Question about Denon DP-29F Turntable
Won't stop turning
It seems like the wheel isn't connected to the needle; as soon as I plug the player in (DP 29F, Denon) it just starts turning, the needle doesn't come over.
  • Anonymous Mar 15, 2014
    I need a new transformer
  • 23 Answers
There are some gears which move back and forth under the turntable which link to the plated  Sometimes they just get stuck, sometimes just reseting them will resolve the issue. Sometimes you need to lubricate them since they a just getting stiff (only lubricate the center of the gears by the shaft they set on) It is rare that any parts are actually broken PS Protect the needle while attempting to service the unit Rob
Posted on Feb 27, 2009
Adjust pitch
Register (free) at Vinyl Engine and download the service manual. The adjustment you need to do seems fairly simple. You will need a turntable strobe disk to get the the speed right, unless you have perfect pitch.
http://www.vinylengine.com/library/denon/dp-29f.shtml
Jun 19, 2014 | Denon DP-29F Turntable
Change stylus
You can download the owner's manual from:
Free registration is required before you can download.
Jun 01, 2014 | Denon DP-29F Turntable
Denon dp-29F won't turn
hit it with a hammer...............
or the other option is to switch off the unit at the wall, then switch it back on again.
Dec 06, 2013 | Denon DP-29F Turntable
No sound when i connect my denon-dp 29f turntable to denon rcd-m39 receiver. what might be the reason? Wrong receiver?
If your receiver ain't has a phono input and the tt has only a phono output, you'll need a phono to line line riaa amp , between the units.
Oct 26, 2013 | Denon DP-29F Turntable
DP29F turntable has static
either you haven't earthed the deck to the amp, on the proper ground screw, or your head shell wires are touching.
if the cartage(the thing the needle slots into) unscrews from the tone-arm, try unscrewing it,then putting back on, nice & tight....
if it still does it then it's your RCA leads that go from the deck to the amp(phono cables).
normally you would wire a deck/decks to a mixer first, then from the master out on the mixer to the AUX IN on the amp.
Oct 21, 2012 | Denon DP-29F Turntable
The belt jumped. how to put it back
take the platter off by lifting it off the center pin,put the belt back round the runner on the platter,then put the platter back on, find the hole on the platter, then turn the platter until you see the motor wheel,put the belt over the wheel.
Jul 07, 2012 | Denon DP-29F Turntable
My drive belt came off i do not know how to put it back on please help! I have a Denon - Fully Automatic Turntable System - DP-29F It doesn't give me much help in the instructions on how to put it back on.
1. Remove the rubber disc from the metal platter.
2. Remove the metal platter by pulling straight up.
3. Ignore the player for the moment; focus on the platter.
4. On the underside of the platter is a circle about 2 inches smaller than the platter; stretch the belt around that inner circle. Make sure it is not twisted.
5. Put the platter back on the player. Rotate the platter so that one of the rectangular holes reveals the drive wheel.
6. Stretch the belt so that it goes around the drive wheel (I used a pencil but tweezers would likely work well).
7. Replace the rubber disc.
Mar 23, 2011 | Denon DP-29F Turntable
Denon DP-29F belt is loose
please not this is when first set up but may help
The drive belt is fitted under the platter. When assembling the
player, please handle the drive belt with care.
• Remove all packing materials attached to the tone arm, except
that on the stylus, and then open the dust cover and assemble.
Remove the stylus cover after assembling.
Hold the platter by the holes at its outer surface, and
then carefully lower the platter so that the center
spindle enters the center hole.
Rotate the platter until one of its outer openings is
aligned with the driving roller. (Refer to illustration.)
Gently grasp and pull at the ribbon tape of the drive
belt that is would under the turntable, and then
extend the belt around the driving roller. (After
attaching, remove the ribbon tape.)
In order to make sure that the drive belt has been
correctly fitted, slowly rotate the platter 3 or 4 turns.
Place the rubber mat on the platter.
IMPORTANT! Please Check.
Check that the drive belt and ribbon tape have been attached
under the platter. Grasp the ribbon tape as shown in the
illustration to the left, and extend it onto the driving roller.
L
R
L
R
L
R
ENGLISH
3 CONNECTIONS
Jul 04, 2009 | Denon DP-29F Turntable
Denon DP-29F Turntable Logo
193 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
