Question about Zyxel P660HW-D1 Router
Cannot see other computers on my Zyxel router network
I've just replaced a sick Linksys ADSL router with a Zyxel one, and overall am pleased with its performance.
I have three laptops that access the net via wireless, and my main PC which is connected to the router via a LAN cable.
My problem is that the main PC cannot 'see' the wireless laptops, andthey cannot see the main PC - which is a headache, since the main PChas the printer attached which needs to be accessible on the network!
I have tried going through the network setup routine on both a laptopand my main PC, but while all the wireless laptops can see eachother, they are still blind to the main PC. What do I have to do to get all the machines accessible to the main PC??
All the PCs are running Windows Vista, Home Premium.
  • Aethelstan Feb 27, 2009
    The settings are all the same - the same as they were before, when they
    were connected on the network before I changed the router. All the PCs
    are on the same workgroup and all have network discovery on.
  • 173 Answers
Change Settings, Be sure they on the same domain & workgroup settings and they are all shared.
Posted on Feb 27, 2009
  • Joselito Perez Mar 02, 2009
    Did you put administrator rights or might be the firewalling system/ antiviruses might block it.
How to set up zyxel NBG416N in universal repeater mode
Yes Zyxel nbg-416n does indeed support repeater mode but you need to make sure you have at least firmware version v1.00(USA.5)C0 and you can switch to that mode via maintenance/sys op mode.
Jun 14, 2012 | Zyxel Communications NBG416N 11N 150N Wlan...
How do I bridge mode a ZyXEL 600 series ? help please
Try setting both internal and external interfaces to DHCP rather than static, or if you have legal static IP address put it on INTERNAL interface only.and leave external as automatic.
Feb 24, 2010 | Zyxel Prestige 650HW - ADSL Router...
Cable Network Routing with Zyxel 600
You have to set different ip address. To clear this up this how I got my setup. I have verizon internet. I use a westell 6100g modem, I have the local ip address set for and I got a linksys wireless router and the ip address set for Then I plug my modem into the wan port and it works. What am I doing is setting a static ip address from my modem to the router and using the router to distribute my address through the network. If you have any printers on the network you need to change that numter to 192.168.9.x number. If you don't have two different numbers set the router will take over.
Aug 09, 2009 | Zyxel Prestige 841 (91-004-226010) Modem
Can't connect my Ipod touch to my router?
You must be sure to what router you are trying to connect. I understand you have a ZyXel and a linksys. You must have 2 wireless networks. Your wireless network must be secured, so you just have to use the correct password. I need more details. Try this
Feb 08, 2009 | Linksys Wireless-G WRT54G Router
Windows Millenium can't connect my Router ADSL
Please make it more clear your question.
1) Are you able to modify your network connection at control panel. or
2) Type at command prompt c:\ipconfig and check what ip it is showing.
Jan 27, 2009 | Zyxel P-660RU-T1 ADSL Ethernet/USB Router...
did you setup a wireless network ? if you didnt go to control panal and then wireless network setup icon and follow instructions (select automatically provide network key option) then follow instructions and finish. once you did that, search through wifi on youf phone it should find your WNetwork and then connect and enjoy. if you want to use internet and have an ADSL modem, make sure that the modem is connected to the internet RJ45 plug on your router. and from router to PC.
good luck, i hope this helps
Dec 30, 2008 | Linksys Wireless-G WUSB54G 802.11g/b
Port forwarding
well to start, your connection would possibly be ADSL and your zyxel is set to provide DHCP address on your network, so its router capabilities could be turned on.
if this is true, you may need to rework the connection settings.
here's a recommendation:
1.set your modem to bridge mode (bridge only)
2.this will then be allowing your linksys to manage your DSL connection through PPPoE
3.after so, your linksys router should get a public IP address for an internet IP when you go to status tab (not an IP address starting with 192.168.1.xx)
after so, you may reconfigure your port-forwarding.
the reason why you will need to set your modem to "bridged" only is that if it is not, your zyxel's firewall is also turned on, provided that the linksys' firewall is always on. so even if you define which port will be opened on the router, it will still be blocked by the modem's firewall.
Jun 22, 2008 | Zyxel Prestige 660R Router (91004397002)
Connecting using wireless
because of zyxel support only zyxel product only
Apr 03, 2008 | Zyxel Prestige 660R Router (91004397002)
Zyxel P660HW-D1 Router Logo
254 people viewed this question
Top Zyxel Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
