Question about Canon Pixma MP500 All-In-One InkJet Printer
My printer does not open
I am using the printer since only 1 month, and the box on top does not open? I don't know what i should do? I want to replace the ink, but the printer does not open.
    Problem Solver:
  • 15 Answers
Hold the leading edge of the printer just under the LCD display in the front. Lift upward with a firm motion and the lid will swing up upwards. Allow the cartridge carrier a few seconds to stop after it makes its side-to-side motions. You are then free to push the release on the top, front part of the ink cartridge and change out any of the empty cartridges. If you take more than a few minutes to complete this change the printer will move the carrier back to the far right side and not be accessible. If that happens, simply close the lid and reopen to allow the carrier to reposition to the middle of the printer.
Posted on Mar 01, 2009
How do i do a print aligennment on a hp deskjet 6540
The printer automatically aligns the print cartridges after a new print cartridge is installed. You can also align the print cartridges at other times to ensure optimal print quality.
To align print cartridges:
1. Load letter-size or A4-size plain white paper in the In tray.
2. Open the printer Toolbox.
3. Click Align the Device.
4. Click Align , and then follow the onscreen instructions
Here are directions for how to open the printer Toolbox, in case you don't know:
The printer Toolbox contains a number of useful tools to enhance the printer performance.
Use the printer tools to perform the following tasks:
• Set the Auto-off function
• Clean the print cartridges
• Align the print cartridges
• Calibrate color
• Print a test page
• View estimated ink levels
To use the tools, open the Printer Properties dialog box, click the Services tab, and
then click the Service this device button.
AND, in case you don't know how to open the Printer Properties dialog box, here you go! :
The Printer Properties dialog box is also referred to as the Printer Preferences dialog box.
Opening the Printer Properties dialog box
Follow these steps to open the Printer Properties dialog box:
1. Open the file that you want to print.
2. Click File , click Print , and then click Properties or Preferences.
Good luck to you! I hope this helps.
Aug 07, 2014 | HP DeskJet 6540 InkJet Printer
Why Canon MX310 won't scan error 114.0. how to fix
I have this copier too but only use it as a copier in my classroom. It's a stand alone. But can't print. There is no software to install on a computer so I don't know how to fix it if there's no software.
Feb 26, 2012 | Canon PIXMA MX310 All-In-One Printer
L have an HP2420 with the usual line down the left side 1.5 inches from the edge. I cleaned whatever I could see and it is less but still a faint line. We don't have high volume, use only HP cartridges...
Run a "half test". Put paper in the manual feed tray(tray 1). Print anything. Watch the paper. When it gets about 1/2 way into the printer, open the top cover. Remove the toner. Look down at the paper. Do you see the "usual" line? If yes, replace the toner cartridge. If no the fuser is probably bad.
Aug 30, 2011 | HP LaserJet 2420 Printer
I can't show ink detail. So, i don't know what time can i change cartridge. I wanna to know how to solve this problem. thanks
1 Check the back of your computer to make sure that the printer is appropriately connected to the computer and is plugged in. If the printer is not plugged into the computer, find the printer jack on the back of the computer and plug it in before you move on to the next step.
2 Click on the "Start" menu button which is located on bottom left hand corner of your screen. Click on the "Settings" bar and notice that a list of functions pop up to the left of the settings button. Click on the control panel icon.
3 Look for the printer/fax icon in the control panel window. Double click on the printer icon.
4 Find the icon for your printer in the opened window and right click on the icon. Now click on the "Preferences" option.
5 Look for the menu box pop up with tabs near the top of the box. Click on the "Services" tab.
6 Click on "Service this device." You will find the button on the Services menu that you just activated.
7 Click on the estimated ink level tab and a graphic will appear indicating how much ink is left in the cartridge.
Jun 24, 2011 | HP DeskJet 3535 InkJet Printer
Type in your email and password into the two boxes labeled as such in the upper right corner and click the login button
May 02, 2011 | Facebook Social Network
My canon printer ir 2022 prints faint and blank pages, what can be a problem and how can i fix it?
Possible Problems:
1)Out of / Low on Ink.
Solution : replace the ink
2)Printer Setting
Solution : Check to make sure the lighter/darker slider is somewhere near the middle. This will be in the configuration screen on your printer.
May 02, 2011 | Canon iR 2022 Printer
HP4-smudged copies of printed text are appearing lower on the page...Any ideas on the fix
Run a 1/2 test.
print something. And watch the paper. As the paper gets
about 1/2 way into the printer, open the top cover, remove the toner.
Look down at the paper. If you don't see smudged text, the fuser is probably bad.
If you see the smudging, replace the toner.
Dec 02, 2010 | HP : HP4 Laserjet Printer
Canon LBP2900 printer but i don`t know how to print back to back
I take it you are using windows,
Open control panel, open printers and faxes, right click on your printer icon.
Left click on properties, left click on printer preferences, left click on page setup, down near the bottom there is a box called duplex printing, tick that and you are on the way.....
Jan 19, 2010 | Canon Office Equipment & Supplies
Thinking of buying this printer!
This printer will require 2 different cartridges. 1 Black Ink tank - Canon PG-37 and 1 Color Ink tank - Canon CL-38. It will come with those already in it but most people don't know that they aren't completely filled from the factory. You might get about 1/3 of it to get you started and you'll quickly need to buy a refill so you might as well get it while you're there. You should also keep the top of each box in your wallet for easy reference next time you have to repurchase the ink. Finally, a caveat- with inkjet (as opposed to laser toner) it's use it or lose it as they will dry out over a few months even if not used.
Please rate this solution accordingly! Thanks and keep in mind with any future questions.
Jan 10, 2009 | Canon Pixma iP2600 Photo InkJet Printer
Canon Pixma MP500 All-In-One InkJet Printer Logo
24 people viewed this question
old marine
old marine
