Question about Water Heaters
My Titan N180 water heater keeps tripping the breakers
My water heater was installed by an electrician, and it even confused him. When we turn the breakers on one of them immediately trips off. What could be causing this?
  • 398 Answers
Replace the breaker.
Posted on Feb 27, 2009
  • 1 more comment
  • josh1111 Feb 28, 2009
    not the answer im guessign , what size breaker and tank are these?
  • josh1111 Mar 07, 2009
    are the breakers amp even across?
  • josh1111 Mar 21, 2009
    improper wireing wire short
Electric shower just installed cuts out at fusebox after being on for about a minute
10-20-12
Circuit breaker is tripping on electric shower?
This could be absolute danger until more information is known.
1) Breakers trip because they sense heat, because the wire size is too small, or breaker size is mismatched with wire. Or breaker is loose on busbar.
Copy following links to determine correct wiring and breaker:
http://waterheatertimer.org/Color-codewire.html
http://waterheatertimer.org/How-to-wire-Tankless-electric-water-heater.html
GFCI circuit breaker will trip because of same heat condition described above, and also trip if ground fault is detected.
Water leaking into element will trip GFCI.
Absolutely you need to get this problem fixed before shower is put back into service.
Call electrician, or the installer, or the manufacturer, or all.
http://waterheatertimer.org/How-to-wire-GFCI.html#spa
Oct 18, 2012 | Rheem EcoSense by 7.4 GPM Tankless Water...
Thermostat sticking titan n180
The thermostat is there to protect the water heater. I don't think it can overheat and make the breaker trip. If you tried to reset the unit and it's still not working, you should send your Titan N180 back to the manufacturer to be repaired. The 10 year warranty if against leaks. You have 1 warranty in your Titan components.
Apr 01, 2012 | TitanNet TITANTANKLESS. COM PRESENTS THE...
Breaker trips; reset breaker at panel and water heater "on" light comes on. Breaker tripped again in 5 min; reset breaker again and water heater light comes on. Cycle continues to repeat. Bad...
It is possible that the breaker is bad. It is also possible that your water heater is overloading the breaker. It is probably easier to try a new breaker to start with. Unless you are familiar with changing the breaker, call an electrician. Your life is a very valuable asset to you!
Feb 18, 2011 | Water Heaters
After installing my titan N100 the breaker keeps tripping went from 50 amp breaker to 60 and still keeps tripping how do Isolve this problem?
You had an instant heater there before? Or a different type? Your breaker numbers don't mean anything to me, I need amps and volts, what is the amp? 30? and the volt is 220? Or are you in Europe?. And you had the four wires in there before? And you have all 4 wires on the heater line? And the heater is grounded? It should work. Unless it is not getting enough juice, but you already upped the amp. Let me know what you got.
Jul 03, 2010 | TitanNet TITANTANKLESS. COM PRESENTS THE...
Keeps tripping the breaker. i have replaced the e...
It may be a weak breaker. If you have replaced all the components on the water heater. I would suggest calling an electrician to check out the breaker.
May 17, 2010 | Water Heaters
My ge 30 gallon electric water heater keeps tripping the breaker. Home warranty plumber was out on Thursday - replaced element. Today breaker tripped again. Plumber said 250 volts were going into the water...
you may have a bad insulator in the wiring going to this water heater. a electrician can be most helpful in finding any shorts if the other repairman was a certified train technician
Mar 07, 2010 | General Electric GE SmartWater Household...
THE INSTA HOT HEATER KEEPS TRIPPING THE BREAKER?
Hire an electrician.  The breaker needs to be replaced or the wiring in your house is not able to handle it.  I believe most need 2-30amp breakers.
Mar 03, 2009 | Emerson Insinkerator 2.5 Gallon Water...
THE INSTA HEATER KEEPS TRIPPING THE BREAKER?
Is this a new install or is this something that has just come up? If it is a new install, the amperage on the breaker is too low. You will have to call an electrician to come in and check to see if the romex wire is large enough to handle a higher amp breaker. If not, it could be that the breaker has become weak and tripps prematurely. If it's not the breaker its self then the heating element is bad on the unit.
Water Heaters Logo
554 people viewed this question
Top Water Heaters Experts
Donni Steen
Paul Carew
Are you a Water Heater Expert? Answer questions, earn points and help others
