The wiper arm for passenger side front window wiper doesn't move when on
SOURCE: The windshield wiper mechanism arm fell off.
snapped wiper transmission arm back into place and it works just fine. thanks for your concern. will not need help after all...
SOURCE: 2004 grand prix driver side wind shield wiper
The arm is stripped onto the stud its pressed into which is call a wiper transmission. That part mounts to eack ww blade then to the wiper motor. You need a new transmission and maybe a new wiper are as well
SOURCE: 01 Grand Prix. Driver's wiper barely moves, then
The wiper arms are mounted to "splined" shafts. Either the arm or shaft may be stripped. You need to remove the arm and inspect them.
SOURCE: 1998 Grand Prix Windshield wiper problem
I assume that the drivers side is working perfectly and only the passanger side has a shorteded erattic sweep . It will be either a loose locking nut on the wiper arm (on spindle) or unusually a faulty crank arm (weld) on the underside of the wiper spindle . Good luck
SOURCE: driver side wiper arm came off wiper transmission
You can remove the screws and fix back by placingit into the parked position , so that the wiper nurlings fit exact into the wiper slots.
