Question about Apple iMac G5 Desktop
COLOR VERTICAL LINES.
WHEN I SIGN ON MY MAC G5, I GET ALL THESE LINES. HELP!!!
    President:
  • 2,653 Answers
Vertical lines are problems that usually arise from either a bad lcd or video card ( GPU).
There is no fix, other than replacing the bad part.
If you want to do it yourself I've got service manuals, but unless you have experience it's no walk in the park.
Is it still under warranty?
You might be able to get an extended warranty through AppleCare.
Posted on Feb 28, 2009
2 Suggested Answers
graysand
  • 558 Answers
SOURCE: COLOR VERTICAL LINES.
You have a bad lcd.No need to reinstall you os.This is a known issue with some macs.I just completed 30 repairs on the same brand.Apple can't realy reveal a fix,however they will replace the logicboard,the lcd and the lcd cable if you are still under warranty.
Good luck
Posted on Sep 12, 2009
Lines on imac g5 screen
For more help follow the Apple iMac g5 line on screen discussion over here https://discussions.apple.com/thread/4929409
and if isn't helpful then take some guidance over it Mac Tech Support .
Apr 16, 2014 | Apple iMac G5 Desktop
About 6 months ago there were 2 colored vertical lines on my desktop screen. I've been getting more lines every 2 or 3 weeks and now have a total of 18. The nearest Apple store said they can fix it no...
It should not affect the data on the hard drive but with all repairs such as this it always worth making sure you have your hard drive backed up. I had a similar problem with a imac a couple of years ago and the hard drive was fine when it came back. Hope this helps.
Nov 14, 2010 | Apple iMac G5 Desktop
Shortly after the warranty was up the first vertical yellow line appeared and now, about 1 months later another vertical line appeared. He's not happy to hear it only gets worse and apple won't do anything...
Although its possible for graphics processor failures to cause vertical lines, they more often create horizontal ones. The first culprit to check for a vertical line problem is the LVDS cable, which it turns out is not that expensive a part (not counting all the work there is in getting to it). To verify this, I would gently flex the cable while the iMac is open and operating, and see if the lines get better or worse. It may also be that the cable itself is fine and just a few of the connector pins at either end are intermittent, in which case it just needs reseating.
Oct 18, 2010 | Apple iMac G5 Desktop
A fine vertical blue line running through imac screen
How long is a piece of string? is the kind of question you've asked. I've a sneaking suspicion you'll get sick and tired of it before it finally goes.
Jun 03, 2010 | Apple iMac G5 Desktop
Thin yellow vertical line
Linear defects of this sort can be caused by a faulty display cable, a faulty LCD panel, or a faulty connector between the two. Much less likely is a problem with your graphic processor, since the line is static in appearance and position. Unless your Mac guy has lots of spare parts hanging around, I would suggest you replace the cable first, as it is the least expensive fix. If that doesn't do the job, then the display panel must be replaced.
Sep 18, 2009 | Apple iMac G5 Desktop
Most likely its a Hardware failure. To reaffirm... insert you install cd that came with your computer. restart computer and hold down "c" until you get the the install screen. Are you still getting vertical lines? You probably still are.. there can be 2 culprits. 1: logic board or video card. To figure it out which is it, hook an external monitor to it. If vertical lines then its the Logic board. If not then its the video card. Now for some odd reason the lines are not shown when you boot to cd, it may be an OS issue. another thing you can try. turn computer on and hold down Apple+option+P+R and let go after 3 chimes. ya never know. good luck!
Apr 05, 2009 | Apple iMac G4 Desktop
White vertical line going through my IMAC screen
The line is an indication that there is a failure in the display, most times the failure will be limited to the line you see but occasionally the problem will spread, causing more lines. the only way to fix it is to have the display replaced.
Dec 15, 2008 | Apple iMac G5 Desktop
Screen Changes and Comupter freezes
It may be possible that the power supply, display and or logicbpard may be having issues. Apple recommends resetting the pram and nvram. If issue persists reset SMU. YOur machine is 6 months outside of the original warranty, but if you purchased the 3 year extension plan, you may want to take action on it.
http://search.info.apple.com/index.html?q=imac%20g5%20reset%20pram&lr=lang_en&search=Go&type=
http://search.info.apple.com/index.html?q=imac+g5+reset+smu&type=&search=Search&lr=lang_en&search=Go
Keep me posted.
Nov 10, 2007 | Apple iMac G5 Desktop
Apple iMac G5 Desktop Logo
878 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
