Question about Maytag Neptune MDG5500AW Gas Dryer
How do you remove front panel of a dryer?
I have an electric dryer, model number MDE8506AYW. An object, I beleive a peice of wire about 5 inches long, is interferring with the rotation of the drum. I need to either remove the front panel or raise the top to get access so I can remove the wire.
  • Anonymous Mar 01, 2009
    How do I remove front and / or top panels
When you open the door you will see two philps head screws on each side. Two of the screws hold the door on. Remove the 4 screws and the front comes off.
Posted on Mar 05, 2009
Noise on rotation and lint filter won't go in
must be something locked in the blower. Seen it. You must remove filter chute and check for objects. DUET DRYER MANUAL
Dec 24, 2013 | Whirlpool Dryers
Tip
How to Change the Heating Element in a Electric Dryer?
1) When the clothes are not getting dried but dryeris running. That means the heating element needs to be replaced.
2) First of all unplug the dryer from wall outlet.
3) The heating element is located in the cabinet. Insome models the cabinet is located in rear or in some models its located infront.
4) Remove the screws on the heating element cabinetto reach the heating element.
5) You will see wires connected to the heatingelement terminals.
6) Remove the wires from element using needle noseplier.
7) Then remove the object blocking the heatingelement with the screw driver. But in some models the heating element can be removeddirectly.
8) After removing the object remove the screwsholding the heating element.
9) Theheating will have to be moved a bit to come out easily. Before removing theheating element out. Please note down the position of old heating element. Sowhile placing the new heating element you don’t face any problem.
10) Refit all the parts removed while removing theold heating element properly.
This will help. Thanks.
on Mar 20, 2010 | Dryers
The peice used to close the dryer has broken off is there maybe a peice that is usable to fix it or replace the item?
Hello, truth1333.
With the model number of your machine, try looking here:
http://www.repairclinic.com/
Enter your model number and hit 'Enter'.
I'm not sure which piece you need, but try looking at the parts listed in 'Latch Parts' in the drop-down menu ('Part Type').
Feb 28, 2011 | GE Spacemaker Washer and Dryer Electric...
Drum occasionally will not turn unless manually turned a few times before start; can here a thud each time manually turned.
I beleive the start capacitor is faulty & it has dropped away from where it's supposed to mount inside,the capacitor is probably dangling down,hanging by it's wires & banging on the drum as it rotates.The start capasitor gives the motor it's first kick start to get goin & it's not working that's why you have to help by turning the drum.
Jun 04, 2010 | Whirlpool LER4634J Electric Dryer
Dryer wont start. Seems like the motor is jammed. Drum rotates by hand, belt is ok, rollers ok. electrical smell when I tried to start. Automatic shut off/breaker kicked the switch, disabling it...
if you can move the drum by hand you have a bad motor,when was the last time you cleaned the dryer?when i clean them i blow off the motor,all kinds of junk blows off the motor even though it looks clean,it over heats the motor,also overloading will kill it,try popping the top on each side in the front,if the filter is on top remove the two phillips screws on the top panel in front of the filter,once you pop the top you'll see two 5/16 inch screws one on each side around four inches from the top,remove them,take off the door switch wires and then under the door section remove the springs and the other two screws one on each side and remove the front panel,whatch out for the door,you just removed the tention springs so it will pop open and unplug the dryer before you do this,remove the belt and take out the drum,i'm not sure what model you have,if you can't figure out how to remove the motor send the model number and i can help you to get the motor out,it's not that hard in kenmore dryers
Mar 11, 2010 | Kenmore 73952 Gas Dryer
My ge gew9250p dryer heating element is needing replacement what is a good part number for this
Hello there:
this should help you out ok
See Part # 14 on diagram.
or
See all parts for this section / diagram Heating Element (11" long x 5" wide) (Heater Element) This heating element fits later model Whirlpool/Kenmore brand electric clothes dryers. Each of its two terminals measures 5/16 of an inch, while the unit itself is approximately 11 inches long by 5 inches wide. This element carries 5200 watts and 240 volts. Appliance Help Part Number AH344597 Availability: In Stock Compare At: $56.32 Your Sale Price: $46.93 You Save: $9.39 SALE PRICE:$46.93 -->
Nov 22, 2009 | Whirlpool GEW9250P Electric Dryer
I have a Whirlpool gas dryer that buzzes when I turn it on and gets hot, but does not rotate.
The problem you describe sounds like a broken belt. The steps below outline how to check for that and disassemble if necessary.
Disconnect Power. Lift Cover on lint filter. Remove two Phillips screws taking care NOT to allow them to fall into the blower housing. Place putty knife in the seam between the top and front panel about 2” in from either side. Push in on clip while pulling control panel forward and tilting putty knife handle up, all at the same time. Same on opposite side. Raise top all the way.
Check for belt on drum half way back on the drum running from left to right. If belt is missing or broken replace with part number 341241 later in this process.
Looking down inside dryer on left and right see a 5/16" hex head screw about 6 inches down. Remove each side while holding front panel in place. Pull top of front panel about 3 inches forward from sides and then pull up. This will disengage the front panel from lower pressure clips and allow you to turn it sideways and expose the dryer interior. Rotate front panel to right to get it out of the way watching to ensure wiring is not damaged.
Place new belt over drum groove side down if old one was broken. Check white idler pulley for free rotation before installing in holes of floor under motor pulley. Replace with part number 691366 if rotation of pulley is not free or if it appears worn. Loop belt with ribs inward and pass through the open space in the idler arm below pulley then pass loop over motor pulley rib side down. The configuration at the motor should now look like the Whirlpool model in the image below:
http://www.applianceaid.com/images/belt-config.JPG
Grasp front edge of dryer drum and rotate counterclockwise slowly to align idler and motor pulley and to remove any twists in the belt.
Reverse disassembly process to re-assemble. Good Luck
Sep 09, 2009 | Whirlpool LER5636P Electric Dryer
Replace belt on kenmore 97281100 dryer
You have to remove the front panel. The top folds back and there are 2 screws on the inside corners to release the front. Eric
Sep 07, 2009 | Kenmore Dryers
My whirlpool dryer heat up. But does not spin.
Belt and pulley configuration
Sep 06, 2009 | Whirlpool Dryers
Desthe dryer warms but it doesn't rotate
is this with a cycle started or not? if no cycle started and it warms then part of the element is grounded to the frame. (120v to ground) or if cycle will not start then first check your thermal fuse (in rear with two blue wires), and still may have a element problem because the motor contains a centrifugal switch to make sure element does not operate with out motor running. also check for a lot of lint build up on motor, possibly interfering with switch on connection box.
Jul 11, 2009 | Whirlpool LER4634J Electric Dryer
Maytag Neptune MDG5500AW Gas Dryer Logo
156 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
