Cars & Trucks Logo
Anonymous Posted on Mar 20, 2013
2007 f350 cluch fan quit working - F-350 Ford Cars & Trucks
  • Anonymous Mar 20, 2013
    is there a fuse or relay for the fan clutch on 2007 f350
Anonymous
Level 3:
  • Master 937 Answers
  • Posted on Mar 20, 2013
Anonymous
Master
Level 3:
Answers
937
Questions
78
Helped
240023
Points
2950
To remove clutch fan: 1. Remove the fan shroud. Remove the top screws & the two side screws with a socket & ratchet. 2. Remove the top radiator hose by using a screwdriver to loosen the clamps. 3. Hook the ends of the water pump pulley lock on the bolts on the outside of the water pump pulley. 4. Remove the large nut on the fan with the 1-1/16 wrench by turning counter clockwise. 5. Replace the fan by holding the nut perfectly level with the water pump post & start the nut by hand. --------------------------------------------------------------------------------------
FGtech V53
2009 Cummings turbo diesel 6.7 L why does the fan cluch working when I turn on the a/c but turn it off and the fan cluch not working ????? Why..
Temperature not getting hot enough in the engine(bad thermostat), bad engine coolant sensor. Codes help.
F350 heater
Fan is working,did you do any work on cooling and heating.
2007 F350 4x4 regular cab V10 gas guage quit working I had the sending unit and fuel pump changed the fuel guage went to 1/4 and sat there. Any tips? Fuel guage wont work.
I'm assuming this has dual tanks, do you know if it is not working on both tanks ?
Most people would check the circuit for the gauge at the tank. The sending unit grounds the gauge on the dash.
Ford f350 fault codes P2ooZ, P244A, and P245Z
2000 7.3litre F350 auto diesel 4x4. coast cluch circute malfunction. how do i fix it!
2helpful
Need to replace fan cluch
the radiator fan is mounted to the clutch, in other words remove the bolts / nuts that is holding the fan assembly to the water pump usually just four nuts once you pull the fan assembly the part that yo seperated from the water pump is the clutch, now remove the fan blades and mount thm on the new clutch assembly the piece which mounts tt the water ump is the fan clutch
2003 F 550 blower fan quite how do I change it
If it's the blower motor,the vacuum pump has to be moved out of the way(10 mm bolts) . There are three or four 8mm bolts holding the motor in place. make sure you have power and ground to blower motor before replacing.
Top Ford Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
xxxxxx xxx
Are you a Ford Expert? Answer questions, earn points and help others
