Question about HP Pavilion F1903 19" Flat Panel LCD Monitor
I replaced the 3 capacitors now there's just bright white screen
I had the same problem with vs19e screeen - no life at switchon. I replaced the 3 capacitors but now at switchon there's just aplain bright white screen that doesn't respond either to the keyboard or the control buttons down the side of the monitor. Any ideas ?
  • Lou Ebert May 11, 2010
    Mike, Did you make sure that all connectors were placed back the correct way. Do you have the logic board connected and poweres with 5 volts or 3.3volts from the switchmode supply? The most important thing when taking apart one of these things is to get out a digital cam and take pics of things before pulling loose cables and other things. Do you have a meter DMM ?? I'm lmistyrel @ aol or louie12fix on
    Problem Solver:
  • 17 Answers
Open your monitor back up and look for unplugged connectors, especially the one to the back of the LCD. I had this same problem with a HP F1703. The owner whacked it so hard when the backlight stopped that they dislodged the connector.
Posted on Jun 19, 2009
Tv problem troubleshooting screen all white no picture
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Take it to a repair shop.
Apr 08, 2014 | LG Televison & Video
My HP vs19e monitor takes almost 5 minutes to "wake up". Works fine once running. It never took this long before. Any ideas?
most common problem is bad electrolytic capacitors if unit is a few years old. Take it apart and replace any swollen, ie bulging top of the aluminium can... but may be 'off-value' if not swollen. Any electronics from China will fail within 3 years due to bad electrolytic caps..
Sep 07, 2010 | HP w19 19" LCD Monitor
HP vs19e monitor is blank. Power button is slowly
that is not a monitor problem that is a cpus problem disconnect the signsl cable and connect power cable you will see the post (power on self test) open the cpu draw the ram clean the dust and reinstall the problem will solved
Feb 26, 2010 | HP vs19 (Silver) 19" LCD Monitor
I want to replace the power switch board on my hp vs19e monitor.
About your only hope for getting a replacement switch is to buy a "Parts Only" monitor off of EBay and carefully remove the switch. This one is tricky it's attached to the front bezel as you've likely found out. When you disassemble the monitor, lay it face down and remove the bac plastic then remove the 4 screws holding the button board on then take the rest apart. That's the safest way.
Mar 28, 2009 | HP Pavilion F1903 19" Flat Panel LCD...
Hp vs19e just died
those capacitors are polarized they have a neg and a pos side were they seated correctly? could also be transistors going bad but my bet is some cap was in backwards.
Mar 22, 2009 | HP w19 19" LCD Monitor
No Picture On Screen
change the 33uf 35v at the vertical filter
Mar 10, 2009 | Televison & Video
Dark picture
you probably have a bad capacitor on the invertor board. try shining a flashlight into it to see if you can see anything. if capacitors are good, you might have some burnt out backlight bulbs. i just had the same problem, replaced the capacitors but messed something else up on the way i guess cause now all i have is a bright white screen with a few colors here and there.
Aug 30, 2008 | HP Vs17 17" LCD Flat Panel Monitor
Screen displaying a thin white very bright horizontal line.... plz help
problem in vertical section.
1. Solder the vertical ic
2. vertical ic supply capacitor problen.
3. dry points in neck board.
Aug 08, 2008 | LG Studioworks 45 14" CRT Monitor
HP Pavilion F1903 19" Flat Panel LCD Monitor Logo
288 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
