Question about Coby DVD-224 DVD Player
I have 2 dvd players that have gone out on me this week. One does not read the disk and the other door won't open. Is there a lens cleaner for dvds that might work:
  • softee2003 Mar 04, 2009
    My players are not Cobys. One is a Panasonic DVD/VHS player that is kind of old, VCR still works but DVD keeps saying Can't Read. The other is an I.T., don't even know what brand that is, but it has the surround sound hooked up; on this one the door will not open. Thanks anyway though.
  • 463 Answers
The Coby 224 is a bottom of the line "piece of cheap Chinese crud". No offense, but this is a DVD player that costs more to ship it over here than it does to manufacture the product. Purchase something a bit more substantial for continued dvd viewing.
Posted on Feb 27, 2009
DVD player not working!
The player uses a laser to check for a DVD. If the laser fails, the player acts like there is no DVD loaded and opens the disc tray so a DVD can be inserted. Sounds like a bad laser.
May 04, 2015 | Televison & Video
Problems reading dvds
Have you tried cleaning the lens of the portable player? You can purchase a DVD cleaning disc, this disc has microfiber brushes which clean the laser len assembly of the player as the disc spins.
Hope this helps
Jul 06, 2008 | Televison & Video
The go video DV2130 will not read a dvd. It loads, but will not play. Can this be fixed? No longer under warranty
  1. Make sure you have a non home made DVD. Some DVD players will not play DVD'S in certain formats.
  2. If you have a normal DVD in the DVD player and are getting "NO Disk" then there is a real good possibility the lens is just so dirty that it is not recognizing your DVD at all. This happens a lot to all disk players that are neglected from the cleaning process. Get a disk player cleaner and run it through a few times until the disk is read again. Sometimes the lens is so dirty you have to try a few times just to get the cleaner disk itself to play just to do the actual cleaning. Make sure to run that cleaner disk through once a week. These disk cleaners "sweep" the lens and work well. You can get one at your local Best Buy for $8usd.
  3. The last thing it could be is that somehow the lens has come out of alignment. Just a millimeter out of alignment is all it takes to not be able to read a disk and DVD players get bumped and knocked off the shelf easy. So this can happen often especially with the more smaller travel DVD player.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Jul 21, 2011 | GoVideo DV2130 DVD Player/VCR
My portable dvd player will not read any dvds
  • I would give it a good cleaning with a disk player cleaning. Those disks have little bristles on them that "sweep" the lens and clean it real well. Remember that if the lens is so dirty that it won't play any DVD you may need to run that cleaner disk a few times to get the lens back to normal working condition.
  • A lens cleaner disk should be ran one time a week to avoid problems with playing disks be it CD or DVD or Computer.
  • Sometimes players go bad so keep in mind this could be the problem as well but I have had the DVD player in my garage get so dirty I had to clean it a few times to get it to work normal.
Regards, Tony
Jul 11, 2011 | Sylvania SDVD8732 Player
Dvds and cds don't work. the screen just says reading to no end
First remove power cord from the wall for five minutes o reset the firmware. Then power on again and let the firmware load before inserting any dvd or cd. If it still can not read the disks, you use TDK lens cleaner until it can read the cleaner disk. It maybe power line glitches, you may need powerline filters for this dvd player.
Aug 20, 2010 | Yamaha DVR-S150 DVD Player
I have a portable dvd player model number mdp1030 the unit keeps saying no disk I have tried numerous disks same results.
then i think the lens is not able to read the disk.
and so i would suggest you to buy a disk cleaner CD and run it in your DVD player and then use your regular disks.
if this is not working then it is some internal fault in your DVD players lens.
Aug 13, 2008 | Mintek Televison & Video
CH dvd300 plays music cds wont read dvds states continuously insert disc
The non-technical answer would be that the lens needs to be cleaned. This is the first step for this type of problem. There are many things that can get the disk drive lens dirty like smoke, incense, dust, moisture. Open the unit and open the DVD cover. You will see the lens that reads a DVD. Get a cotton swab (the ones for cleaning out ears) and some isopropyl alcohol (rubbing alcohol) and moisten the cotton swab with the alcohol (moisten not soak) and gently (I mean, do not push hard or scrub hard) rub it on the lens. Now with a dry cotton swab, do the same. Let it dry for a minute (longer if the swab had more alcohol and it might have dripped down) and close the unit. Now try to play DVDs and let us know if it worked. If this does not do the trick then it could be a firmware issue that can only be fixed if the company put a download on their support page.
May 29, 2008 | Cyberhome CH-DVD 300 DVD Player
Problem with reading and playing dvds
Basic DVD, CDrom Troubleshooting
wrong disk ,disk error,
First Clean the lens:
http://www.ehow.com/how_2036275_clean-lens-dvd.html
wont open, wont close, makes clicking/grinding noises etc.
http://www.llamma.com/xbox/Repairs/thompson_dvd_tray.htm
Feb 07, 2008 | Sanyo DRW-1000 DVD Recorder/VCR
DVD player
My Smasung DVD/VCR Combo stopped reading DVDs because of a dirty read head. It started by only playing disks sometimes, and progressed to never playing disks. I assumed it was a dirty laser lens so I bought a lens cleaner set. Unfortunately my player wouldn't play the cleaner disk.
So I took it apart and cleaned the laser lens manually with some isopropyl alcohol (the clenser that came with my cleaning disk), and a lens cloth (that came with my glasses). Just open the case (starting with the screws in the back) and remove the snap in cross panel that obscures the lens of the DVD portion. Put a drop of cleanser on the lens and gently wipe it with the cloth.
Oh and by the way, I take no responsibility if you break your own player while following my instructions. My own DVD player was far out of warranty at the time I cracked it open.
Dec 30, 2007 | Samsung DVD-V3500 DVD Player/VCR
Samsung DVD-4600 DVD/VCR Player
Aug 16, 2007 | Samsung DVD-V4600 DVD Player/VCR
Coby DVD-224 DVD Player Logo
Top Coby Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Coby Televison and Video Expert? Answer questions, earn points and help others
