Question about Orion HCCA-D5000 Car Audio Amplifier
Orion hcca 250 digital reference
i bridged my orion hcca 250 digital reference
using the orange wire as pos and black/yellow as neg
i then connected two orion xtreme 12" 500watt subs
a 600watt jensen amp powers two separates
orion separates at the rear and jbl separates at the front
powering the system is a 1farad lightning audio capacitor
the RED POSITIVE LINE of the orion hcca 250 amp is getting very hot
and the power it is giving to the two subs is not sufficient
the subs have no bass instead crackling sound is coming out
what is wrong with the system
tnx
  • 32 Answers
If its hot its drawing to much current sound as if you have something improperly hooked up..if i could see your wiring i could help u out better steve
Posted on Feb 28, 2009
I have 2 jl-w6 subs n a orion hcca 250 amp how do i run wirering
Hello brianmitchel,
From what I am able to determine, the Orion HCCA250 is a bridgeable 2-channel amp that is stable to 1ohm when bridged and outputs 800 watts RMS into that load.
The JL W6's in both 10" and 12" versions are dual voice coil with 4ohm coils so they can be wired to present either an 8ohm load (series) or a 2ohm load (parallel). They can handle 600 watts RMS.
With this combination, the best configuration would be to wire the sub voice coils in parallel for a 2ohm load and then parallel both subs to the amp bridged terminals for a final impedance of 1ohm. The subs will each be getting 400 watts.
In any event, I would not recommend running subs in series. There is some evidence for distortion being caused by something termed "back EMF".
Hope this helps.
Aug 03, 2009 | Orion HCCA-D5000 Car Audio Amplifier
Orion hcca 250 digital reference & orion XTR 12" 500w dual subs
If you have one sub dual voice coil, just paralel the sub and conect to brigde amp. Simple...
Mar 02, 2009 | Orion HCCA-D5000 Car Audio Amplifier
Orion hcca 250 digital reference & orion XTR 12" 500w subs
the speakers most not go lower than 2ohms.when the amp. is bridge you are connectin 2 channels.your speakers are most important,the impendence of it,in ohms e.g 4ohms or 8ohms.note make shore the amp.can go down to 2ohms when bridge,or connect the speakers in series.if you not shore.
Orion hcca 250
i can make this relatively simple.
2 stages:
Stage (1) wiring the Sub inside the box;
Unscrew the SUB from the Box, (& undo the wires)
Connect both +Positive terminals on the SUB to the +Positive terminal on the inside of your BOX.
Connect both -Negative terminals on the SUB to the -Negative terminal on the inside of your Box,
Then screw the SUB back into the Box.
u Have just wired yr sub in parallel. any Amplifier will see it as 1woofer with 1OHMs resistance.
Stage (2) bridging your amp
(please check Amplifier instructions on which terminals to use)
generally you use "LEFT -Negative" and
"Right +Positive"
and connect to the corresponding terminals on the Sub Box.
Hope that helps someone.
Feb 25, 2009 | Orion HCCA-D5000 Car Audio Amplifier
How to wire 2 dvc subs to a orion 2150sx ? dont know the wire colors or how to hook um to my amp.
what impedence are the voicecoils?
Dual 4 - Dual 2 - Dual 1 ??
Orion SX / GS / HCCA amp Wiring guide:
Orange = Right Positive
Black/ Orange = Right Negative
Yellow = Left Positive
Black/ Yellow = Left Negative
Blue = 1+1
Bridging of SX or HCCA Amps:
1. Use the Orange wire for Positive.
2 Use the Black/ Yellow wire for Negative
3. Push "in" the Mono Button
That amplifier is only 4ohm mono stable - so assuming the subs are dual 4 ohm voicecoils...
First wire both in Parallel Independently So each subwoofer is now a 2 ohm load. (combine + and + - and- on both subwoofers)
Now Take a positive on one voicecoil of sub #1 and attach to amplifier+(orange)
Take a - on that same subwoofer and attach it to a + on the OTHER subwoofer.
Finally, take a - from the second woofer to the amplifier -(black/yellow)
Now you have a 4 ohm load on your bridged channels.
Thanks for using FixYa - a FixYa rating is appreciated!!
Feb 23, 2009 | JBL 1200GTi Car Speaker
Old schoool orion amp 250-hcca
Wiring Codes for SX and HCCA
Black/Orange = Right Negative
Black/Yellow = Left Negative
Blue = Remote Turn On
You can remove the bottom of the amp and the colors can be deciphered as to which goes to which pin in the plug. Go to this link on AmpGuts for a reference.
http://www.ampguts.realmofexcursion.com/Orion_HCCA250/
And here is a link where you can buy a new plug on ebay for $25.
http://cgi.ebay.com.my/ws/eBayISAPI.dll?ViewItem&item=110093583828&indexURL=
Dec 05, 2008 | Orion Car Audio & Video
Orion hcca 12d subwoofer wiring
I had two of those they are awsome subs! anyway your best to connect them in parallel that is both positive wires connected together and both negative wires connected together then connect pos and neg to amp in a bridged configuration if its a 4 channel amp - this will put your subs under a 2ohm load and make sure you turn down gain and set your filter to low pass (very important!) turn up gain in increments till your happy :) rock on!
May 04, 2017 | Car Audio & Video
Orion 250G4
Generally to bridge an amplifier you need to insert the positive wire from the sub to the positive wire on the first channel. And then insert the negative wire from the sub to the second channels's negative terminal.
Apr 22, 2008 | Orion HCCA 225G4 Car Audio Amplifier
Orion HCCA-D5000 Car Audio Amplifier Logo
550 people viewed this question
Top Orion Car Audio & Video Experts
Tygh Duval
Tygh Duval
Steve Sweetleaf
Steve Sweetleaf
Are you an Orion Car Audio and Video Expert? Answer questions, earn points and help others
