Question about LG WM-2277HW Front Load Washer
LG Washing machine - WM14225FD. Error LE showing
Starts fine then within a few minutes of wash it grinds to a noisey halt then LE flashes. HELP!
  • 1 more comment
  • helen_grove Feb 27, 2009
    Will do what you have said above and will feedback..........fingers crossed.
    Model No. is WM14225FD in answer to MNTECH question.
    Fixer 444, it has been turned off for about 1 hour and I have just checked all wires and all seem fine and tight. I have read numerous reasons as to what the issue 'could be' - it may because there was not a big enough load put in but from comments I have read and investigated it could be the 'motor servo control' or in my LG manual it states LE = over load in motor and when I called LG who were useless they said it could be the hall sensor? LG have been really unhelpful and want to charge me £70 call out charge......this has been going on now for over 5 weeks. HELP
  • Carl Schulzetenberg
    Carl Schulzetenberg May 11, 2010
    Could you confirm model number. (usually found on sticker just inside door)
  • 1,543 Answers
I'm sorry I only have service info on US market models, but this info might help.
LE codes are extensively covered in past Fix-Ya solutions, but are generally caused by only a handful of things. 1. the " Load Error " can be a very off balanced load. 2. excessive use of soap leads to too much suds, and thus drag on the inner tub. (use 1 tablespoon of HE soap max. per load) or 3. the Hall sensor (part number 6501KW2001A) has failed. The hall sensor is rather easy to replace, and is covered by a seven year part warranty. Take the back cover off. Take the big nut off and remove the motor rotor. Remove the bolts holding the motor windings. Remove the electric plug on the sensor and unclip it from the motor winding. Snap new sensor on and reassemble. Usually takes under a half hour. On a difficulty scale of 1 - 10, it might rate a 4. This should be a Fix-Ya for your machine, and at basically no cost!
In the US, find a service provider using your zip code at http://us.lgservice.com/index_b2c.jsp or call LG at 800-243-0000
Posted on Feb 28, 2009
  • 8 Answers
I tried what I'd seen written elsewhere - my LE error came after I turned the drum as I was unloading it, which caused the control panel to light up. This confused the brain.
I unplugged it for 10 minutes, then started a Rinse & Spin cycle with No Spin selected for the Spin Speed. After this completed, I was able to use the washer as normal.
Location off brushes in washing machine
could you show a picture please
Posted on Dec 14, 2009
    Scholar:
  • 106 Answers
Press "end of cycle". Plug off the wall. Code can be an indication of several issues. The most common cause is over-sudsing in the machine. Overloading the wash with too much laundry may also cause the LE error code. Lastly, a breakdown in the signal between the microprocessor and the motor may cause that error code. This can occur if there is a loose wire, see that all wires are tightened..........
Posted on Feb 27, 2009
Washer starts then after few minutes stops and beeps with LE flashing. What does this mean?
LE = Load Error. If you do not have an unusually heavy or unbalanced load, replace the HALL sensor on the motor. Remove back access panel, remove bolt from center of motor. Remove rotor. Remove bolts holding motor coils to machine. Unplug wires. Un-clip sensor, replace with new sensor, and re-assemble. This is a rather easy repair.
Feb 13, 2011 | LG WD-1045FH Front Load Washer
Dishwashing cycle starts for about 3 minutes then flashing LE light comes on and the machine stops. Why?
Display Condition LE = Motor Error
Possible Cause For Error Occurrence:
Wiring connection is OK?
The Impeller of Washing Pump is locked.
The rotor of Washing Motor is locked.
The Blade is locked.
Remedy:
Check the wiring connection.
Replace the cause of restriction.
Replace the Washing Motor.
Replace the PCB.
Try the following steps:
Unplug the washing machine if you see an LE error on the two-digit display electronic readout. This error indicates a miscommunication between the control panel and wash motor.
Press and hold the "Start/Pause" button on the front panel for five seconds.
Plug the LG dishwasher back in.
Run a cycle. The LE code will clear.
Aug 31, 2010 | LG 24 in. LDF 7811 Stainless Steel...
LG WM14225fd will not spin and le code
(Load Error) can be an unbalanced load. Or, excessive use of soap causing too much suds, which can drag on the inner tub. Add only 1 tablespoon of HE soap max. per load.
Or maybe your Hall sensor died the part number is 6501KW2001A
Mar 18, 2010 | Washing Machines
My LG washer is flashing LE and won't contiue the
First try unplugging the machine for a few minutes and then retry a cycle. If you still get the LE error:
The Hall sensor (part number 6501KW2001A) has failed. The hall sensor is rather easy to replace, and is covered by a seven year part warranty (in the US). Take the back cover off. Take the big nut off and remove the motor rotor. Remove the bolts holding the motor windings. Remove the electric plug on the sensor and unclip it from the motor winding. Snap new sensor on and reassemble. Usually takes under a half hour. On a difficulty scale of 1 - 10, it might rate a 4. This should be a Fix-Ya for your machine, and at basically no cost!
Sep 06, 2009 | Washing Machines
My LG washing machine will not run through washing cycle
Locked motor error (LE)
* The connector (3-pin, male, white) in the motor harness is not connected to the connector (3-pin, female, white) of stator assembly
* The electrical contact between the connectores, (3-pin, male, white) in the motor harness and 4-pin, female, white connector in the main PWB assembly is bad or unstable. Or the motor harness between the sator assembly and main PWB assembly is cut (open circuit).
* The hall sensor is out of order/defective.
***. If the hall sensor is defective, replace the entire motor.
Jul 13, 2009 | LG WM1814CW Front Load Washer
Problem with LG washing machine Model number wm1480fhd. The machine drum reluctantly turns and in about a few minutes it displays error code LE (flashing).
LE error code: This indicates a locked motor condition. Please check the following conditions. Large loads of laundry can put a strain on the motor causing the LE error code. Try removing some clothing and restart. Excessive suds can cause the LE error code. Make sure the customer is using an HE (High Efficiency) detergent. They should decrease the amount of detergent until the machine washes without suds. A few bubbles can be expected. Areas that have �soft� water will usually need to use less detergent. If you suspect that excessive suds are the problem, let the machine stand for 30 min (motor cool down) and then run a rinse and spin cycle before restarting the load. If these directions are followed and the code persists, the machine will likely need service. .
Aug 22, 2008 | LG Washing Machines
Lg washer code le
LE= That is a water inlet error
Correct water level (246) is not reached within 8 minutes
after water is supplied or it does not reach the preset water
level within 25 minutes
Check you water supply lines and make sure the screens on the valves are not clogged
Jul 09, 2008 | LG Washing Machines
LE Code on control panel
Dec 31, 2007 | Washing Machines
Error message when trying to wash
Unplug the machine and spun the drum few times by hand, wait 10-15 min. and plug it back. Good luck!
Aug 06, 2007 | LG WM-2077C Front Load Washer
LG WM-2277HW Front Load Washer Logo
1,972 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
