Question about Dryers
I have a whirlpool GEQ9800LG1 Dryer that takes along time to dry
This is crazy. it will dry fine at times and then you will need to run it 2 or 3 times to get clothes dry. My vent is clear and has no kinks in metal flex hose.
  • mitch_smith Mar 02, 2009
    Thats it it will dry in timed mode and Auto mode then it will not. This weekend it dryed t loads fine and then the next day it had to be run twice to dry
  • 463 Answers
Does this dryer have an automatic mode? If so, does it dry appropriately in manual (timed) mode?
If the timed mode is working, then the moisture sensor is bad.
Posted on Feb 27, 2009
I have a whirlpool cabrio gas dryer that take along time to dry. It has a code of F1 stored on it.The dryer vent is clean.Is the control panel bad.
change gas valve coils. for f1 error, if dryer is running don't worry about it. in future if your dryer beeps and flash f1 error you can unplug dryer get main control board out check dry solder on motor control rely it it is dry solder you can solder and you good to go or not solder problem then you need new control board. good luck.
Jan 21, 2017 | Whirlpool Dryers
My Whirlpool duet dryer isn't drying on automatic or timed settings. I replaced the ther-o-mister, but the dryer isn't heating up. How do you run a diagnostic on this dryer. Model GEW9250PWO
You should know that dryer has a thermal fuse located along exhaust Of heat... When You over load the machine the flow of air is not enough... Then thermal fuse is damaged ( open due security condition ) and the flame is turn off all the time... Just replace the thermal fuse. I hope this can help You. Sincerely
Jul 10, 2013 | Dryers
My Whirlpool dryer tumbles but no heat. The clothes dry after along period of time and that is when i finally feel some heat.
Probably needs a good cleaning. If it was me I would remove the filter housing and do a through cleanup. make sure the vent going outside is not blocked. The dryer must have adequate airflow to work well.
BEFORE AND AFTER
Oct 03, 2012 | Whirlpool Dryers
Whirlpool gas dryer GGQ9858JQD runs fine not drying
Check the inlet and exit venting around the burner for lint or other obstruction.
Aug 23, 2009 | Whirlpool LGV4634JQ Gas Dryer
Whirlpool dryer wed5200tq0: I have to run cycle
Check the following areas thoroughly to address this issue.
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
****(((Please disregard step three if this is a GAS dryer)))
Aug 21, 2009 | Whirlpool Dryers
Changing gas whirlpool dryer heating ailment
Before you do that try this pull the unit out from the wall remove the venting from the back run a load and let the hot air go intop the house if it drys fine you have a plugged vent going to the outside and it will need to be cleaned out (This is the most common problem for long dry time)
Apr 13, 2008 | Whirlpool LER5636P Electric Dryer
Whirlpool Dryer GEQ9858J autodry problem
Are you running the dryer in a relatively humid environment?
Sep 07, 2007 | Whirlpool GEQ9858J Dryer
Dryers Logo
199 people viewed this question
Top Dryers Experts
