Question about Virtual Reality VRCD500-SDU CD Player
VRCD500-SDU losing settings at sub freezing temps
Bought the VRCD500-SDU last summer and installed it. It worked fine until winter came around. Now, when the temp drops below freezing, the deck loses its settings and I have to reset everything (time, stations, bass, treble, beep). It is very frustrating and I am about ready to just throw it away and get something else.
  • 463 Answers
You've either got:
An inermittent in the battery (+) wire (the one that is always supposed to be hot)
or
You need to pull the connectors out of the back of the unit and firmly re-seat them back in there.
Posted on Feb 27, 2009
Description to pins of a car radio
Starting at the upper right (UR1) when looking at the rear of the unit: UR1 is 12v power; LR1 is ground; UR2 = Ignition power; LR2 = Panel light lead; UR3 = Unused; LR3 = Power Antenna lead; UR4 & LR4 = Right front speaker; UR5 & LR5 = Right rear speaker; UR6 & LR6 = Left rear speaker; UR7 & LR7 = Left front speaker; UR8 & LR8 = Unused.
Jul 29, 2012 | Virtual Reality VRCD500-SDU CD Player
I was trying to eject a cd out of my vrcd500-sdu and it stopped working it won't turn on at all
check fuse in fusebox for radio it could have blown, Plus check all connections maybe use voltage meter to make sure power is going to the unit.
Aug 14, 2010 | Virtual Reality VRCD500-SDU CD Player
Need head unit pin outs for VRCD500 - sdu as am in uk and can't buy harness
hello , i'm looking for a manul and wiring harmed for car radio virtual reality sound labs model number vrcd500-sdu
Jul 09, 2010 | Virtual Reality Sound VR3 CD Player w/ USB...
On my vrcd500-sdu the radio stations won't stay stored once the car/radio is turned off...what do I do so they stay stored?
If the car is a peugeot, renault, vw, audi, fiat. Chances are the lives just need to be swapped into the radio. Lives on a radio are red and yellow. on some makes of cars these are the opposite way round. so join yellow to red and red to yellow. this will solve the memory storage problem.
May 17, 2009 | Virtual Reality VRCD500-SDU CD Player
My vrcd400-sdu will not trn on...
i have a vrcd400-sdu the reset reset led it go on and off the radio well not come on
Jan 20, 2009 | Virtual Reality VRCD500-SDU CD Player
Error 13 MP3 playback
Ah.. Error13! Not again! Anyways this is a very common problem in all kinds of players that have USB support. Error 13 means device communication error usually due to power failure. Looks like some loose contact inside this player. Taking it apart and rewiring will fix the issue..
Hope this helps,
Sai.
Oct 07, 2008 | Virtual Reality VRCD500-SDU CD Player
No sound. Tried all solutions posted.
Are you using the speaker outputs? If you are using the rca pre-outs for an amplifier they are mislabeled. The subwoofer out is labeled as the front output and it is off when shipped. Connect to rca out labeled as the sub and you should get sound. The sub out can be turned on from the front panel by pressing and holding the "band/sub" button. The flashing light intended to mimic an alarm, it has no other purpose.
May 31, 2008 | Virtual Reality VRCD500-SDU CD Player
VRCD500-SDU
Same issue. Power, but won't turn on. Just started happening when the outside temp reached 95+ degrees...
Apr 16, 2008 | Virtual Reality VRCD500-SDU CD Player
No sound...
Hi XX,
Let's try the easy ones first:
1. try to do a reset of the unit;
2. check that all the speaker wirings are:
2.1 connected properly following the wiring diagram;
2.2 not bare/exposed and touching any metal part/chassis;
3. verify that the MUTE is not enabled;
4. try all signal sources: AM/FM, CD, SD Card, USB, AUX;
5. verify that the SEL is set to SUB OFF;
6. replace the CR-2025 Lithium battery of the remote.
If your concern has not been corrected after completion of the above procedures, you may need to:
a. open the unit for a loose connection and/or other diagnosis;
b. ask assistance from the manufacturer's Technical Service at 1-800-445-1797;
c. return the unit for a replacement.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 02, 2008 | Virtual Reality VRCD500-SDU CD Player
NO SOUND!!!
check all your fuses and then take the face plate off and push the reset button. if that doesnt work just check the wire connections sometimes if the wires dont have enough contact they want work. i had that issue when i upgraded the speakers in my jeep the connections were not good enough.
Virtual Reality VRCD500-SDU CD Player Logo
443 people viewed this question
Top Virtual Reality Car Audio & Video Experts
Tom Chichester
Are you a Virtual Reality Car Audio and Video Expert? Answer questions, earn points and help others
