Question about Gateway Audio Players & Recorders
No tuner output
I have no sound from am fm out put
    Scholar:
  • 93 Answers
Some home theatre receivers will not output sound until you ( LOCK INTO ) a radio signal, be sure you have a antenna connected and are receiving a strong signal. Unlike the older model you would receive static sound until you found a station.
Posted on Feb 28, 2009
Why cant I hear my am fm radio? if I put the cd player on I hear sound or if I put on satalite radio I have sound but no sound on am and fm ?
The AM/FM tuner could be bad...probably the antennae is not connected completely...please check this first...:)
Jun 01, 2015 | 2007 Saturn Aura XE
Tip
SERVICE MODE TO BEKO 23WL46G 30WL46G
Service Menu StructureThe service menu has three items: display, calibre and version 2.1 Display Display item has seven options:
a- Panel
Panel option gives information about the current panel resolution. It is a read only option and can not be set.
b- Power on time
Power on time gives information about the last update time of the SW running. It is a read only option and can not be set.
c- Backlight on time
Backlight on time option reserved.
d- Scart prescale
Scart prescale option sets the prescale values for the input sounds entering the scart input of the MSP(Micronas Sound Processor). Changing this value you can adjust the level of the output sound going to loudspeakers for all the sources except the Tuners. The range is between 0 and 100.
e- nicam prescale
Nicam prescale option sets the prescale values for the Nicam standard sounds for tuner inputs. Changing this value you can adjust the level of the output sound going to loudspeakers for Nicam sounds entering the analog sound input of MSP. The range is between 0 and 100.
f- fm/am prescale
fm/am prescale option sets the prescale values for the FM/AM standard sounds for tuner inputs. Changing this value you can adjust the level of the output sound going to loudspeakers for FM/AM sounds entering the analog sound input of MSP.
g- Agc(Automatic Gain Control) adjust
Agc adjust option sets the input voltage going to IF decoder AGC pin. Changing this value you can adjust this voltage for optimum Tuner performance. The range is between 0 and 31.
h- R/G/B Brightness/Contrast:
These are used for color bias adjustment. The range is Between 0 and 255
Calibrate
Calibrate item has nine options:
a- video format
Video format option force the video format to the desired format. Selectable formats are Auto, Pal, NTSC and SECAM.
FOR MORE CHECK THE LINK BELLOW
Electronics Equipment Repair Center
Ajin Gopakumar Google
on Feb 16, 2015 | Beko 17WLB450S 17 in. LCD TV
Sony MHC ec77 CD player works fine, great sound but when I switch to AM/FM, why is there no sound although the display shows that is going through the stations?
Unlike old analog tuners, the new digital tuners will not output any sound or static if they do not lock onto a station.
May 06, 2015 | Sony Audio Players & Recorders
Why cant I record FM from this Pioneer vsx921
To record from the built-in FM-tuner, you can use either the DVR/BDR or the CD-R/TAPE outputs of the receiver.
Mar 13, 2015 | Pioneer VSX-921K 7.1 Channel A/V Receiver...
STR-DE835 dead audio. I have a high powered cb radio in my truck will over come amplified stereos. I keyed up the cb not knowing that the tuner was on and now I have no audio. The unit powers up and...
I have seen the higher power cb's fry the fm front end sectioon of the tuner section....did you try to put it on an aux input?....the click you hear is the amp protection relay and it sounds like it is working ok....if it were the output side of the power amp, then the relay wouldn't click after power up...it is probably the front end...this is the entire fm tuning section usually contained inside a metal box near where the antenna comes in
Feb 02, 2011 | Sony STR-DE835 Receiver
FM tuner does not play
Hard to say without knowing more, but many tuners have a squelch function that "mutes" the output unless the signal level reaches a certain threshold. You might want to look at the control panel and search for such a switch and de-activate it.
You didnt say if this was connected to an external pre-amp or a power amp. If so, the issue could be simply one of the correct cabling and selector switch setting
Sep 21, 2009 | Yamaha RX-770
TV TUNER
Do you have a satellite TV tuner with an AV output on the back of the unit?
If you take the video output from the satellite tuner and insert it into the line input of your TV tuner card.  The audio output from the satellite TV tuner can go into one of two places.  The audio inputs of the TV tuner card or the mic input of your sound card.
Sep 13, 2008 | Philips SAA7130 TV Tuner/FM Radio/Video...
No soun on composite mode
How about the patch cord from the tuner sound output to the line input of the PC's sound card. ? Many have neglected to put that in. Green jack on the tuner to Blue jack on the PC.
Apr 20, 2008 | Philips SAA7130 TV Tuner/FM Radio/Video...
Driver you have is not compatible! try to down load a newest version!!! and look on sound manager if mute is off
Jan 21, 2008 | Philips SAA7130 TV Tuner/FM Radio/Video...
Philips SAA7130 TV Tuner/FM Radio/Video PCI Capture Card problems
MY SAA7130 TV TUNER CARD IS NOT OUTPUT NORMAL CA LOUR IT SO ONLY BLACK AND WHITE CA LOUR ONLY PLZ SOLVE MY PRB.
Dec 02, 2007 | Televison & Video
109 people viewed this question
Top Gateway Audio Players & Recorders Experts
Kolbrun...
Tom Chichester
Are you a Gateway Audio Player and Recorder Expert? Answer questions, earn points and help others
