Question about HP Photosmart C6180 All-In-One InkJet Printer
I have a Ink System Failure.
My 3210 will not print, scan or copy. I have a error message - Ink system has failed. Unable to print, receive faxes or copy. Refer to printer documentation. Error Oxc18a0206 When I turn on my printer it makes funny noises than in the box it reads: Ink system failure error code 0xc05d381
My product is the same is below except it is 6280, it wasn't listed and the one below is the closest to it.
  • 1 more comment
  • tonisavic Feb 27, 2009
    I have a HP Photosmart C6280 All-In-One
    My printer will not do anything it says there is a Ink Error 0xc05d1381
    I've already tried twice unplugging it and waiting for 10 minutes.
  • tonisavic Mar 01, 2009
    I have a HP Photosmart C6280 All-In-One printer
    that has an error code 0xc05d1381
    So far I've tried unplugging it and waiting 10 minutes, I also have uninstalled the application and re-installed.
  • tonisavic Mar 07, 2009
    Solution sounds helpful, I just need to find someone in my area who will fix it at a price that would be worth it to me.
  • HP Master
  • 19,396 Answers
Try the steps below from HP:
1) First off, press the Setup button on your printer.
2) Now, press the down arrow button until Tools is highlighted and then press OK.
3) Again, Press the down arrow button until Clean Printhead is highlighted and then press OK; a test page should be printed.
4) Examine the test page; If the print quality of the page is good, stop here. If the print quality is bad, go on to the next step for cleaning the printhead further.
5) Open the Printer Toolbox. There are two ways to do this: > Open HP solution cetre Select the Settings menu, then the Print Settings submenu, and finally the Printer Toolbox,
or
> Open Printers and Faxes in the Windows Control Panel, then right-click your printer icon and choose Properties. Click Printing Preferences. Click the Features tab, then click the Printer Services button.
6) The Printer Toolbox opens; in the Device Services tab, click Clean the Printheads, then follow the on-screen instructions. Up to three levels of cleaning are available; discard or recycle the page that prints.
7) If cleaning the printheads once does not help, follow the directions in step 6, but use the next level of cleaning.
Posted on Mar 04, 2009
  • 679 Answers
Ok try this , go into the device manager, start, control panel, system, hardware, device mgr, and look to see where the multi function device in question. Highlight it and click on uninstall. This will take that non working machine out of the loop it's in. When you restsrt it should locate the device and reinstall the software, you will see at the taskbar, it will say found new hardware, followed by installing the software for the new hardware. That is usually what will fix this type of hardware problem. If it works please rate accordinglly. good luck
Posted on Mar 01, 2009
    Brigadier General:
  • 8,619 Answers
Hi!
Try Following this procedure to remove the error code---
  1. Press the On button to turn the printer off.
  2. Unplug the power cord from the back of the printer.
  3. Remove all the ink cartridges.
  4. Wait two minutes.
  5. Plug the power cord into the back of the printer.
  6. Press the On button to turn the printer on.
  7. Install the ink cartridges when prompted.
Thanks
Rylee
  • 82 Answers
An Ink system failure message and error code appears on the printer display.
Solution:
Step one: Reset the printer
Press the On button to turn off the printer.
Unplug the power cord and universal serial bus (USB) cable from the back of the printer.
Wait 30 seconds.
Plug the power cord back into the printer.
If Ink system failure does not display, the issue is resolved; reconnect the USB cable and resume using the printer.
If the previous steps have not cleared the message, continue to the next step.
Step two: Download and install firmware update
Go to the product support page to download the update.
http://h10025.www1.hp.com/ewfrf/wc/softw...
Click Software & driver downloads.
Click on the appropriate operating system link.
Click on the Recommended update to fix long power-on cycle and ink system failures link and follow the instructions to download the file.
After downloading is complete, disconnect all other USB devices from the PC. Make sure the product is powered ON and plugged into the USB port.
With the printer directly connected to the PC, click the downloaded file FirmwareEnable_Release.EXE.
Click Open/Run.
Click OK at the Update successful window. The error should have been cleared from the printer display.
If you get a message saying a device was not detected (see Figure 1), make sure the printer is powered ON and the USB cable is connected to both the printer and PC and try step five again.
  • 916 Answers
You will need to replace the print head to get it working again. That error code refers to a damaged print head. I would bring this to a pc shop to be repaired it should be fairly cheap.
Posted on Feb 27, 2009
  • 1,800 Answers
First solution it:
  1. uninstall application
  2. install it reboot
  3. plug printer
  4. test page
tell me ur feedback.
    Brigadier General:
  • 5,158 Answers
Unplug it for about ten minutes to reset it
Ink system failure
I have a message on my printer
Ink System Failure
ink system has failed -unable to copy, receive faxes,or print.
error Oxc19a0107
Feb 10, 2011 | HP Photosmart 3310 Printer
Hello my printer model in an HP Photosmart 3210 All in one, it was working okay until I replaced one of the empty ink cartridges and now I just receive this message, "Ink System Failure, Ink system...
Greetings sometimes when this happens is that the printer cartridge is not accepting that as the correct model I recommend you go where you bought it and ask for another because this is not working, I recommend getting one new one that is not Refil
Dec 29, 2010 | Office Equipment & Supplies
I have a Hp photoshop 3210 printer ink cartrage error empty or
I installed new cartriges, but my printer keeps giving me an error msg, Ink system has failed. Unable to copy, receive faxes, or print. Refer to printer documentation. Error: Oxc18a0206. What do I do now?
Nov 06, 2009 | HP Photosmart 3210 Printer
Ink system has fail. unable to copy receive faxes, or print. Refer to printer documentation. Error: 0xc18a001
i can not feed paper at all or copy to paper but i can scan files to my computer how can i fix this
Mar 01, 2009 | HP Photosmart 3210 Printer
IssueAn 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel. The printer cannot copy, receive faxes, or print. Solution
Wait two minutes.
If the error code does not display, the issue is resolved.
If the 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel, service the printer.
Dec 20, 2008 | HP Photosmart C5180 All-In-One InkJet...
Hp photosmart 3313 all in one
If you are getting inksystem failure along with Error 0xc18a0106 then contact HP support. If you need their contact info I can give it to you.
Thanks,
Lee
Jun 17, 2008 | HP Photosmart 3210 Printer
HP PHOTOSMART 7180 ALL IN ONE
how to reduce the baud rate in all in one printer
Apr 16, 2008 | HP Photosmart 3210 All-In-One InkJet...
I had this same problem but with a different error code. Try doing:
1. Unplug the power cord from printer.
2. Hold both o.k and Cancel simultaneously.
3. Plug the power cable while holding the buttons.
After I did this my printer reconfigured like it used to do and it was like it was new again.... well new plus a headache a managed to get while reading all these little posts. I hope this helps!
If not try going to this website:
http://www.out-of-warranty.com/how-to-reset-hewlett-packard-hp-all-in-one-printers
Mar 02, 2008 | HP Photosmart 3210 Printer
HP Photosmart C6180 All-In-One InkJet Printer Logo
228 people viewed this question
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
