Question about Xerox Office Equipment & Supplies
Xerox wkctr 35 toner fault 9-567
Replaced complete developer assembly and did not solve problem.
  • 1 more comment
  • joe9635 Feb 27, 2009
    code# is mistaken the code is 09-597.00 Toner control sensor failure. Thank you for responding.
  • joe9635 Mar 02, 2009
    Now we get 9-361 after changing whole developer housing.
  • Everett Lin May 11, 2010
    Hello sir; Just want to make sure the error code you given us is correct, 9-567 we don't have,either 9-597 or 9-560,
    President:
  • Xerox Master
  • 990 Answers
Hi sir; Just need to replace toner sensor should be take care your problem, if you solved the problem ,don't forget to give me a rating, thank you !
Posted on Feb 28, 2009
Xerox phaser 6360 smearing magenta toner only
that's the developer assembly that has gone bad. If you're using 3rd party toner it wears down a lot quicker. You'll need to replace the magenta developer unit, part number is 848K03850.
http://www.iteminconline.com/848k03850_848k03850-xerox-6360-developer-assembly-magenta-oem-new-genuine.htm
Feb 09, 2016 | Xerox Office Equipment & Supplies
Xerox 3030 (engineering copier)-- "Toner Fault. Call for assistance" is on the little display screen. Can I easily fix this myself?
I expect you've probably got this fixed by now? In my experience people who own these machines want them working all the time. This error code problem can be over concentrated or under concentrated developer. Possibly needs developer changing, or the DEV sensor could be U/S. Good luck.
Dec 05, 2014 | Xerox Office Equipment & Supplies
Xerox workcenter7346 has fault code 009-390
009-390= IBT belt home position sensor/patch. After examing ibt belt assembly and cleaning patch and sesor, noticed that the magenta developer unit was not in proper position, this was not allowing the ibt unit to turn. Re-positioned developer unit into proper position, installed ibt unit, this cleared up the problem and machine is running fine.
Dec 11, 2012 | Xerox WorkCentreR Pro 7346 Black Toner...
My sharp xerox machine AR-5516 is bleaking a man near toner signal point. why is this bleking? Kindly solve my problem.
The blinking man who we refer to as Mr Bill is a "time for maintenance light". Just ignore it, the machine will keep working.
Aug 21, 2011 | Sharp AR-5320 Black and White Copier
Error 000020-000 in photocopier iR3025/3028
These is error code related to toner station trouble. It could be toner sensor fault, broken parts in toner hopper,...
the book says:
E020 The path between the sub hopper and the developing assembly is clogged with toner.
0000 The developing assembly toner sensor detects the
absence of toner, while the sub hopper toner
sensor detects the presence of toner. With the
developing clutch turned on, the hopper
feedscrew motor is rotated for 1 sec intermittently
194 times; still, the developing assembly toner
sensor does not detect the presence of toner.
Replace the developing assembly toner sensor.
Replace the sub hopper toner sensor. Replace the DC
control PCB
Aug 12, 2010 | Canon iR 2016i Black and White Copier
Plesae describe the error code E00020
E020 There is a fault associated with the drum/developer.
For the first 2 digits of detail code xx12 through xxD0,
xx=01: Y
xx=02: M
xx=03: C
xx=04: Bk
xx20
xx24
xx25
xx30
xx34
xx35
xx40
xx50
The fault can occur as when a new drum
unit has been fitted. It is detected in about
90 to 120 sec after idle rotation of the developing
assembly.
unit has been fitted. It is detected during
ATR control or in about 150 sec after idle
rotation of the developing assembly.
assembly.
unit has been fitted. It is detached during
assembly.
The fault occurs when an image is being
formed. It is detected when toner supply
operation is started.
There is a fault/open circuit in
the ATR sensor. The drum unit
is not fitted normally, or is
faulty.
the SALT sensor.
the SALT sensor.
The ITB has deteriorated.
the ATR sensor. The setting of
the ATR sensor computation
value is wrong. The drum unit is
not fitted properly, or is faulty.
The sample image fails to be
drawn in ATR control. There is
a fault/open circuit in the SALT
sensor. The drum unit is faulty.
the SALT sensor.
The ATR sensor communication
value is faulty. There is a fault/
open circuit in the ATR sensor.
The drum unit has been fitted
improperly. (The machine cannot
detect the drum unit). The
The developer concentration
computation value is faulty (set
when a new drum unit is fitted).
xx60
xx70
xx80
xx81
xxA0
xxB0
xxC0
xxD0
target value is faulty (set when a
new drum is fitted; the value is
extremely small).
new drum unit is fitted; the
value is extremely small).
The actual value is considerably
high in relation to the ITB surface
reflectance when a new
drum unit is fitted. The SALT
sensor is faulty.
drum is fitted.
The measured value of the developer
concentration is considerably
low. The ATR sensor is
faulty. The SALT sensor is
faulty. The ITB is soiled.
The drum unit is approaching
the end of its life and is causing
the T/D ratio to drop. The ATR
sensor has an open circuit.
The supply of toner for the toner
container to the developing assembly
is faulty. The developing
assembly is supplied with toner
excessively. The ATR sensor has
an open circuit.
has failed. The toner
cartridge motor fails to rotate.
The toner container is empty.
The toner supply mouth of the
drum unit is damaged. The ATR
code xxEE,
xx=00: fault in access to drum
unit
xx=01: fault in access to toner
container
The fault occurs while ATR control is being
executed.
executed.
formed.
formed and, in addition, when the T/D ratio
drops while 20 prints are being made
continuously. It is detected when toner
supply operation is started.
Aug 04, 2010 | Canon imageRUNNER C3200 Copier
Xerox phaser 6360 is ghosting. replaced transfer roller but no help thanks Bruce
Most common cause of this is the use of 3rd party toner. This isnt true for all printers but some of the newer Xerox are notorious for it as the 3rd party toners are not produced to the exact specs as xerox. If your not using genuin Xerox toner you have your cause.
If your mechanicaly savy you can completely dissasemble most of the printer in order to clean out the toner. Then start over with new Xerox toner cartridges. I have had to service 2 of these printers in this way, and both were like new when done.
Dec 16, 2009 | Xerox Phaser 6360 Laser Printer
Phaser 6350 flooded with magenta toner
Problem developers start leaking toner. The problem is that some times the toner spuills into developers below it and damaging them. The problem may appear as a grinding noise that may indicate a developer gear/motor problem, when in fact its a bad developer that is not running smoothly. It may be expensive, and you may have to replace ALL the Developers.
Jun 15, 2009 | Xerox Phaser 6350/YDT Laser Printer
Prints aren't plain, it have some texture like crayon
its problem of toner
its of good quality
and also check proper supply of toner into develper assembly
trying to add some extra ink directly in developer assembly
if problem solve
check
cartridge motor running
and supplying toner proeprly
May 24, 2009 | Xerox DocuColor 12 Color Copier
We have the Xerox WorkCentre 665 and it's printing so light.
You can pull the developer houseing out. Wipe the mag roll, so it has a shinny area.
in a small area. Enter the developer housing in again.
Try running a copy.
Remove the developer housing and see if the mag roll moved. If it did not and it is still shinny and clean, this is the problem with light copies. Possibley bad developer housing or ciruit boards. Both are costly.
One other area is, if the developer housing is working, see what brand of toner you are using on this machine?
If it is a brand other than Xerox, dump it all out.
The developer housing has to be completely emptied.
Enter the Xerox toner and see how it works.
Also, a bad Transfer corotron can cause this problem, it may be arching in the blocks.
If all else fails, call Xerox for this major repair.
Feb 23, 2009 | Xerox WorkCentre Pro 785 Plain Paper Laser...
188 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
