Question about Toshiba Satellite M65-S9063 PC Notebook
Laptop screen is black
Laptop starts up and runs but screen is black. Seem like trouble with the little button that turns off monitor when you close laptop. If I push and release this button while the laptop is on the screen flashes and for a split second you see the desktop screen. Is it possible to get to that button and see if it just needs cleaned or replaced?
  • 1,800 Answers
Yes u shud deal with button just clean it it is a monitor sensor.
Posted on Feb 27, 2009
Black screen on dell but i can see a little
Try connecting first to a standard monitor. This should work. Likely the inverter module ( part that provides the light behind your lcd) has broken down. Dell should be able to provide you with one!
Apr 05, 2013 | Dell Computers & Internet
I have a dell m1730 laptop. I turned it off last night before bed, when i got home from doing my running around this afternoon i went to turn on the laptop. The computer turned on, the keyboard lit up,...
Have you tried going to the BIOS? If you can see the BIOS screen there's video and the hard drive could be the issue. If you can't see anything but black screen you probably need to replace screen and or video invertor board.
Jun 28, 2017 | Dell XPS M1730 Laptop
Last night my Toshiba's screen turned white with a few red and yellow stripped lines. Than the white filled in with black over night. Now the screen is blank, the power button won't turn it off only on....
HI There,
I'm a pro laptop repair/rebuild tech. If you own an external regular computer monitor or even a friend who does, connect the laptop to the external monitor and power it on. Your Toshiba will have an F key with a little icon figure of a monitor on it. Hold down the fn key and press that F key to transfer the laptop display signal to the external monitor.
If the external monitor shows your normal laptop screen as it would usually display, you have a bad laptop LCD and some other (as yet) undetermined problem. If the external monitor is black just like the laptop, then yout video/graphics card has failed and since it's closely associated with power up issues at the beginning of the startup cycle, is interfering with the laptop's ability to run the operating system because it never gets that far.
From what you've described, you're going to have a choice of sending the laptop to a motherboard repair service (if you go to eBay and type "Motherboard Repair Laptop" in the search window you'll see many choices) for a price between $100 and $200 or need to start shopping for new laptop.
Remember, "don't shoot the messenger"!
Good Luck
Aug 05, 2010 | Toshiba PSAFGU-058002 Notebook
Monitor receiving signal, but no image
Hello!
I see many monitor with that trouble.
When you turn on comp., you can have a picture on monitor about 10-30 min. and that go in black screen, or If you change resolution again go in black screen.
You must repair monitor or bay another.
Nov 02, 2009 | Acer AL2416W Monitor
Check signal cable
Turn off the monitor first.
Hold down Function button and click F8 key to tell the laptop to send signal to the monitor.
Apr 20, 2017 | Samsung SyncMaster 2233BW 22" LCD Monitor
My Screen might be out??
dear ...,
when switching on te laptop, does it make noises, does the fan run, the CD/DVD-drive
LED shows green light and the harddisk rattle little bit? - good for you if it does, as the system still boots up !
to check if the LCD screen is broke and not the graphics card malfunctioning:
hook it up to an external monitor (one usually used with desktop PCs)
when laptop is switched off, using the 3-pin input in the back or to the right side of your laptop, and make sure the external monitor's power cord is properly fused...
Now switch on the external monitor first and then your machine again, and wait for the laptop boot messages on the monitor!
see anything? if yes the laptop screen is broke and needs to be replaced.
If still the external monitor stays black the onboard graphics card is up in smoke and you're in big trouble then.
Good luck finding out!
Oct 22, 2008 | Toshiba Satellite M55-S135 Notebook
I just bought a docking station for my Dell laptop computer. How do I hook it up so I can keep the top closed and use my desk top monitor? I want to be able to turn on the laptop without opening the lid.
Well.. you'd still have to open the lid to turn it on, right? (because you didn't mention the model of your laptop, I don't know where the power button actually *is*)
You want to close it while it's on, without it hibernating or going to sleep...
Go to your control panel, then into power or power management (depending on your Windows version, because you didn't mention it)
Then have a look under the "advanced" tab where it asks "when I close the lid of my computer". Set that to "do nothing".
Now when you close the lid, the laptop screen should turn off, but the PC should keep running. I'm not sure if that will still turn your external monitor off though.
I think that is your best solution, other than hacking off the little button that senses when the lid is closed. =-]
Aug 23, 2008 | Computers & Internet
Trouble with running a secondary monitor from my laptop
Hello tonyphats,
How are you trying to use the monitor? Just connecting it to the laptop? I know on most laptops you have to select to use the external monitor it won't just come up. You usually have to hold down the 'Fn' button and then press 'F5' or 'F7' to toggle between - monitor only, monitor and lcd, and lcd only.
If you are trying that, what happens? Does anything show on the screen?
-Chester
Dec 20, 2007 | HP Pavilion zd7000 zx5000 zv5000 presario...
Screen black
Bill, It could be your LCD backlight giving you problems. With the computer on and the monitor power LED green shine a flashlight in the lower left hand corner of your screen. Look for the ?Start? button, if your backlight is not working you?ll see a faint ?start? button if you look closely. Depending on the monitor this is usually and economically repairable problem. Let us know if you have any other questions and please don?t forget to rate this posting.
Mar 06, 2007 | Samsung SyncMaster 910T 19" LCD Monitor
Toshiba Satellite M65-S9063 PC Notebook Logo
96 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
