Question about Pioneer DVR-107D DVD±RW Burner
Hello i'm having HP PAVILLION DV6500 and OS is VISTA ULTIMATE .My problem is that my system does'nt show any dvd drive in MY COMPUTER. I am having PIONEER DVDRW DVR-K17B ATA Device .device manager show a yellow icon and tells that it needs driver. It was working properly before.
  • phillip Jan 02, 2015
    right click on the icon in device manager and reinstall or remove and restart your computer. windows should find the device.
  • 1,800 Answers
Remove it and and put it back again and set bios to default settings
Posted on Feb 27, 2009
Matshita DVD-RAM UJ861H Lightscribe fcn not working
its light scribe day.
again, no pC stated, nor OS stated? why?
1: bad media
2: bad drive or HP don;'t support it.
3: wrong OS loaded, W10?
4: HP dont support this now.... why use it?
5: missing driver for it, matching OS and drive, yah. that be it .
ask hp yet, its not supported now.
https://h30434.www3.hp.com/
try google for alternate support, non HP???? be wise !
Aug 19, 2017 | HP Computers & Internet
Can't get the Cd/Dvd drive to work, Windows vista doesn't show it in the device manager, I have a n HP Pavillion dv6500 notebook around 3 yrs old
If the device manager does not recognise the drive then it has most likely failed. You should be able to remove the drive, one screw on the underside, and reboot, Once you have done this power down, reseat the drive and power up again. If the Plug and Play software doe snot recognise it then you need a new drive.
Mar 09, 2010 | HP Pavilion dv6605us Notebook
Hello i'm having HP PAVILLION DV6000 and OS is
You first remove that device from device manager.
Then restart the pc.
You may check the BIOS menu for that device for any clarification.
After restart since u have removed it the OS will detect the device and install it automatically.
Hope this helped.
Jan 09, 2010 | Pioneer DVR-107D DVD±RW Burner
HP pavillion DV6500 CD/DVD RW not responding, unit will try to boot up many times when system is starting but when I put in a CD or DVD no response and doesn't show a drive in My Computer. I've opened up...
Turn off the Notebook remve all the peripherials, Remove battery and disconnect AC Adapter and then press and hold down power button for thirty seconds.
After 30 Seconds connect Battery and Power supply as soon as you tun on the Notebook keep on hitting F10 Notebook will show BIOS then F9 Notebook will show Load Set-up Default than Hit yes and Hit F10 again it will show save Exit and chnages now that show Fix the Problem
If not than use Philip Screw Driver take out optical drive and put it back in Reinstall CD/DVD Drive drivers using Device Manager .
Thanks and Regards
Neeraj Sharma
HP and Compaq Notebooks Expert
Oct 08, 2009 | HP Pavilion dv6000z Notebook
I need a lan driver for hp pavilion dv6500, the driver from hp website is not working
hmm run a Everest Analise software into your computer and see exactly what kinda device ( lan card ) you have ...cause it is possible that it was changed and this cause the driver malfunction ..
and please specify what kinda operating system you use...( if you changed the lan card yourself and know what model it is ...place it here ...
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=ob-59636-1&lc=en&dlc=en&cc=pl&lang=en&os=2093&product=3380544
anyway ..if its the original ..this is the driver for all kinda Vista operating system
http://depositfiles.com/en/files/5848028
for xp try this one ...
Sep 09, 2009 | HP Pavilion dv6000z Notebook
My pioneer dvr-k17b ata device does not work. ie CDs do not work on my system, which is a Vistas HP Pavillion dv6500
I have the HP Pavilion 9720us laptop, with a Pioneer dvr-k17b dvr. It is not recognizing any CD of DVD. What could be the problem. I have the latest drive update
Jun 08, 2009 | Pioneer DVR-107D DVD±RW Burner
My problem is that my system does'nt show any dvd drive in lapto
The driver for the device would have been corrupted by some incompatible drivers loaded onto your pc lately. It could also be that the device has been mistakenly disabled. If not, disable the device and restart your pc. After it stabilized on the desktop, go back to the Device Manager and enable it again. If nothing still happens, go through Control Panel and remove the driver from installed programs. Shut down your pc and disconnect the device. Leave for about 10 minutes and recoonect and power on the pc, the device should be detected by the pc and then install its drivers. If it doesn't detect the device, it has probably gone bad and should be replaced. Good luck
Jun 02, 2009 | Pioneer DVR-107D DVD±RW Burner
My problem is that my system does'nt show any dvd drive in Lap
I had the same problem, it occurred right after windows installed sp2 and my laptop showed no dvd player with any program, I restored my laptop to the previous day before the update and it worked fine again, after that I just let windows update by itself and it has been a week and everything is fine, also in device manager open the dvd + sign and right click your dvd and click update drivers, if that does not work, right click your dvd, and then click delete, and then reboot your computer, laptop whatever and the computer will automatically recognize the player on startup and it will install again and hopefully that will get your drivers updated, do not worry about deleting the dvd player, it will reinstall all by itself, just have to reboot..thanks
steve
Nov 20, 2008 | Pioneer DVR-107D DVD±RW Burner
Pioneeer DVDRW-K17B ATA Device
hello
i'm having HP PAVILLION DV6000 and OS is VISTA HOME PREMIUM .My problem is that my system does'nt show any dvd drive in MY COMPUTER. I am having PIONEER DVDRW DVR-K17B ATA Device .device manager show a yellow icon and tells that it needs driver. It was working properly before.
thank u in advance
Oct 30, 2008 | Pioneer DVR-107D DVD±RW Burner
Pioneer DVR-107D DVD±RW Burner Logo
447 people viewed this question
Top Pioneer Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Computer Links
David
David
Are you a Pioneer Computer and Internet Expert? Answer questions, earn points and help others
