Question about Whirlpool GS2SHEXN Side by Side Refrigerator
Freshfood light out along with setting display
Checked switch, socket, connections all ok. No power to light socket?
  • tea642000 Feb 27, 2009
    Come on I am not stupid... of course I tested the bulb. Well, that was no help.
  • 1,800 Answers
Wellreplace the bulb.
Posted on Feb 27, 2009
My tv has no power light. already checked plug and socket and all seems to be fine but still no red light
More information is needed.
Some tv's have a primary power switch along the side or bottom edges (not the small on/off button on the side). This switch is easy to bump when moving the TV. If the switch isn't your problem then you have a bad power supply board inside the TV.
Aug 01, 2016 | Televison & Video
Light bulb replacement doesn't work
Hi Liz,
The reason they want you to disconnect the power is to prevent shock while installing the new bulb. The door switch controls the light in the freshfood so you really do not need to disconnect power, just be careful not to stick your finger into the socket. In most cases the bulb is hard to get securely screwed into the socket. The moisture in the refrigerator causes defect in the metal around the bulb socket and causes the bulb not to make a secure connectioin. So to repair your problem you can first off make sure the bulb is securely screwed into the socket. If it does not work you can check the voltage at the socket for the 110 volts. You can do this with any volt meter if you have one. Sometime the new bulbs can also be bad, its rare but possible. If you are not getting the proper voltage to the socket then you may need a door switch. If you have another light working in the freshfood then the door swith will not be the problem. The door switch is the only power feed swith to the socket, so one of those two will definately fixYa. Good luck and have a great day.
Mike Anderson
Anderson Appliance
(865)945-3808
Oct 28, 2008 | Maytag MZD2766GES Side by Side...
PIXMA MG5350 WILL NOT POWER UP. HAVE CHECKED THE PLUG FUSE.
Unfortunately, I believe the printer will need to be replaced.
If you have verified the power outlet is good, there are not many options. No reset for 'No power'.
Nov 30, 2013 | Office Equipment & Supplies
1999 vw polo driver side reverse light wont turn on. checked the fuse and its good. checked the wire going to socket and it has no power. what do i do next?
You've done most of the work, its tracing back along the socket wire to find a bad connection. Invariably its a bad earth.
Apr 13, 2011 | 1992 Volkswagen Fox
Unplugged tv and when plugged back in doesn't come on
Hello
If you have unpluged the TV from wall socket and it doesn't come On when you plug in back, either its power supply system or its stored memory has the trouble. Look whether the power indicator light coms on. Ensure that the main power ON/OFF switch at the front panel of the TV is ON. If the front panel power switch, control switch of your wall socket, and all the other electrical connections are OK, and still the TV doesn't come ON, surely the power inverter baord has the trouble and must be either repaired or replaced. if the power indicator light comes on, and your TV doesn't come ON by remote POWER ON button, the settigs that were stored has vanished, and resetting it to its original setting is necessary. Follow its manual for 'initial setup" and so all the recomended setting there. OK.
Apr 11, 2011 | Emerson LC320EM9 32 in. LCD HDTV
Left front turn signal does not flash. Left rear OK. socket was corroded so I replaced socket. No flash. Checked wires for voltage, only the parking light connection ever gets anything. Front and rear...
Try pushing the Hazard switch on the Column several times and see if it restores the connection. From what I understand about the Multifunction Turn switch is that some of the contacts share connections with the Hazard Button.
The contacts work on a type of derailer setup and when the contacts get dirty or wear, things stop working. Moving the Hazard switch resets the points and springs each time you go in and out of the Hazard setting.
If your brake light is working you know the wires to the light socket from the brake switch are okay. Probably would not hurt to check brake light switch as it shares the common wire. The split between the left turn and right turn signal wire has to occur, yet the opposite brake light will stay on steady while the other side blinks.
Oct 22, 2010 | Ford E-250 Cars & Trucks
Moved Kenmore dishwasher to new house. Installed it. It will not start. Is there a reset switch? Model 587-1541590. Electrical installation checked OK. Water connection checked OK. Is there something I...
You say "electrical installation checked OK"...is the machine hard wired into a junction box or does it plug into an outlet?
If in a wall socket the new house circut may be on a wall switch which is currently off. If it is plugged into a GFI outlet it may have tripped, Find another power source to wire to, GFI plugs and dishmachines just don't get along, Learned that some time ago!
There may be an issue with your door safety switch on the unit.
Check for voltage where the house wires are wire capped in the machine if hard wired, sometimes twisting those can cause issues.
I doubt your machine has a reset switch but many hobart units have on on the motors.
It really sounds like you have a voltage issue.
Dec 22, 2009 | Kenmore Dishwashers
'05 Chevrolet Malibu - Front Right Blinker is not Working
You need to check for power coming out of the turn signal switch with a test light, or voltmeter. On older Chevys, the R/F turn signal wire is dark blue. Check the color of your wire at the bulb socket, then locate the turn signal switch connector, and probe that color wire with the ignition switch on, and turn signal switch in the right position. If you have power coming out of the T/S switch, you have bad connection, or open circuit between it and the bulb socket.
Sep 01, 2009 | 2005 Chevrolet Malibu
System is lit with no display does not turn on
your set needs to be repaired have a tech look at your set, the power supply is defected along with the audio output.good luck
Jun 03, 2007 | Teac CD-X8 CD Shelf System
Whirlpool GS2SHEXN Side by Side Refrigerator Logo
47 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
