By mistake some combination of button from remote got pressed and I lost the sound of my tv. It is showing S symbol on tv. Is there any step to get back the original settings.
hit menu button on your remote, navigate to channel setup menu. on the sub-menu, set channel fix to your channel that you require. now when your tv powers up this will be the default channel. if this doesn't fix your issue then try cycling through video inputs tv/video button on your remote.
Unplug everything and wait for a few minutes. It may very well also be that your TV has lost it's picture and needs repaired. Not because of anything you did. Just coincidental to you thinking you pressed the wrong button on your remote.
Did you hit the "input" or "video source" button by mistake on the remote or TV? That would change the input from the one the cable/video source uses. You're getting sound, so it's working......sounds as if the input was maybe changed. I'd hit the input/video source button a few times to go through all the available inputs and see if you get video back.
i don't know what brand and model of your television,,,all i can say is that, you have to read first the manual instructions. you press the menu and check.
The high pitch sound could have been the flyback transformer. check the horzontal output transsitor if is gone the tranfomer is sure to be gone . Tranformers are varying in price are the transistors can also vary you could be looking at around 150.00 plus labour.
i just fixed mine by doing this. on the remote there should be a button that says f. hold down the f button then press mute and that should work it did for me
