Question about HP DeskJet 2500C Pro InkJet Printer
HP 2500C Pro Series Color Ink Jet with Error Code 432
I just bought a HP 2500C Pro Series Color Ink Jet and it worked at sellers office, but when I powered up after transporting it comes up with this error code, 432. Description per manual is
MECH SS Failure
Service Station/Harness/Logic PCA Error
SS Jammed or SS OPTO Failure
Any idea what I can do, appears something disconnected in the move, but what?
  • Vance Ferratusco Apr 15, 2009
    First of all I'm sorry it took me so long to respond to this fix, but the good news is once I found the time to sit down and do it, it worked. The printer is running again. THANK YOU for all your help.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 121 Answers
The problem is with the service station. This is the unit that the carrier "Parks itself" over when it is not printing. It cleans the print heads and collects excess ink. It also fills up with ink. and the ink dries in a big blob.
If the motor is good, if it was working it likely is, The SS probrably got jammed in the move.
Try this:
If you can move the carrier to the left with power off do so.
If not turn machine on and while carrier is to the left unplug the machine.
You need the carrier to the left to expose the SS.
Open the cover as if you were changing printheads.
Look straight down. your looking at the service station.
A shaft with wipers and a gear at one end should turn. A little resistance but jam if alot of ink is caked in the bottom of the unit.
You can clean some of this in from the top and see if the SS frees up as a test at least.
The service station can be removed if required. You need to remove the right cover from the machine.
There are three screws that you should see looking down at the SS from the top They have numbers next to them I beleive, holding the SS in. Everything that moves should move freely.
Hope this Helps Good Luck
Posted on Mar 11, 2009
I have toshiba e-studio 2500c error code E030. No paper jam.
Power-ON jam: The paper is remaining on the
paper transport path when power is turned ON.
Nov 27, 2016 | Toshiba E-studio 2500c Color...
I bought all new cartridges, inserted them the way they were removed, but message board still says defected cartridges. how to install ink properly and make error message disappear?
Here is a video from HP explaining the process. IF you followed this procedure and are getting errors, then you may have bigger issues. I am assuming you are using genuine HP ink, not remanufactured or refilled cartridges.
Replacing Cartridges for HP Officejet Pro 8600 All in One Printer Series...
Aug 31, 2016 | HP Officejet Pro 8600 Plus e-All-in-One -...
HP Office Jet Pro 8600 Plus throwing error code C8190002
Look up on Google first the meaning of that error, than you'll know how to fix it..
Oct 11, 2014 | HP Officejet Pro 8600
Printhead has a problem HP Office Jet Pro L7590
I suggest you go to the HP support website and see what assistance you can get for this model.
Start by downloading HP Assistant
Oct 06, 2017 | HP Office Equipment & Supplies
Office jet pro 8500 alignment failed error message -black ink intermittently fails.
The following may work: remove all the ink supplies. Remove the printhead and soak it for about 5 minutes in 0.5" of very hot water. Gently blot the printhead on a soft damp paper towel to remove the excess water, then replace in the printer and then reinstall the ink supplies.
Apr 10, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
My HP office jet pro k5400 series has blobs of ink all over the document, how can i stop this from happening.
Have you tried replacing the ink catridge? If so, are you using new ink catridges or refurbished/refilled?
Aug 30, 2010 | HP Officejet Pro K5400 All-In-One InkJet...
HP OFFICE JET PRO L7500/L7600/L7700
my hp office jet pro l7500 indicates the ink has expired in all cartages but the cartgages are new because they were just put in . Before the same error code came up and so bought new cartages. Also the door to the cartages will not stay closed without tape.
Nov 29, 2008 | HP Officejet Pro L7480 All-in-One...
HP DeskJet 2500C Pro InkJet Printer Logo
565 people viewed this question
Ben Johnson
