Question about LG CRN 8245B (CRN-8245B) Internal 24x CD-ROM Drive
Toshiba ODD-DVD SD R5272 won't recognise blank DVDs
The DVDs are -RW & +RW--Fujifilm(-) and Sony (+). It won't recognise these blanks as legitmate formats. Can't burn to them. Was trying to burn an iso and none of my burn programs would recognise the writeability of these blanks. Can't figure it out. Used CdBurnerXP and it started to write, but then failed.
Rene
  • Anonymous Apr 25, 2009
    It wont read blank DVD-R's.. It treats them like they have the space of a blank CD.. But it uses DVD-RW's correctly. I have tried Verbatim, Sony, Memorex, and Maxell DVD-R's.. They all do the same thing.
  • 83 Answers
SOURCE: cd rw/dvd combo drive GCC-4242N WRITING PROBLEM
what brand , model number, and operating system you are using,,,
Posted on Jul 15, 2007
SOURCE: Blank DVD discs that used to be recognised are suddenly not able to be read
I've found that once a disk is formatted in certain formats with a pc it prevents the LG from reading it.  Format it again in the LG (if you can!) or use the pc to format it using the UDF1.5 setting in a pc (which sort of resets it so the LG can at least see it as an unused disc again).
All in all I have found my RH19991H really confusing as far as disk initialization and formatting and finalizing is concerned.  Sometimes you can select to finalize a +-rw dvd and sometimes not (the latter is the the case according to the manual) and sometimes I can select the format mode and sometimes not.  Sometimes the machine auto finalizes the dvd+-rw (the way it should be says the manual) and sometimes it does not and then I cannot use it in the pc.  I have also created some disks with DivX files and was able to play them in the LG and then using the same pc, same type of discs, same video editing software and same settings created other DivX files I could not play on the LG.  It seems the software on the machine needs some work...
Posted on Nov 01, 2007
melnavz
  • 1226 Answers
SOURCE: LG LS50 DVD/CD-RW DRIVE won't recognize blank dvd-r
Yes does not read DVD-R because if your LS50 Labeled like this (DVD/CD-RW) means that can read only all DVD Disc and cannot write on DVD blank only CD blank.
You can burn only on the blank CD-RW or any blank CD.
Posted on Jan 17, 2008
Drummernick
  • 440 Answers
SOURCE: Optiarc DVD RW AD-5170A ATA not writing DVDs
how big is your movie les sthen 4.5 gb ha sto be and u only burn at 8x never full 16x ok thx for using fix ya nick
Posted on Feb 03, 2008
  • 256 Answers
SOURCE: reads DVD's but fails to burn
do a system restore from the date when you remembered you're pc was not having that kind of problem. start menu >> all programs >> accessories >> system tools >> system restore.
Posted on Mar 29, 2010
Can't write dvds
i have same problem. i tried to fix it myself but didnt work its the problem of dvd-writer no problem with software, i know becoz i took my friend's dvd-writer and its woking absolute fine, so better take it to some hardware repair shop.
Oct 02, 2009 | Computers & Internet
I have a toshiba ODD-DVD SD-R5272 that runs in win 2000 But the windows drivers it uses say its only a CD rom I have done the firmware update ...With no help What else can I do ?
Make sure you have the proper driver installed and that it is working.
Go to PCPITSTOP and have them scan your machine. It is a free service.
I hope this helps you
a
Sep 21, 2009 | Toshiba SD-R5272 DVD±RW Burner
Toshiba sd-r2002 - won't recognize blank CD when trying to write files to a CD
right click on the drive.... go to properties... under tab recording, remove tick "enable CD recording on this drive" and press apply... after that tick "enable CD recording on this drive" and press OK.
It should work.
Jun 01, 2009 | Toshiba SD R2002 CD-RW/DVD-ROM Burner
Cdrom doesnt recognise blank dvd. error message
Its only cd writer burner and can only that it can read dvd disc also. That is why its called combo. But burning blank dvd it can't. But if you want buy some dvdburner too.
Apr 19, 2009 | Memorex (32023244) CD-RW/DVD-ROM Combo...
Toshiba sd-r2002
I'm very late to your question, but the problem is that this drive doesn't burn DVDs (i.e., it was not designed to do that). It's a CD-RW, DVD-ROM (read only).
Apr 03, 2009 | Toshiba SD R2002 CD-RW/DVD-ROM Burner
DVD-RW not recognising blank disk
Usually HPs are good with +R DVDs unless things have change over the last year or two.
Whats the model number on your computer?
Aug 09, 2008 | Tablets & eReaders
Did you try a DVD firmware update? Some dvds need new firmware to reconize some DVDs
May 30, 2008 | Computers & Internet
Toshiba ODD-DVD SD-R5272 not compatible with iTunes
go to My computer right click on cd drive properties - check digital cd playback recording - check enable cd recording on this drive driver - update or uninstall reboot your computer Good luck!
Dec 10, 2006 | Toshiba SD-R5272 DVD±RW Burner
Toshiba A30 - DVD-ROM CDRW
Wow, That's a weird malfunction. Only TDK??? What about other media types? Did you try a diffrent burning software?
May 12, 2006 | Toshiba (SD-R2412) for Satellite A10, A15,...
LG CRN 8245B (CRN-8245B) Internal 24x CD-ROM Drive Logo
607 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
