Question about Dell 924 All-in-One InkJet Printer
Dell 924 dell printer head ;error 1203;change cartri... sane problem.help|| black will print but color wont print' correct cartridge is inserted ,still color wont print. warning was ignore that ink was low
  • Anonymous Mar 20, 2014
    what is 016-720 error on a dell 255cn printer
Hey do a power drain by removing all the cables from the rear of the printer and then hold the power button on the printer of 15-20seconds with all the cable out connecting the printer... Then power on the printer if you still see the error code message displayed on the printer display screen do a nozzle clean in the computer, check on if the printer prints the nozzle clean test page perfectly.If not remove the cartridges and clean the nozzle of the cartridges with a clean cloth and be careful so that you do not destroy the copper contacts, clean the same you see on the carrier(where you place on the cartridges). I think this should work.
If not call in technical support.
Regards,
Dev,
Printer Technician.
Posted on Feb 27, 2009
I have the Dell AIO 926 and i have an Error Message. Error 1203 Consult User's Guide I cannot print, what do i do?
error 1203's error name is print head short which indicates a short circuit in the print head has occurred. solution to this problem is to disconnect and then reconnect the printer power cable. Reinstall the ink cartridges.For more information, see Replacing Ink Cartridges.
  • Turn on your printer.
  • Lift the printer unit, and then position the scanner support between the tabs to hold it open.
  • The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
  • Press down on the ink cartridge lever to raise each ink cartridge lid.
    Remove the old ink cartridges.
  • Store the cartridges in an air-tight container, such as the storage unit you received with your photo cartridge, or dispose of them properly.
  • If you are installing new ink cartridges, remove the sticker and transparent tape from the back and bottom of each ink cartridge.
    NOTE: The following illustration shows a black cartridge and a color cartridge (used for normal printing). For photo printing, use a photo cartridge and a color cartridge.
    Insert the new ink cartridges. Make sure the black or photo ink cartridge is secure in the left ink cartridge carrier, and the color ink cartridge is secure in the right ink cartridge carrier.
    Snap each lid closed.
    Hold the printer unit up, push the scanner support back to unlock it, and then lower the printer unit until it is completely closed.
  • Jun 05, 2011 | Office Equipment & Supplies
    Reading a cartridge error # 1203
    Error 1203 is 'print head has a short'. You have a faulty color or black cartridge... kindly replace the catridge.just try this also,
    Check to see if the installed cartridge is the correct one for the printer. If the cartridge is the proper part number, remove the ink cartridge and make sure all the packaging tape has been removed from the copper circuitry strip on the backside of the cartridge. Reinsert the cartridge and try printing again.
    If the error continues, remove the cartridge again and clean the copper circuitry strip on the backside of the cartridge, and the contacts inside the printer, by following the instructions below:
    1. Use a clean, dry, soft, lint-free cloth. Locate the copper-colored circuitry strip on the back of the cartridge.
    2. Wipe the copper-colored strip with the dry cloth. Use an upward motion, from the nozzle end to the top of the cartridge. Do not wipe the nozzle end of the cartridge or touch the nozzle plate. Wipe the contacts only once.
    3. To clean the printer contacts, carefully look for fibers or contamination on the electrical contacts inside the carriage assembly, but do not wipe the printer contacts with any object. The contacts in the printer can be damaged if too much pressure is applied during a wiping process. Try to remove any visible attached debris within the carriage assembly by gently pulling the debris off with your fingers. If the carriage contacts show noticeable damage, contact the Customer Care Center listed in the printer's User's Guide.
    Reinsert the cartridge and try printing again. If the error continues, the cartridge may need to be replaced.
    Hope this helps. Please rate my response.
    Thanks.
    Have a good day.
    Sep 23, 2010 | Dell 924 All-in-One InkJet Printer
    Trying to insert new ink catridges
    I think it will do the trick for you try this.
    Error 1203 is an issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad...
    1 - try cleaning the copper contacts of the both carts and cart slot in the printer and try again..
    or
    2 - when error shows up, shut the printers power off; wait one minute and turn it back on press copy.
    Mar 31, 2009 | Dell 924 All-in-One InkJet Printer
    Cartridge error #1203
    or
    It may work , worth a try
    Jan 29, 2009 | Dell 924 All-in-One InkJet Printer
    Dell Printer 926 Error 1203 "Print Head Short"
    Error code 1203 means that you have a print head short error. The way to fix this is to:
    1) Clean the contacts on the cartridge w/ a damp cloth. Only do it in one direction so that you're not smearing ink all over the contacts!
    2) Disconnect and then reconnect the power cord from the wall and from the back of the printer. Wait about 30 seconds, and then plug everything back in.
    If this doesn't work, you may need to replace the ink cartridges...you can always try it one more time just to be sure
    Jan 09, 2009 | Dell 924 All-in-One InkJet Printer
    Dell Printer 924 error #1203
    go to page 59 of the manual ("http://support.dell.com/support/edocs/systems/924/en/om_en/om_en.pdf" if you don't have it) look for
    code 1203 in the middle of the page. good luck!
    Nov 16, 2008 | Dell 924 All-in-One InkJet Printer
    I am getting a message error 1203
    Try this first see if it will help.
    ERROR 1203 LEXMARK ERROR 1200 Error 1203 is an issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad...
    or
    Aug 02, 2008 | Dell 924 All-in-One InkJet Printer
    Error message 1203
    This link should have the answer for you.
    http://www.dellcommunity.com/supportforums/board/message?board.id=A940&message.id=13761
    Jul 27, 2008 | Dell 924 All-in-One InkJet Printer
    Dell Printer 924
    Please try this
    or
    Jun 24, 2008 | Dell 924 All-in-One InkJet Printer
    Dell All-in-one 924 error: "right cartridge is incorrect"
    Hi ,
    if you are getting the error msg 12203 , pperform the following steps,
    remove both the cartridges from the printer and unplug the power adapter ( black box) from the back panel of the printer, clean the cartridges using a damp cloth .
    initially put only the black cartridge and then turn on the system , it will give you the error msg right cartridge missing, you can ignore it and try copying a document .
    remove the black cartridge and put the color one in, and then try printing.
    during the printing with any of the cartridge inside the printer if it gives out the error msg 1203 then that cartridge has to be replaced...
    Mar 05, 2008 | Dell 924 All-in-One InkJet Printer
    Dell 924 All-in-One InkJet Printer Logo
    244 people viewed this question
    Top Dell Office Equipment & Supplies Experts
    jasbo
    jasbo
    Electro Med Services...
    Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
