Question about Poulan Pro 22" Self Propelled High Wheel Mower
Snowblower only runs on choke. Seem like not getting enough gas.
I have a poulanpro 9 hp 30'' snowblower. It is two years old. When I start it, it begins to die right away. I can keep it running by pushing the primer and keeping the choke on. As soon as I take the choke off, it shuts off.
  • 97 Answers
SOURCE: my pbv200le leaf blower only runs when you keep
Check fuel filter,,lines, then carb.
It may need a carb kit.
Posted on Mar 25, 2009
  • 71 Answers
SOURCE: Poulan weedeater will only run with choke half way on
this could one or a combination of a few things
1 check inside the tank for dirt 2check that the filter screen inside the tank is not plugged3 make sure the gas feed tube is not restricted pinched in the case or kinked also you can try a simple carb adjustment.also check to make sure the plug is gapped to the right specs good luck and i hope one of these suggestions do the trick
Posted on May 02, 2009
  • 95 Answers
SOURCE: starts then dies unless you keep pushing the red bulb
You will have to remove the fuel bowl from bottom of carburetor and clean the varnish out of the carburetor.Take note that the screw on the bottom of the carburetor is a fuel metering jet,there are small passages in it that may need to be cleaned out with a small wire,be careful not to enlarge the holes in it,they are important for fuel metering correctly.You may have to soak it in carb cleaner. Be sure to use good carb cleaner. The brand name Berkebile 2+2 is the best followed by Gumout.
Posted on Jul 31, 2009
  • 486 Answers
SOURCE: Poulan Pro Mode 96134000800 push mower dies immediately
Fuel Starvation - Float Bowl Carburetor
1) remove air filter assembly
*be cautious of tearing the mounting gasket. If it does tear, you HAVE to replace it. It is part of the priming system
2) remove the float bowl fastener. This is the main jet
3) carefully remove the float bowl, the rubber o-ring/gasket will not be able to be used if it is removed, you WILL have to replace it
4) using a spray 'carb cleaner'
spray up thru the center of the carburetor
spray and clean the main jet with cleaner and 'tag' wire
(tag wire is very thin, and can be used to clean the hole in the center of the main jet)
5) clean any debris from inside the bowl or carb body
6) re-install bowl and center bolt, air filter assembly
*if you need gaskets, your Briggs dealer can supply. The kit is cheaper than individual gaskets, and all the parts needed to finish the above repair are in the kit.
Posted on Nov 22, 2009
SOURCE: Poulan snowblower with tecumseh engine runs
This is a common problem with snow blowers becuase they set around more then they get used and the gas gets stale and cloggs up the carb. First thing to try is remove the bolt that holds the carb bowl on and clean it. It should have 1 or 2 holes through the side close to the bottem and 1 hole about half way up. If this doesn't do the trick you need to remove the whole carb disassemble and soak it in carb cleaner.
Posted on Jan 07, 2010
I have a Ariens snowblower deluxe 30 which is a year old. Starts fine and will run. Unfortunatley it is running way to low. I have replace the gas with fresh gas ran it through completely
It is very possible the carbureator needs a cleaning. Moisture can corrode the inner parts of them if left all summer. I find that the fuel usually does not go bad over the summer. I always start my snowblower once a month over the summer and then have no problems when the snow flies again. There was a time when mine was losing power and quitting also. There is a screw on the bottom of my carbureator that needed adjusting. If you are lucky that may be all you need. By turning mine in and out a bit I found the spot where the gas was correct and it worked fine again.
Jan 08, 2017 | Ariens Garden
One year old murry snowblower won't start. Don't smell gas
Most of the time it is trash in the carb. try putting just a small amount of gas in the carb. do that a few times until it starts you might have to use your hand to act as a choke, moving your hand up and down over the carb opening until it runs smooth on it's own.
Feb 27, 2015 | Garden
Snowblower only runs on full choke
try adding a little (few ounces) of sea foam to the gas tank and then running it for an hour or so.
if this doesn't cure it, you may need to take the carburetor apart and clean it.
your symptoms are typical of dirty jets (not enough fuel/ too much air)
Dec 30, 2012 | Garden
208cc b&g craftsman snowblower governor settings
sounds like last years ethanol gas messed up your carburetor.
Probably have to drop the carburetor Bowl and clean the Jet
Nov 22, 2012 | Craftsman Snow Blower / Snowblower Bottom...
The snowblower starts great, but then it will not shut off. have to snowblow my neighbors, waiting for it to run out of gas
Try lowering the choke all the way below Turtle Speed. With any luck this will shut the snowblower off.
Mar 07, 2011 | Sport & Outdoor - Others
I have a 17 year old snowblower. Sears Craftsman 3 HP single stage. It wouldn't start. I changed the spark plug and now it started but it's running very rough with excess smoke. If I press the gas...
Good to hear you got it running anyway.
Look for a choke, maybe it's just running with the choke set. Could also be that it's all gummed up from sitting, if that is the case then some running should bring it out of it by the time you've put a couple of tanks of fuel through it.
Is this a two-stroke motor? If so, be sure you have your fuel mixed correctly- go by the manufacturer's statement concerning how much oil to how much fuel, never assume that the oil bottle directions apply to your machine because they probably don't.
Good luck with it,
Dec 28, 2010 | Craftsman Garden
My mastercraft "deluxe" 8 hp, 26" snowblower won't
Could be dirt in the carb. If this engine has a fuel cup on the bottom of the carb take it off and clean it out and clean the fuel jet. It is the little screw that has a little hole through it. If this has any dirt in it the engine will not run. A lot of engines I get in this is a quick fix as most people do not run the old fuel out before they store it for the summer. Check the spark plug as well and see if there is wet gas after trying to start. Maybe your choke is not working.
Oct 26, 2017 | Garden
Snowblower wow's
tecumseh snow engines are natorious for not starting,first thing you need to do is take the old gas from the tank.gas only stays good for about 30 days.YEP .....that's all.there should be two screws that holds the cover over the carb.take the bowl off and there should be water and dirt in the bowl.clean that out,be careful not to drop the needle off the float.if you do it take a little patence to put it back the nut you took off the bowl has three holes in the side of it.clean all the holes,one is really small and it's up twards the theads..replace the bowl gasket and reassemble the you should have fuel to the cylinder and it should start.if not let me know
Mar 02, 2009 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
I have a troy built snowblower that has sat for 7 years.
hi roaddoctor86; I suspect that your carb is the source of your problem in the fuel system. I always drain the fuel in my 2 cycle and even 4 cycle engines and then start them and run them dry, before I put them up for the winter/. I would suggest you drain the tank or at least take most of the gas out and then add a can of gas treatment/solvent and see if that helps. Something like Heet I think is one product.
Hope this helps good Luck Loriongh ps Please leave a rating if appropriate Thanks
Nov 20, 2008 | Karcher 2500 PSI Pressure Washer
Poulan Pro 22" Self Propelled High Wheel Mower Logo
251 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
