Question about Clarion ARX6670Z Cassette Player
How do i remove my clarion arx5570r radio from my almera
How do I remove the radio on my almera Nissan car?
which year
looks like all the radios need some slid down each side of the radio
that releases clips to extract the factory radio
Nissan Almera radio fit
Sep 09, 2016 | Nissan Almera Cars & Trucks
Radio will not acceprt code on passport after disconnecting battery, is there a default code? it's a clarion radio model no. CH916 fiied to a 1996 nissan almera. cheers
The only CLARION code available for free (using a serialnumber ) from anywhere on the Internet is if your radio also has a BARCODESERIAL NUMBER beginning with C 7000000 + + ++ on a separate label somewhere on themetal casing. (Note ...not beginning with CL.) If not then it will only be available from your Main Dealer or a Decoding Service oryour local Car Radio / Audio Store who will connect a laptop to read/recode thememory chip (EEPROM) inside your radio
May 05, 2011 | Car Audio & Video
I need the code to unlock a nissan almera radio. The details are as below: Model: PN-2419M Serial No: CL057220140319
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Your radio is made by CLARION and the only CLARION code available for free (using a serial number ) from anywhere on the Internet is if your radio also has a BARCODE SERIAL NUMBER beginning with
C 7000000 + + + + on a label somewhere on the metal casing.
If not then it will only be available from your Main Dealer or a Decoding Service or your local Car Radio / Audio Store who will connect a laptop to read/recode the memory chip (EEPROM)
May 07, 2010 | Car Audio & Video
Nissan Almera Tino 2004 - built-in radio is quiet or screeches
with the proper wire harness you can retrofit any aftermarket indash you want call any car audio shop they will be happy to set you up with exactly what you need
Mar 10, 2010 | Car Audio & Video
Cd palyer won't eject.
nissan comes with a clarion radio that had eject problems. you are probably better off removing it and replacing it with and aftermarket radio.
May 31, 2009 | Car Audio & Video
Cd code
Your radio is made by CLARION and the only CLARION code available for free (using a serial number ) from anywhere on the Internet is if your radio also has a BARCODE SERIAL NUMBER beginning with C7000000 + + + + on a label somewhere on the metal casing.
(There are usually two barcodes on one label. The one required is the lower one )
May 12, 2009 | 2003 Nissan Altima
Clarion ARX6670Z Cassette Player Logo
290 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Marco Avila
Marco Avila
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
