Question about kawasaki Full Suspension Mountain Bike Men
How do i adjust the mix on my vn750 vulcan
My vn750 is running rich and i have trouble starting it and i get some back firing and popping when it does go how do i adjust the mix any help would be great
  • 24 Answers
Screws under lead caps that have to be dug out, but join us at yahoo groups vn750.
Posted on Sep 07, 2009
Kawasaki wiring
check your kick stand switch
Jul 11, 2014 | 1993 kawasaki VN 750 Vulcan
Download manual 1985 kawasaki vulcan 700
http://www.tocmanufacturing.com/Files%20for%20Download/VN750%20Manual%20and%20Parts.pdf
This link is for the Vn750 other than the 700 being smaller cc's everything is the same service specs.
free download.
Oct 27, 2012 | Motorcycles
My 1400 intruder pops and back fires
I think maddogcycle is right. One cylinder is running rich and the other running lean. It seems as though they have not been balanced properly and the mixture not accurately adjusted. The settings on these carburettors are critical and must be adjusted with the proper gauges. I'd advise you to have the carbs cleaned and adjusted and tuned to the engine for balance of inducted air flow and fuel/air ratio (mixture)
Apr 09, 2010 | 1996 Suzuki VS 1400 Intruder
Chevy V8 Hei dist. starts and runs fine at idle at higher rpm starts minimal back firing? When on gas hard and let off pedal big back fire? Could problem be bad stator/igniton part that fires off of star...
Yes...timing. Adjust the distributor...back it off a little and set the timing....also check your carb setting for rich/lean mix....air mix will cause this also.
What have you done to the system to cause this or were you trying to adjust something?
Oct 09, 2009 | 1983 Chevrolet Silverado
Charging issue with vn750 1986
I need more details. Is it quitting because it fails to get spark because it is not charging? Or are the carburators gummed up enough and it runs out of gas? Has this bike been setting? If you are able to run engine with a battery power supply on it then it wouls seem to me a charging issue, but if it is stalling and only runs with the choke out or partially out, clean the carbs.
Aug 09, 2009 | 1992 kawasaki VN 750 Vulcan
My vulcan 1500 1997 back fire somme time wy
lean gas mixture. or the valve timing is off, but probably both. A lean mix will run really hot and allow for secondary combustion in the pipes (backfire) when the valves let even a bit of uncombusted gas through. My guess is that the bike hasn't had the carbs cleaned out thoroughly in a while. Run a half can of Sea Foam with your full tank of gas to help clean out the carbs, but really you should take them apart and dip them to clean everything out. Also you could adjust your pilot screw settings to make it run a bit more rich, but then you are just compensating for the dirty carbs. That's just my guess.
Jul 22, 2009 | kawasaki Full Suspension Mountain Bike Men
Whats the adjustments on a 1996 kawasaki vulcan 800 carburetor. the bike seems to blacken the plugs and run sluggish. it was rejetted however im not sure if the carb was adjusted for the new jets. im...
oem specs run lean if you rejetted and plugs are blacken running rich try air screw first alittle at a time (replace plugs) keep rechecking plugs as you go same diff. if you adjust fuel screw
Jul 13, 2009 | 1996 kawasaki VN 800 A Vulcan
Back firing & cutting out
If a stock intruder is running rich it must have a restriction in the air filter or a problem with the carbs. These bike are always way too lean from the factory. Check to make sure the filters are not plugged up. Also if it is truly rich it will start and run well without the choke on. You may have inricheners that need adjusted.
Feb 26, 2009 | 1996 Suzuki VS 1400 Intruder
kawasaki Full Suspension Mountain Bike Men Logo
93 people viewed this question
Top kawasaki Sport & Outdoor - Others Experts
Wayne McNeil
Phillip Edwin
Level 1 Expert
Are you a kawasaki Sport and Outdoor - Other Expert? Answer questions, earn points and help others
