Question about Brother Sewing Machines
Thread caught and messed up the tension spring.
I cannot adjust the tension when sewing.  Any suggestions
    Scholar:
  • 69 Answers
You tension should always be between 3-5. There are several things that can cause a machine to not adjust properly. The most common is threading incorrectly. Another is pieces of thread caught in the tension assembly,usually between the metal tension discs. Try rethreading your machine with the presser foot in the up position.
Posted on Mar 01, 2009
How do to adjust the bobbin tension? Do I need to remove the throat plate and loosen the screws that hold the bobbin mechanism in place so I can get to the tension screw?
the tension screw for the bobbin thread is on the side of the bobbin carrier
that bit that you put the full bobbin in to clip it back onto the machine
t there is a small spring plate that you pull the bobbin thread under when you put the bobbin back in the carrier and you pull the thread down a slot and under that spring plate
the tension is adjusted by that small screw that holds that plate on
only very small adjustments make a lot of difference to the tension
don't touch any other screws or you will alter the needle /hook timing and that will put you a pickle
Oct 02, 2015 | Sewing Machines
Why is thread getting caught and unable to pick up the bobbin thread?
try tightening the needle thread tension as it appears to be too lose
try loosing of the bobbin thread tension a fraction as it may be to hard to pull out of the bobbin case under the spring
changing thread sizes and material thickness generally requires a tension adjustment of the threads
Sep 16, 2015 | Singer 4411 Heavy Duty Sewing Machine
How do you adjust the bobbin tension on an emerald 118
There is a screw on the bobbin case that can be used to adjust the tension. However, first I would check that there is not a thread or lint caught in the tension spring of the bobbin case. Use a stiff brush to clean bobbin case. Use a needle (or other sharp point tool), and check spring area for thread.
Jun 17, 2014 | Husqvarna Viking Emerald 116 Sewing...
I have a Brother sewing machine and whenever I try to pick up the bottom thread (or when I try to sew), the upper thread gets caught around the bobbin case causing a huge, knotted mess. It's just all...
Check your top tension dial setting is on 5, as this sounds like the thread is not in tension fully so is looping up around the rotary hook and not being held back by the tension device. Is the pressure foot lowered (this turns the tension on) fully and is the thread through the tension discs correctly. Lower the pressure foot and pull the top thread from below the tension dial, it should feel firm to pull, if it comes out easy, its not undertension, device could be faulty and machine will need to be serviced.
Also, check that the bobbin case is fully inserted into the rotary hook in the correct position, bobbin is in and rotating the right way and thread is into the tension spring fully.
If you have the manual pull it out, and carefully check the threading up instructions and follow on your machine - it is probably one of these things causing the jamming.
May 23, 2011 | Brother LS-2125 Mechanical Sewing Machine
The tension on my top thread is so tight it breaks the thread no matter if the tension is set on 1 or 9? Any suggestions?
check the needle to see if it's in backwards
check to see if the needle is bent
the thread might be hung up in the bobbin case(check area for lint or loose thread)
the tension spring could be bad-if this is the problem it would have to be replaced
check to see if it's threaded correctly(usually rethreading it is the best way to check)
check to see if the thread is caught on the spool pin or on the notch on the spool of thread it's self
make sure thread is not hung up on any of the guides
make sure the thread is not notty-if so replace
sometimes pieces of thread can be caught in the tension area
Aug 22, 2010 | PfaFF Sewing Machines
My bottom thread is a real mess when I sew. The
I would suggest to replace the bobbin case,
make sure the needle is not in backwards
make sure the needle is not bent
Jul 29, 2010 | Brother BC-1000 Computerized Sewing...
Thread knotting up at needle
my suggestion is to try different thread
check the tension
make sure there's no loose thread's caught up in the tension spring
Jul 29, 2010 | Juki DDL-8700
Viking Designer 1 balleds / Birdnest / issues after repaired from Husk service center in midwest - replaced thread needle and adjusted tension .. freequilting and embroidery situations
birdsnest refers to a mess of thread on the underside of fabric when you start sewing (after a few stitches all looks good). if this is the case and it is happening during embroidery, switch off jump stitch thread cutting.
if it happens at the start of normal sewing, either hold your needle thread when you start sewing or make sure the needle thread is under the presser foot and held by the presser foot when you start sewing. this way you will have an inch or so of thread on top of your fabric which you can trim instead of a mess underneath.
if there is a mess underneath for more than first few stitches, either your check spring in the needle tension area is set incorrectly, or your needle tension is set too loose (adjustable in sevice menu by tech only) or there is foreign matter caught in tension assembly preventing proper tension.
scott
Jul 26, 2009 | Husqvarna Sewing Machines
Thread caught in hook race
There should be a small screw on the side of your bobbin case adjust it little by little until you get the correct tension.
Jun 06, 2009 | Euro-Pro 9125 Computerized Sewing Machine
Need online manual
If you are having problems with the thread on the underside of the fabric, that is usually the upper tension. Check to make sure that it is threaded correctly. If so, make sure that the thread is inside the tension disc and that there are no pieces of thread caught in the tension. If it is threaded and there are no thread caught up in the tension assembly, adjust your tension dial to a slightly higher number. Do this until you get a good stitch.
Feb 09, 2009 | Kenmore Sewing Machines
Sewing Machines Logo
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
