Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Kenmore washer aggiates slower than when new. is
Kenmore washer aggiates slower than when new. is it in need of a aggitator kit, or something else?
  • 463 Answers
Usually, there are two agitator modes. A Normal ("Fast") mode, and a delicates ("Slow") mode. Put washer in 'delicates' cycle and see if the agitator slows down even further. If it stays at same speed as in perma press or 'normal' mode, then there is an open in the circuit betwixt the controller dial and the agitator control.
Posted on Feb 27, 2009
I have a MAYTAG washer that was having trouble in the spin cycle it would drain but would spin slower like the brake was coming on. Now it rinses and spins fine but during the wash cycle it fills then once...
More than likely it has a broken wire underneath that controls the spin. and agitation. I had an old Kenmore that the wire that controls these functions would break about every 6 months.
Apr 28, 2010 | Maytag Washer Timer - 22004015
Washer aggitate for 20 seconds then stops, starts
This could be your control switch. Remove the front cover at the top that has the dials on. Check main switch unit, it probably needs to be rebuilt, about $35 or installed new.
Nov 01, 2009 | Kenmore 22422 Top Load Washer
Will not agitate 110 92587210 Kenmore Washer
I have 2 words for you: "dog ears".
the dog aggitation ears are what cause the aggitator to aggitate. Those things wear down and not grab after time.
Pretty easy to change out. You just need to pull the aggitator out and change the 4 little plastic ears. Good luck :)
Jul 13, 2009 | Kenmore 24032\24036 Top Load Washer
My Kenmore model 80 washer won't aggitate but spins and drains without issue. The aggitator tries to move but acts like there is a gear stripped or something.
you will need to purchase an agitator replacement kit for your washer and, the clutch will need to be replaced as well. these components are damaged and, replacing them will restore your units agitation functions.
Jun 07, 2009 | Kenmore 15944 Top Load Washer
Kenmore front loading washer won't drain or aggitate, just buzzes
take the front bottom panel off. inside there is a drain pump. you need to remove filter from drain pump its look like a knob. be careful because their is water inside your drain pump so use some big thing for water. clean your filter. put filter back tight. i hope will solve your problem.
May 23, 2009 | Kenmore 43142 Front Load Washer
Kenmore 20842 won't spin or aggitate
Check your motor drive coupler. Tilt washer back against wall and look between motor and transmission . You will see a rubber grommet and two plastic couplers on each end of rubber , They may appear broken or you will see rubber shavings under washer.
May 11, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore washer
ckd wires to motor ..next timer slim chance could be water level switch most likely motor wire
Jul 21, 2008 | Kenmore 24032\24036 Top Load Washer
Aggitator is lose small items (socks) fall down behind aggitator
When the wash plate is loose (can be lifted up and down) it means that your washer needs a u-joint kit. Yes, Whirlpool actually came out with an entire kit for this.
Tightening the bolts (actually there are 6 of them) won't fix your problem. The kit number is 285927. There's an instruction sheet included with it.
After you get the kit and are ready to install it, remove the white plastic dome by inserting a flat screwdriver into the 4 small slots (look closely and you'll see them) and lifting up at the same time.
*Beware... this is a MAJOR job. Be prepared to spend a long time on it. You'll need to lift the top panel, remove the balance ring, remove the wash plate, remove the drive block nut (<---sometimes requires a torch), etc... It may not be something you wanna jump into. Call an appliance repair outfit and ask them what they'd charge to install one if you ordered the part.
Mar 28, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Washine mashine aggitator
Rob, sounds like you need an agitator repair kit. Not a hard job, under the dispenser cap you have a set of ears, spring and plastic bearing. The kit is cheap, you can find it here http://www.repairclinic.com/0080.asp Catriver...post back
Dec 03, 2006 | Kenmore 15864/15862 Top Load Washer
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
206 people viewed this question
Dan Webster
Dan Webster
Sal De GO PATS
