Question about Toshiba Satellite M105-S3021 Notebook
Mainboard replacement ,where do i get a repairs manual
  • 43 Answers
Hello. Try searching on the net. Some guys post very interesting video or picture tutorials on how to remove all the pieces.
Posted on Mar 16, 2009
Manual motherboard
Manufacturers only supply mainboard manuals when the mainboard is sold as a stand-alone part. This is so that the system builder can populate and setup the board according to specifications. Pre-built systems use mainboards that are specially designed for the PC manufacturer by the mainboard manufacturer. There is no manual associated with these builds. Some mainboards used in pre-built systems may be very similar to stand-alone models. In those cases, you may be able to use the stand-alone manual. But unless you know who made the mainboard for Lenovo (they did not), you won't find a manual for the mainboard specifically.
Aug 11, 2016 | Lenovo ThinkCentre A57 Desktop - Intel...
Need large, clear diagram for MSI motherboard, type ms 7613-iona gl8e
Hello this mainboard belongs to the HP/ COMPAQ support:
https://h10025.www1.hp.com/ewfrf/wc/document?cc=us&dlc=en&docname=c02014355&lc=en&product=4262655
The manual:
https://h10025.www1.hp.com/ewfrf/wc/manualCategory?cc=us&dlc=en&docname=c02014355&lc=en&product=4262655&
You can`t find anything at the msi support site.
Do you get any picture (blue screen of death) ???
Any beep sound ???
This fault could be: ram failure,harddrive,graphic card,cpu.
Or sinply mainboard is dead.
It`s always difficult to do fault finding on a mainboard.
Many thing can go wrong.
And it will sometimes cost more
than a new mainboard or pc to solve the problem.
Ask a qualified repair shop (hp support) about known issues
with this mainboard.
Good luck
Nov 25, 2012 | MSI Computers & Internet
The DC Jack seems to be loose, I've tried two different AC Adapters and discovered that they are in fact not the issue. The screen will show constant switching between power mode and battery mode at times,...
More likely than not the DC jack will need to be desoldered from the mainboard and replaced or the whole mainboard replaced.
Without warranty coverage you're looking at around $75 for a qualified tech to solder a new DC jack in or the full cost of the computer (replacing the whole system) as parts for the Eee PC's are prohibitively expensive and motherboard/mainboard replacement not really an option.
Jan 22, 2010 | ASUS Eee PC 1000HA Notebook
How to turn up back lite on acer aspire 5100
Based on what you are describing it sounds like you your mainboard has failed, and it will need to be replaced. Even if it is just the video component that has failed you would still need to replace the entire mainboard as the graphics are made onto the mainboard.
I agree with hoggie if your notebook is less that 1 year old I would return it and use your warranty to get it repaired.
Jan 20, 2010 | Acer Aspire 5100 Notebook
Shuts off red lights flashing
Hi there
If the temp light is showing from startup and doesn't fire up at all - you might be facing a Mainboard fault.This will need either repair or replacement.Must warn you that the replacement of a Mainboard is very expensive.
thank u
rate me!!
Aug 24, 2009 | Sanyo Office Equipment & Supplies
MainBoard Manual
It depends on the age of the unit and the availability of repair parts. Can you send me the Mother Board Identification? If you have a problem we will help you and give it to you.
Jun 17, 2009 | Computers & Internet
Motherboard fried for no reason and suddenly
I understand your pain. Acer has a extensive case-history of motherboards that die or quit for no reason. Do a search and you will find forums full of complaints where the machine just quit for no reason and did not start ever again.
I repair laptops for a living and see dead Acers in here all the time. Replacing the motherboard of a dead laptop is not easy. If you know how to work on computers, make sure you have a Service Manual for that make and model to make sure you can reassemble the computer. I do NOT recommend this.
I also do not recommend replacing the motherbaord at all. Firstly, only an ACER mainboard for that particular model will work - and secondly if you have to pay for another mainboard plus installation, the cost of labor and parts will likely exceed the value of the machine - which even if repaired with a new mainboard - could conk out on you all over again.
My advice - consider it totaled, invest your money in a newer model, and think twice before you buy Acer again.
Dec 19, 2008 | Acer Aspire 5100 Notebook
Is it easy to replace the graphics card on a Philips x59 laptop
laptops have thier Graphic circuitry build into the mainboard-to replace the mainboard is not economically advicable.you are bound to spend a lot in repair cost.So think carefully about what you do.
Jul 16, 2008 | Computers & Internet
Mitsubishi sl2u projector fault
Hi there
Apr 02, 2008 | Office Equipment & Supplies
Olympus c755
Your backup battery has gone dead. Check your manual to see if it is replaceable, or if it needs to be replaced by a repair shop. I have a C-750 on my bench now in for repair, and I do not see a customer-replaceable backup battery. I do not know if this applies to the C-755, but the C-750 requires disassembly to replace this cell. David Millier Advance Camera Repair
Feb 21, 2007 | Olympus Camedia C-755 Ultra Zoom Digital...
Toshiba Satellite M105-S3021 Notebook Logo
61 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
