Question about Dell AS500 Sound Bar Computer Speakers
Is there a power cord that i have to connect to my soundbar to this little short wire an if i have to connect to the tower how its to short
Yes there should be an adapter that it goes into. One cable with green connector goes into the back of PC the other short connecter into the ac adapter model no 12150bs.
Posted on Mar 14, 2009
I need a power supply cord for soundbar #psb3713-b
I could not find one anywhere. I finally tried the power cord from my Craig soundbar model# CHT923 and it works fine. It is probably easier to find this power adapter.
Mar 11, 2015 | Proscan PSB3713 37-Inch Bluetooth Sound...
How to repair Computer Fan
<p>1. Remove the mini-tower computer cord and unplug the power. Disconnect the cable from the back of the computer for a note in which they were set to be fast to restore.<br /> <p><br /> <p>2. Unplug the connector on the back of the computer. Tighten the screws on the back of the computer, back up the side with a screwdriver. Slide the computer case and put it out of your way.<br /> <p><br /> <p>3. Locate the fan in the box near the back and then connect the power cord where it is on the motherboard. Unplug the fan motherboard manual. Remove the four screws holding the fan on the bottom of the box with a screwdriver to secure.<br /> <p><br /> <p>4. Remove the PC case fan and set aside. Turn the fan of the new mini-tower in the back of the cabinet with screws and plugs wire connector on the motherboard.<br /> <p><br /> <p>5. Place the rear plate side of the computer and secure it with screws. Connect the power cord to power on the back of the case and connect the cable to the computer case.<br /> <p><br /> <p>6. Connect the power cable from the mini-tower outlet and turn on the computer.<br />
on Jun 21, 2011 | Computers & Internet
Connect an active soundbar to a receiver
What if the soundbar is Bluetooth? Will I still be able to use that function and connect the active soundbar to the tv (Bluetooth) and connect the av receiver for other surround sound speakers? (they are pre-wired in the walls in the apartment I moved into)
Jan 08, 2013 | Audio Players & Recorders
My tower fan(not a lasko) but very similar cuts off when i put it to rotate.
Sounds like a short in the wire. Return it before it burns your house down.
Oct 10, 2012 | Lasko 2554 Tower Fan
How to wire a compressor to switch
Your pressure switch should have four wire attachment screws on the switch tower and two ground points on the metal frame/base. Most switches label the four screws in pairs as LINE and MOTOR. If they're not labeled, use an ohm meter to make sure you don't connect the cord to a direct short. Usually the bottom two are for the LINE or power cord connection. The upper two are for the cord going to the MOTOR. There should be two screws on the metal base for the ground lines or at least two holes for the screws, some switches come without the screws. Make sure you ground the unit as compressing air creats a lot of static electricity.
Aug 20, 2012 | Coleman Powermate 27 Gallon Air Compressor
16" Vintage Stand Fan not a tower type Model #
first check AC power cord for cutoff wire inside. if its ok, carefully remove back motor cover and find FUSIBLE RESISTOR, its covered by insulator, replace it or connect two legs together or jumper-ed with wire, covered it with insulator like wire tape for short circuit purpose, then try it.
Aug 10, 2011 | Dryers
When we plug in the dishwasher da4441s it short circuits.
The short circuit may be located in the junction box from which the dishwasher gets power.
Its probably bare wires touching under the "skirts" of two wire nuts.
If no power problems, then the dishwasher itself has a short. In this case, start locating the short in the
little box to which the power cord is connected - these connections will short if one of the
hot wires, or a hot wire spade lug is touching a frame ground (all components of the frame are grounded).
A third (remote) possibility is a wiring mistake - the dishwasher hot & neutral could be connected, causing a dead short.
May 13, 2011 | Dishwashers
I dont know where the Dell 725 Printer Power Cord goes into the tower Which outlet on the tower
The Dell 725 printer power cord does NOT plug in to the tower. The Video Cable, on the other hand, plugs in to the tower's video output. Look for a connector like the one from the printer (often USB these days) to plug it in to the computer. There was a diagram that came with the computer that showed how to do all the connections, and the Power Cord does NOT plug in to the tower. USB connections are in various locations on your computer's tower, in the back and sometimes in the front too.
Nov 09, 2009 | Dell 725 InkJet Printer
My tower will not turn on
It sounds as if your power supply is having issues, I would recommend replacing it.  If your good with computers, you can test the power supply: 1. Open the computer tower. 2. Find the main plug which runs from the power supply to the motherboard. 3. There should be 16 wires. 4. Find the green wire, short it to the black wire with a paper clip. 5. If the computer seems to turn on, its your motherboard having issues and you will probably need a new computer.  If it does not turn on, your power supply has failed, and you need to replace it.
I hope this helps!
Apr 03, 2009 | Acer Aspire L100 PC Desktop
Dell AS500 Sound Bar Computer Speakers Logo
982 people viewed this question
Top Dell Audio Players & Recorders Experts
jairo sanchez
Greg Cann
Greg Cann
Are you a Dell Audio Player and Recorder Expert? Answer questions, earn points and help others
