Question about Sony Playstation 3 (PS3) Console
The ps3 turns on but there is no display or sound
I've tryed 2 TVs and 2 HDMI cables and its still the same, just a black screen and no sound. i tryed resetting it but still nothing happens
my friend says its something to do with the power.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 94 Answers
HAVE YOU TRYED THE SETTINGS ON YOUR TV?? SWITCHING IT FROM SCART TO HDMI AND THEN USE THE SOURCE BUTTON ON YOUR TV TO FIND THE DISPLAY FROM YOUR PS3...HOPE THIS WILL HELP YOU...........
Posted on Feb 27, 2009
I have a goodmans TV is having issues, sky box works fine through the hdmi but, ps3 no display or sound through the same port, my ps4 gets pic but no sound, both consoles have been tested on other tvs
1.Put your PS3 on standby.
2. Unplug the power lead.
3. Connect HDMI cable to HDMI out on PS3 and HDMI in on TV
4. Connect PS3 so that the red standby light is showing
5. Hold down the On/Off button until you hear a second beep. The PS3 will try and detect the display output settings on your monitor.
Dec 02, 2015 | PS4 Video Game Consoles & Games
My ps3 console signal isn't working but the sound works but there is no signal! not even a hdmi cable works help!
Try these tips to fix the so-called "black screen of death".
Tip 1: The main reason of HDMI black screen problem due to HDMI cable may be damaged and not properly connected to the PS3 console. Please follow below step to troubleshoot PS3 HDMI cables problem:
1) Restart your PlayStation 3.
2) Look for loose cables.
3) Try to unplug all cables except the power cord, and plug them back in. If you found out that your HDMI cable is damaged, borrow a friends cable and try it. If your friends cable works fine, and the black screen error disappears. Then you can buy a brand new HDMI cable for a replacement.
Tip 2: Only try as last resort. There is a possibility you'll lose all data on your PS3's hard drive. If tip 1 didn't work, you will need to go a step deeper and reset your console. Most PS3 gamers are not aware that Sony actually included a black screen of death troubleshooting method and other HDMI problems in the PS3 manual, you can find it under the troubleshooting section - topic "console reset".
If you do it correctly, the console reset fix will allow you to reset back your PS3 to its default HDMI settings without impacting your gamer profile, and other storage data on the hard drive.
You will need to perform the following steps:
1. Place your PS3 in stand-by mode.
2. Hold down the touch power button until a series of beeps are heard.
3. Listen for one long beep, followed by two shorter beeps.
4. Release the power button.
5. Follow the instructions on screen.
If it works you should be good to go.
May 20, 2012 | Sony Playstation 3 (PS3) Console
Connecting Ps3 with philips tv (full hd) when i got hd cable in, and click to switch so the ps3 uses hd to show things and i than switch over to the channel i plugin the hdmi cabel it gives blac kscreen
If it's the first time using your PS3, use the composite cables that came with it. Turn on the PS3 go to video settings and switch the input to HDMI. After you've switched to HDMI, turn the PS3 off and connect your HDMI cable, go back to video settings and change the resolution to 1080p. If this isn't the first time you've used HDMI for your PS3, make sure your T.V. is on the correct input. If the T.V. is on the correct input, try switching the HDMI cable to a different input. If that doesn't work try using a different HDMI cable, testing different HDMI connections if you're still getting the black screen. If none of those work then it's probably a problem with the PS3, but just to make sure try plugging something else with HDMI to see if that works. If another HDMI device works, then it's your PS3, if it doesn't then it could be a problem with your HDMI connections on the T.V.
May 04, 2011 | Philips 52 In. LCD HDTV
I can hear my Ps3's Sound, when the HDMI cables are connected, and it's on the correct HDMI channel, though i can't see anything, the screen is just black. I have tried holding the power down, until i...
Ok, you are actually holding the power button down for too long. Please do the following to sort out the display on your PS3.
Turn the PS3 off into standby (red light on)
Press and hold the power button. It will beep once when you first press it, then beep again about 5 seconds later. Release the power button when you hear the second beep. The display will now reset and it should detect your HDMI display with no problem.
Hope this helps
Dec 23, 2010 | Video Game Consoles & Games
How do i connect a playstation 3 to a philips tv
The PlayStation 3 (PS3) is a high-definition gaming console that supports both standard AV connections and high-resolution connections (such as HDMI). Most of the older Philips TVs come with a standard AV input. Newer, flat-panel Philips TVs include standard AV inputs and high-resolution inputs. To get the best video quality out of your PS3, using an HDMI connection is recommended if the option is available. The PS3 does not include an HDMI cable, only a standard AV cable
Standard AV
  • 1 Turn off the PS3.
  • 2 Connect the flat end of the PS3 AV cable into the "AV Multi Out" port on the back of the PS3.
  • 3 Connect the "red," "white" and "yellow" prongs on the opposite end of the PS3 AV cable into the corresponding "red," "white" and "yellow" AV inputs on the TV (usually located on the side or in the back).
  • 4 Press the "Source" button on the Philips TV remote.
  • 5 Select the "AV" video display mode.
  • 6 Turn on the PS3. The PS3 logo will appear on the screen.
  • HDMI Connection
    Dec 08, 2010 | Philips Televison & Video
    I AM TRYING TO RECONNECT MY PS3 ON MY LCD TV AFTER 2 WEEK BEEING DISCONNECTED AND IT DOESNT SEEM TO WORK THREW HDMI CABLE! IT SAYS THAT HDMI CABLE WAS DETECTED BUT WHEN I AM ON HDMI CHANNEL ON TV THERE IS...
    I think maybe the following steps might help you out :
    Step 1. Turn the PS3 off into standby (red light on)
    Step 2. Press and hold the power button. It will beep as soon as you press it and then about 5 seconds later it will beep again. Let go of the power button when you hear this second beep.
    Step 3. Wait for your PS3 to start.
    This solution basically resets the video output back to standard definition.
    Hope this helps and thank you for using FixYa
    Aug 26, 2010 | Sony Playstation 3 (PS3) Console
    No picture or sound
    Your display needs to be reset, Turn the ps3 off. Then turn the ps3 back on but continue to press the power button until you hear the beeps then it should work fine :)
    Aug 05, 2009 | Sony Playstation 3 (PS3) Console
    Playstation 3 Does not display on TV using HDMI or regular video cable. senerio: My son hook it up using HDMI Cable to my bedroom sony flat screen tv to watch a blue ray movie and play some games. which...
    I posted to your problem with a similar one. I was able to get my PS3 to work by:
    1.) Powering down both the PS3 and ViewSonic LCD
    2.) Unplugging the power cables to both PS3 and LCD
    3.) Waiting at least 10 or more seconds
    4.) Plugging in the power cables to both PS3 and LCD
    5.) Turning on the ViewSonic LCD
    6.) Turning on the PS3 and holding down the power button until the beep
    After this sequence I heard the bootup audio and the menu appeared on the screen- which detected the HDMI connection to my LCD.
    Very odd.. I've had my PS3 in the same place for months and just today this happened.
    I wanted to post my success. Best of luck!
    Seth
    Dec 26, 2008 | Sony Playstation 3 (PS3) Console
    Sony Playstation 3 (PS3) Console Logo
    61 people viewed this question
    Top Sony Video Game Consoles & Games Experts
    Zhenya Ogorodnikov
    shaun taylor
    marley mcelhinney
    Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
