Question about Dometic Rooftop RV Air Conditioner
Dometic/Duotherm propane furnace won't fire up
I have a Due Therm Mod 65920-064 and on turn-on, the fan begins to blow but there is no flame. Is there supposed to be something hot to view in the little window? Like an electric hot plug or wire? I don't see anything in there and don't see a reasonably easy way to get into it. Can one get to it without pulling the entire heater out of its cabinet?
  • 1,800 Answers
The ignition switsh it wet or spark plug defective u need a replacemet in this case!
Posted on Feb 27, 2009
  • Jalal Sordo
    Jalal Sordo Feb 28, 2009
    just trying to help not inap.
Fan run compressor run but no cold air
DuoTherm by Domestic-Fan runs, no cold air - iRV2 Forums
www.irv2.com > ... > RV Systems & Appliances
Jan 22, 2012 - 12 posts - ‎4 authors Duo Therm by Dometic 13500 BTU air conditioning with ducting, furnace. I. ... If the fan runs but no cold air and the compressor feels like it is ...
A/C just stopped blowing cold.....any ideas??! - RV Forum
www.rvforum.net > ... > RVing message boards > Trailers & Fifthwheels
Jul 27, 2008 - 23 posts - ‎6 authors We have run it continuos like this before without any troubles. Thanks for the help! ....When you switch the AC unit on, the fan runs, but the compressor doesnt fire up. You used to be able ... You can find Dometic here. Logged. Dometic Duo Them Air Conditioner Cycles
Jul 21, 2015
Dometic SL-135 A/C problem
May 29, 2012
Dometic ac compressor runs but fan does not on auto
Jun 5, 2011
AC blower runs full time w/ AC on
Sep 2, 2009
More results from www.rvforum.net
Nov 18, 2015 | Dometic 705600009 A-284, SMX II Retrofit...
Duotherm dowmflow propane furnace the pilot keeps blowing out
There should be an access hole in the gas valve near the pilot gas tube entrance to readjust the pilot pressure. There may also be a small regulator in the tube for adjusting pressure. But if it was OK for years and all of a sudden just started blowing out, its probably a dirty pilot assembly. Also, if you have changed locations of your propane tank to a cooler location, ambient temperatures will lower the pressure of the propane. If your not familiar enough to remove, clean and replace the pilot assembly, you should call a trustworthy tech. There is a definite reason it started blowing out. All possibilities should eliminated before raising pressure. ALWAYS be careful with propane! Unlike natural gas, it is heavier than air and will collect in the tray under the burners and explode when a flame is established. Propane explosions are common. Be VERY careful!!!!!!!
Nov 05, 2013 | Heating & Cooling
I have a suburban lp furnace and duotherm air/heat pump roof unit. duothern thermostat. 20 amp breaker kicked ( reset breaker) & furnace quit. NOW furnace fan comes on but does not light, and the front...
I'm not sure what the problem may be but you could try calling All Seasons RV Appliance Parts & Service. There number is 1-800-344-0673 they have helped me in the past. That and there tech calls are free so it wouldn't hurt to give them a call.
Jan 23, 2010 | Dometic Rooftop RV Air Conditioner
If this unit has a spark ignition you may just need to clean the flame sensor. It is a metal rod protruding in the path of the flame.
Feb 10, 2009 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
497 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
mike cooper
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
