Question about HP LaserJet P2015dn Printer
I have HP LJ 2015D all lights stay on except paper load LED, How to fix it
  • Janmo Mar 04, 2009
    HP LJ 2015D all lights stay on except paper.
  • Anonymous Mar 12, 2009
    I have had about 10 of these printers with the same problem, I fixed some by putting in the boards from some 2015s with different problems, if you cant get your hands on a spare board I suggest you take it to your local rubbish dump, or put it out for the scabs during rubbish collection time, let them work it out XD
    Novelist:
  • 102 Answers
Take the Tray 2 out and check if all the paper guides are moving freely if they are than remove the toner cartridge and check if any toner sensor is not align correctly.
If they are aligned correctly than next to the pickup roller there is a small piece of plastic make sure it should be hanging freely if it is than we need to perform cold reset of the printer.
Switch off the printer press and hold down the go button and switch the printer on keep holding down go button till the time three lights lit up on control panel, as soon as three lights lits up release the go button and let the printer initialise of it s own.
If that doesn't fix than Formatter Board of the printer is faulty.
Logic:
If there is no paper jam and printer rep[orts the jam means either any of the sensors is not aligned correctly and reporting the jam or formatter Board(Motherboard) of the printer is faulty and showing incorrect display.
Thanks and Regards
Posted on Jul 03, 2009
  • 102 Answers
SOURCE: led on problem after half wormmingup
Logic:
Thanks and Regards
EPIJAB
  • 89 Answers
SOURCE: hp lj 2500 flashing yellow light
The yellow-print-cartridge
light is blinking, and the
printer stops printing.
 The print cartridge is
empty or missing.
 The printer cannot
detect the print
cartridge correctly.
1. Reinsert or replace the print cartridge.
2. If the print-cartridge light is still blinking but the
Attention light is not on, turn the printer off and
then back on.
3. If the problem persists, repeat the above steps
with yellow print cartridges until the error is
resolved.
4. If the problem persists, replace the printcartridge
E-label reader, which is located on the
pressure assembly of the print-cartridge
carousel.
Posted on Jan 09, 2009
  • 5 Answers
SOURCE: hp lj 2015 jam led stays on
Judging by my personal experience with these printers...if there really is no paper jam, you are most likely looking at a bad formatter board. Very common issue with these printers.
Posted on May 20, 2009
SOURCE: hp lj 2015dn problem for top 2 LED standard ON in my printer
check your printer motherboard it could be the communication cable from the power board is bad or the mother board that is why it can not scan. that is the problem
Posted on May 23, 2009
Thiru77
  • 33 Answers
SOURCE: hp lj 4700 with error 41.3 unexpected paper size
Take the paper off and place the correct paper size.
If the setting is in A4 paper size please place the A4 size paper.
Thanks
Thiru
Posted on Jun 17, 2009
Cram paper led is flasher
Nadia, printer paper jam, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Aug 09, 2016 | HP cb367a - 2015d Laser Printer
Fix inner paper jam hp cm1312
I Suggest You To Watch HP Video Gallery Fixing Paper Jam HP Deskjet 1510 All in One Printer To Fix Your Brother Printer Issue.In Case You Still Having Problem Then Follow Us For On : HP Printer Support Team.
Nov 19, 2013 | HEWLETT-PACKARD HP Color LJ CM1312 MFP...
HP 2015d While trying to print there is a gutteral noise on the first pass then the paper is picked up on the second pass and then the printed document feeds out. It appears to miss pick up on the first...
first you can try to clean the paper pick up tire, but most likely the problem is in pick up clutch.
TO replace him and rectify the problem you need to dismantle half of printer... call service...
Hope that helps!
Aug 23, 2011 | HP LaserJet P2015dn Printer
Hp lj 4700 with error 41.3 unexpected paper size
Thanks
Thiru
Jun 17, 2009 | Office Equipment & Supplies
Led on problem after half wormmingup
Logic:
Thanks and Regards
Jun 17, 2009 | HP LaserJet P2015dn Printer
Hp lj 2015dn problem for top 2 LED standard ON in my printer
May 23, 2009 | HP LaserJet P2015dn Printer
Hp lj 2015 jam led stays on
Apr 13, 2009 | HP LaserJet P2015dn Printer
Hp lj 1200
How much Price HP lj 1200 at Sisney- Astralia?
Aug 16, 2008 | HP LaserJet 1200 Printer
Brother Laser Printer HL 1440
tray this
The procedure for the factory inspection mode is as follows.
(1) Turn off the printer power switch, open the front cover, and remove the drum unit.
(2) Turn on the printer power switch while holding down the control panel button. The Drum
LED comes ON.
(3) Lightly press the panel button again.
(4) Check that all the LEDs except the Ready LED are OFF.
✒ If the toner sensor is ON, the Drum LED stays ON (error).
✒ If the front registration sensor is ON, the Alarm LED stays ON (error).
✒ If the upper paper cassette sensor is ON, the Data LED stays ON. (error) (HL-1250
only)
NOTE:
The lower paper cassette solenoid is turned ON/OFF even if the panel button is not pressed.
(5) Check the rear registration sensor.
✒ If the rear registration sensor is stuck backwards, the Ready LED stays OFF. (error)
✒ If the rear registration sensor is moved back and forth, the Ready LED comes ON at
any time. (error)
(6) Check that only the Data LED comes ON while pressing the panel button.
✒ If the paper eject sensor is ON, the Drum LED stays ON. (error)
✒ If the lower paper cassette registration sensor is ON, the Ready LED stays ON. (error)
If the registration sensor is ON, the lower paper cassette solenoid is turned ON, and
the Ready LED also stays ON. (HL-1250 only)
NOTE:
(7) Install the drum unit.
✒ Check that the Drum LED goes ON and the Ready LED goes OFF.
(8) Close the front cover.
(9) Continue to press the control panel button.
✒ Check that the Data LED stays OFF.
(10) Release the panel button.
(11) If all the sensors except the toner sensor are correct, the printer goes back to the Ready
status.
If any error is detected, the printer stays in the inspection mode.
Apr 01, 2008 | Brother HL 1440 Laser Printer
HP laserjet P2015D , JAM LED in a solid state ??
Dear gentlemen,
Hope this helps you sort out the problem. Please check paper jammed pieces of paper remains from paper in to out paper path. Check if the paper is properly picked-up, else check rubber roller pick-up and the solinoid motors that control to fed on and off the tray to engage pick-up. Check paper path sensors if possible. If you can determine when is the paper Jam happens please advice. Other means you can also refer your manual and machine diagnostic menu which part of the operation the paper will jam.
Best regards,
Rosener Guyano
Jan 10, 2008 | HP LaserJet P2015dn Printer
HP LaserJet P2015dn Printer Logo
2,741 people viewed this question
Ben Johnson
