Question about Toshiba 42HL167 42 in. LCD Television
My toshiba 42HL167 won't turn on
When i turn it on the orange light just blinks
  • 1 more comment
  • Robert Short
    Robert Short May 11, 2010
    if its 3 blinks pause 3 more; then I have seen this before.
    replaced the seine board and it fixed it. part number 75007224
  • sssnake Jan 30, 2014
    Save your money on a new board and find an old SD card and go here:http://support.toshiba.ca/support/ceg/do...
    I had the same issue and the instructions on the link above fixed it. i spent 50 cents on an obsolete SD card.
Until you get it fixed, i found a way to get mine to come on. I have been doing this for the last three months. I will probably just buy a new (different branded) TV, rather than repair.
But, what I do is watch the yellow light blink three times then i count to three and then press hold the power button(on the tv). the yellow light will blink three times, go off for about three seconds, then blink twice. if it only blinks twice after the pause, then let off of the power button and press it once and then the tv comes on.
If this doesn't work then i just start over and try again and eventually it comes on.
Posted on Apr 30, 2010
  • 1 more comment
    I eventually fixed it completely. It took a 256mb sd card with a firmware update file on it. The instructions can be found here:http://support.toshiba.ca/support/ceg/do...
    This solved the issue completely and the tv still works today. I am regret that i didn't post this sooner, for i fixed it about a year ago, but i had completely forgotten that i created an account and posted this on this website until i received an email that said over 6,000 people read my solution. i hope that all 6,000 come back and read the real solution.
    *regretting
    President:
  • 814 Answers
Try this fix from the toshiba website. Q. I have no picture or sound, but I have a blinking power light?
Models: LCD-2007
REF:FAQLCD00090
1. Try resetting the TV by disconnecting the power for 30 seconds and then plugging it back in. If this has no
effect, try moving the TV to a different power outlet that has been tested and is known to be good.
2. If your unit continues to fail, please contact our Customer Solutions Department at 1-800-631-3811 Monday
through Friday, from 8 a.m. until 7 pm CST for a local Toshiba Authorize Service Station Hope this helps you with your problem.
Posted on May 16, 2009
What's your problem? won't turn on..... yellow/orange light continually flashes three times...
Toshiba Regza 37in - 37HL17
TV will not turn on - Yellow power ind. Light blinks three times...
Fixed with a firmware update (hard to believe, but true). Search Google for a file named: 2007SEN069.zip (don't worry if the page you find it on doesn't mention the 37HL17 - it worked fine). Unzip the file, and copy the 3 folders and 3 files to the root of a small SD card. The SD card MUST be 2GB or less in size (I used a 1GB card), and it MUST be formatted with FAT-16 (not FAT-32). Mine was pre-formatted as FAT (FAT-16). The SD port is on the back of the TV behind a cover plate near the power cable. You do NOT need to remove the back cover of the TV, just the small cover plate (1 screw). UNPLUG the TV; remove the cover plate; insert the SD card (prepped as explained above); Plug in the TV; Watch the yellow lights blink, then turn blue, then go dark; UNPLUG the TV; remove the SD Card and replace the cover; Plug in the TV; Yellow lights will blink a few times (this is normal); when blinking stops, turn on the TV and you should be good to go. :-)
Pictures attached are from a Toshiba software upgrade bulletin I found online.
09adb97e-8925-4d59-b218-7443a6e64989.png 82ea33aa-2353-4e13-a5db-8be13ba85711.png
Aug 06, 2012 | Toshiba Regza 37HL17 37 in. LCD TV
Replaced lamp but lamp light still blinks orange
I have a wd-57731 The lamp light blinked orange. i replaced the lamp turned the tv on and the timer blinks green for one minute and then the lamp light blinks orange again. It won't turn on. Can you suggest anything?
Nov 22, 2011 | Mitsubishi WD-57731 57" Projection HDTV
The laptop (recently) has just started to blink 4 (light) orange lights consecutively every time i try to turn it on. It just won't turn on, it remains with a black screen. The light blinks in where...
It looks like your laptop is in standby.
Try pressing power button.or
CTRL-ALT-DELETE- at the same time.
This should reboot your computer.
Failing this:
Remove power.
Remove battery.
Reconnect power.
Turn on.
Jan 01, 2018 | Toshiba Satellite L655S5163 156 Notebook
Screen goes blank on toshiba 42hl167. sound still works, and turning the tv off for a few minutes restores the picture.
your tv's pictures tube are creating the problem. contact with the tv brand customer services center for the repairment of your tv
Jan 06, 2011 | Toshiba 42HL167 42 in. LCD Television
42hl67 has a continuous blinking yellow light in 3 blink intervals, how do I fix this?
I followed the steps at the following link and it worked for me. I have a 2007 Toshiba Regza 42HL67, but the firmware applies to many models as documented in the readme file at the location found via the link below. I used a 1gb SD card formatted FAT16, copied the unzipped files and folder to the card (wasn't sure if it required the top level folder or only the files under the top level folder so I copied both to the root of the SD card), unplugged the TV, inserted the card, plugged in the TV, waited 2.5 minutes, unplugged the TV, removed the card, plugged in the TV, yellow light flashed 3 times and went out. I turned on the TV and it has worked normally since last night.
http://www.benjammin.net/www/pages/techtips/Toshiba-Regza-42HL167.html
May 09, 2010 | Toshiba 42HL67 42 in. LCD Television
I have a toshiba 42HL167. Love it but recently when the power is off iget a repeating blinking yellow light. Blinks 3 times pauses blinks 3 time pauses blinks either 2 or 3 times then stops for 25 seconds...
Yes. The Yellow LED blinking 3 times is a normal boot-up, but if it keeps doing it -- it needs the firmware "update" (which is more like a reload because it got corrupted.) The problem is, no one talks about how to do that. (there is a PDF and firmware on toshiba's website, but it lacks some crucial details.)
My friend gave me his 42HL167 after this problem started after a power event during a storm and I managed to fix it by reloading the firmware.
I posted instructions on my website at:
Once I figured out some of the facts, it was a breeze...
Nov 06, 2009 | Toshiba 42HL167 42 in. LCD Television
Tv will not turn on
Possibly not.. in this case with the 42HL167, the CPU pcb (most commonly referred to the SEINE PCB) is having issues booting and just isn't starting up.
I posted this elsewhere here since there's so many duplicate threads... trying the firmware update is simple, so it's worth trying that first since the case doesn't need to be opened.
-Ben
Jul 10, 2009 | Toshiba 42HL167 42 in. LCD Television
REGZA 42HL167 Won't turn on
I found it!
I posted detailed instructions on my website at:
I hope this is still useful for others. It's so embarrassingly easy anyone can at least TRY it before calling a tech if they have any friends that are computer savvy.
-Ben
Apr 22, 2009 | Toshiba 42HL167 42 in. LCD Television
I found it!!
In my case, the 42HL167, the CPU pcb (most commonly referred to the SEINE PCB) is having issues booting and just isn't starting up.
I agree -- it seems like a design flaw. What cracks me up is that the places I called for a replacement SEINE PCB require the core (the bad PCB). Well GEE, why is that!?!? EASY FIX MAYBE?
It was. Too easy. Shamefully easy.
-Ben
Aug 18, 2008 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
Toshiba 42HL167 42 in. LCD Television Logo
1,076 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
