Question about Canon PIXMA MX310 All-In-One Printer
Mx310 makes a buzzing sound
When the printer is on and not printing, I get a small buzzing sound, It does not seem to affect the printing. What could this be?
  • 1,800 Answers
A shorting out on a Print IC :
  • unplugg/ plug usb cord
  • uninstall/install soft
Posted on Feb 27, 2009
Mx310 makes an alarm sound while the power buton is flashing , any ideas ?
If you use the printer connected to your PC, you should get some error message when you send a print job. If you use the printer as standalone (without PC), count how many times the power LED flashes, then check the Canon website for explanation of the problem. Usually the LED will flash few times than pause before flashing few times...and so on.
good luck with it!
Jun 16, 2015 | Canon PIXMA MX310 All-In-One Printer
Which alternative printer software can I use, since Canon MX310 is not listed in the software from which I want to print.
go to the canon web site and down load from there as the wizard relies only on what microsoft has included in the list and may not be up to date
Aug 06, 2017 | Canon PIXMA MX310 All-In-One Printer
It seems that my printer mx310 is always offline?
Go to printer option.. or there must be small icon right corner.
And you can see off line printer is checked.
If it is checked, pls click once more and won't see any check mark and u r good to go
Apr 24, 2011 | Canon PIXMA MX310 All-In-One Printer
My paper is jamming as it is tilting to the right side when I print.
check to make sure that is not a small piece of paper stuck in between the rollers.
Mar 03, 2011 | Canon PIXMA MX310 All-In-One Printer
WHen printing from MS Word academic version, the canon MX310 will print 1 page across multiple pieces of paper, at random. The drivers have been reinstalled. Any ideas?
Many programs allow you to change the size of the page for the document you are creating. If the size of the page defined in the program is different than the size of the page set in the printer driver, the document may print too small or over multiple pages.
In the application you wish to print from, check for a 'Page Setup' option in the 'File' menu. Make sure that the defined page size in 'Page Setup' matches the printer's settings. If you are unable to locate 'Page Setup', consult the application's 'Help' files or manual.
Jan 09, 2010 | Canon PIXMA MX310 All-In-One Printer
Canon MX310 keeps not printing and message comes up paper jam sometimes nothing happens sometimes startes to take paper then stops sometimes just feeds through without printing , there seems to be no real...
Have you ever tried printing sticky labels in the thing? You have to be careful with those because sometimes a piece will come off and stick in the corner of your printer. If you don't have long surgical tweezers to pull it out, you could be looking at an expensive repair. Also check your manual. There are two places the paper can jam in. You might have checked only one. I have a different Canon model but on mine I also have to make sure the correct light is on. Is the light for feeding from the back on, or the light from feeding on the front? If you have the same light, press it again to change the place where it will feed from.
Make sure your paper isn't curled or that you're using paper that's too thick also.
Can't answer more because I don't know what program you are using to try to print.
Sep 24, 2009 | Canon PIXMA MX310 All-In-One Printer
Ran out of color ink on cnnon mx310 ... want to
If when you attempt to print only with the black cartridge installed but it won't print, then this specific printer requires that color ink also be installed. Typical with most inkjets.
Jul 07, 2009 | Canon MX310 Office All-In-One Printer
I have an error code 5100 on a Cannon MX310 that will not allow me to print. Can you help please?
There are several things to check
1.remove and reinstall the ink cartidges
2. press ON/OFF switch to reset the printer
3. if the printer is new, make sure all the packing material has been removed
4. Check the paper path to make sure that you do not have a paper jam.
5. If these do not clear the problem, you need to have the printer serviced.
2. 3. Remove Packing Material MX310 4. Removing paper jams MX310 5. The MX310 may require repair
Jun 17, 2009 | Canon PIXMA MX310 All-In-One Printer
Canon mx310 feeds paper w/out printing
Normal 0 Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 09, 2009 | Canon PIXMA MX310 All-In-One Printer
Canon MX310 Scanner Error
The scanner mechanism is locked....there should be a bar or button that slides to lock/unlock. Probably a picture of a lock.....this prevents damage while transporting the device....
May 12, 2008 | Canon MX310 Office All-In-One Printer
Canon PIXMA MX310 All-In-One Printer Logo
85 people viewed this question
old marine
old marine
