Check at this phone number for tech support.
+44 - 1933 35 20 00
2. make use port forwarding is configured properly for UDP/TCP
3. check the DMZ rules.
Apr 24, 2010 | Belkin N Wireless Modem-Router F5D8633au4A
Belkin N1 F5D8231-4 V3000
are you running the Cisco VPN client from home, where this Belkin is your gateway and connecting to say your work?
If so, have a look in the settings of the Belkin to see if you can enable VPN Pass-through.
Sep 07, 2009 | Belkin (F5D8231-4) Wireless Router...
Belkin + xbox live problems
It's not the MTU problem any more. Its the router's firewall. To resolve it, you two steps to try. First, try to do port forwarding, you must forward the port for XBOX Live to the router's admin page. I believe the ports are 3074 TCP and UDP, 53 TCP and UDP, 88 TCP and UDP. If that doesn't work, try to just disable the router's firewall itself. One of these steps will surely fix your problem
May 06, 2009 | Routers
Found the check box - for Block WAN
I believe your initial problem was for PCAnywhere rgiht? just make sure ports 5631 (Data Port or TCP) and 5632(Status port or UDP) is properly opened/forwarded on your router's config page plus make sure that you instruct the router to forward those ports to the computer that you have PCAnywhere plus I have read some articles that newer versions of PCAnywhere 10.+ 11.+ will not work with older version 5.+
Now if it still doesn't work try setting up DMZ for you host computer(Note: enabling DMZ will open a wide range of ports, well common ports that is).
Jul 02, 2008 | Linksys Wireless-G WRT54G Router
Setting up my progam
It usually depends on the program - for example, PCAnywhere uses port 5631 TCP, and 5632 UDP. Some programs don't have a default port, and can use one of the 'standard' ports, like port 80 which is used by HTTP (your web browser).
Feb 20, 2008 | Belkin (F5D7230-4) Router (587009)
CyberXLink CXL-EBR-W router - can't open ports 5631/5632 for pcAnywhere
Hi dave, I'm not familiar with that router at all and I didn't find any doc's online for it so I'm running blind here but... If the router has it make sure "Block WAN Request" is disabled or you won't get anywhere. Also I don't know if the print server has anything to do with your problem. Have you tried mapping those ports directly to the host in the router? TCP PCanywhere port 5631 Inbound 192.168.1.[host IP] port 5631 UDP PCanywhere port 5632 Inbound 192.168.1.[host IP] port 5632 I'm also assuming that you're using a static IP on the host. You don't want to use a dynamic IP. Hope this helps. Let me know how you make out, Duder
Nov 17, 2006 | cyberxlink (CXLEBRW) Wireless Router
Belkin (F5D5231-4) Router Logo
144 people viewed this question
Top Belkin Routers Experts
Prashant M
Prashant M
steve morris
steve morris
Are you a Belkin Router Expert? Answer questions, earn points and help others
