Question about Lexmark E250dn Laser Printer
Yellow toner light is blinking
Just replaced toner cartridge two weeks and I don't have the manual to troubleshoot
On this printer it can also indicate the developer needs to be replaced
Posted on Jun 24, 2009
  • Lexmark Master
  • 4,338 Answers
Here is the manual; led status diagosing starts on page 13:
http://www.lexmark.com/publications/pdfs/2007/e250/EN/ABJug.pdf
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Apr 10, 2009
Yellow light is blinking?
If the bottom amber colored light is blinking, the imaging drum needs replaced.
If the yellow print cartridge light is blinking, then replace the print cartridge (yellow toner).
Mar 24, 2014 | HP c9705a - Color Laser Jet 2500l Printer
Hello sir my brother tn-3250 laser toner blinking yellow light
Toner Blinking yellow LED indicates that the toner cartridge is nearly empty. Buy a new toner cartridge or refill the cartridge. Refilling the TN cartridges is quite simple and you can do it yourself.
It is a very simple process. Please refer to this video.
Let me know if any further clarification/ assistance is required.
Good Luck!
Appreciate generously, if the solution could have been of any help!
CreativeTECH
Jan 17, 2011 | Brother HL-5250dnt Laser Printer
The yellow spot is blinking and the black dot is
the solid light means toner is low. Blinking usually means either the cartridge is out of toner or the cartridge is having a technical problem. If you pull the yellow toner cartridge and put it back in with no change in result, you will need to replace the yellow toner cartidge
Nov 19, 2009 | HP LaserJet 1500L Printer
Replacing the toner cartridge
No it isn't, toner does not distribute evenly from the cartridge, when it says it is out you often can shake it and get another few weeks out of it. However, when you get to the point your shaking after every job, stop. I have been told the printer can be damaged by running a cartridge bone dry.
Nov 13, 2009 | Brother HL-2170W Laser Printer
Blinking red and yellow light
Generally if both the (red) alarm LED and the (yellow) data LED are both blinking, it is an indication that the tone cartridge needs to be replaced. You should be close to out of cartridge.
Jan 12, 2009 | Brother HL 1440 Laser Printer
Hp lj 2500 flashing yellow light
The yellow-print-cartridge
light is blinking, and the
printer stops printing.
 The print cartridge is
empty or missing.
 The printer cannot
detect the print
cartridge correctly.
1. Reinsert or replace the print cartridge.
2. If the print-cartridge light is still blinking but the
Attention light is not on, turn the printer off and
then back on.
3. If the problem persists, repeat the above steps
with yellow print cartridges until the error is
resolved.
4. If the problem persists, replace the printcartridge
E-label reader, which is located on the
pressure assembly of the print-cartridge
carousel.
Jan 09, 2009 | HP LaserJet 2500L Printer
Installing new black print cartridge
Manually Removing Toner for magicolor 2400W
1.  Hold down the Cancel button for 10 seconds or longer.
2.  With the Cancel button still held down, also simultaneously hold down the Rotate Toner button for 10 seconds or longer.
3.  When all LED indicators are blinking rapidly, release both the Cancel and Rotate Toner buttons.
4.  Then hold down the Rotate Toner button again for another 10 seconds or longer.
5.  The Cyan toner cartridge moves into the proper position, so it can be removed.
6.  Remove and/or replace the Toner Cartridge if necessary.
7.  Open and close the covers. Each time you do this, another toner cartridge moves into the proper position, so it can be removed and/or replaced (in this order: cyan, black, yellow, magenta).
The link is located here
Oct 21, 2007 | Minolta magicolor 2400W Laser Printer
Toner light won't stop blinking
Try resetting it, open front cover hold down silver button, all lights should flash rotatingly, when stopped turn off and on and close door.
Oct 09, 2007 | Lexmark E330 Laser Printer
Brother HL-1440
(blinking every 5 seconds) Toner Low Indicates that the toner cartridge is nearly empty. Purchase a new toner and have it ready for when Toner Empty is indicated. (solid) Toner Empty Replace the toner cartridge with a new one. User's Manual is available at the following location: http://www.brother-usa.com/Data/Documentation/Printer/User/UM_HL1440_1450_1470N.pdf Hope this helps.
Aug 22, 2007 | Brother HL 1440 Laser Printer
Brother HL-1440/ flashing alarm light and flashing yellow data light
Lexmark E250dn Laser Printer Logo
478 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
