Question about Kenwood KM800 Major Classic Stand Mixer
I have a Kenwood Model KM800 mixer with a "K" beater. I washed the beater in the dishwasher and it now has black residue on it. Is it salvageable? I have washed most all of the black stuff off. Should I soak it in vinegar or what? Please advise. Thanks in advance. Glenn Miller
  • 3 more comments
  • gmiller1932 Feb 27, 2009
    The black stuff is NOT grease. I believe it is a reaction to the dishwasher soap.
    You still seem to think it is grease - it is NOT grease but a reaction that occurred when I washed the K mixer tool in the dishwasher.
    I thought I was supposed to get help from FixYa, instead you advise me to contact the manufacturer. I don't believe I should be charged for that advise.
    It's not the mixer that is in question but the "K" BEATER. You advise me to go to the Kenwood site but you give me the wrong site. I want my money back!!!!
  • louiselat May 15, 2009
    My k-beater has done the same thing - after 20 years of great use. I think the metal has for some reason is oxydizing, causing this black film. It is not hard to wipe off, in fact it comes off on my hands all too easily causing quite a mess. I would like know how to stop this from happening. The cake beater and dough hook, made out of the same metal are just fine. Perhaps I should try and annodize it?
  • 257 Answers
Hi Glenn,
The discoloration is a chemical reaction that is harmless but unsightly. Have you ever used a metal utensil in a ceramic mixing bowl? It leaves marks that looks like the metal came off, which it didn't. Try as you might you will discover that you can only remove some of the marks just as you experienced. Another example would be hot tomato sauce and a plastic spatula, not a chemical reaction but the heat penetrates the plastic and allows the stain to set, Unsightly yes, usable yes, fixable no. I wish you could get a better answer but it is what it is. I'm sorry we couldn't Fixya!
Posted on Feb 27, 2009
  • 728 Answers
Let it sit in hot water for about ten to fifteen minutes which should make the black stuff easier to wipe off, and try to wipe off the residue. If you say you wiped off most of the black stuff, it is most likely not a reaction from the dishwasher soap. If it still does not come off, try soaking it in CLR which should remove all of the residue from it. Then hand wash it and it should be back to normal.
    Genius:
  • 1,011 Answers
Sir,
Clean it with baking soda.... it will solved
thanks good luck
  • Kenwood Master
  • 19,396 Answers
Try rubbing the mixer with isopropyl alcohol, this can solve and remove many plastic materials.
Walgreens Apothecary Isopropyl Alcohol 91% 16oz
If that does not work , contact Kenwood here, this is not a common problem.
  • Ginko
    Ginko Mar 06, 2009
    Well , the K beater is made by kenwood : Kenwood K beater.
    You still need to contact Kenwood to get part and support.
    Now that you have obtained refund as from term and conditions, I will be grateful if you can change the negative vote you gave us.
    Many thans.
  • 1,800 Answers
The substance is a liquid grace melanged with a soap and water:
just let it till dry use a hairdryer to help it to dry just plz do not plug it to an electric outlet so a short out wont occur!
  • 2 more comments
  • Jalal Sordo
    Jalal Sordo Feb 27, 2009
    just let it dry till the stream of the black liquid stops dont plug it to power the unit will work fine plz do not touch it till tomorow or use the hair dryr to help it dry!
  • Jalal Sordo
    its the gear liquid its black there is a small outlet where u can put oil in that unit
  • Jalal Sordo
    also its a combination of dust and old dirt that was in the rotor part.
    the bad news if the water streams inside the board u shud take it apart and start drynig it!!
  • Jalal Sordo
    its easy i told u how to deal with such as a problem LET IT DRY for god #@\`: what do u want more??
    Brigadier General:
  • 5,158 Answers
That black residiue is the grease for the gears... you need to take it apart again and grease it... graphite grease i believe
  • Roberta Smith
    Roberta Smith Feb 27, 2009
    just use rubbing alchohol and a cloth then to clean it
  • 203 Answers
If it is just a taint to the metal of the beater itself it will be a reaction on the metal. you could soak it in vinegar or a metal cleaner but the stain may not come off. some metals tarnish and the mark will be in too deep to remove. i dont think it will cause an issue when using. its just a stain.
  • sean sutton
    sean sutton Feb 27, 2009
    you do not need to contact anyone. you have stained the steel itself and i do not think you can remove the stain. it is nothing to worry about.
    Top Expert:
  • Kenwood Master
  • 77,499 Answers
Why not call the manufacturer and tell them your problem and have them advise u on how to handle this problem, after all it is there product and they would know the best course of action,
  • yadayada
    yadayada Feb 27, 2009
    very sorry just trying to help, have u ever used a product called Goof-off, avail at most hardware stores, it will dissolve almost anything organic like what you are dealing with, it is non toxic.
My detachable draft shaft burned by my stove where can i buy a other one
I think your talking about the beater shaft. I can not relate to the draft shaft and I have been around a long time. This site has loads of KM800 parts in the UK. FYI Delonghi bought out Kenwood and getting parts in the US is through Delonghi. Their phone service takes forever!!!!
Try browsing this site:
http://www.4kenwood.co.uk/cgi-bin/catalogue.pl?pg=17&section=345619&path=345550,345619
There are 260 items for the Kenwood KM800 there
Thanks for choosing FixYa.
Kelly
p.s. Watch as your looking through the items. Many of them are no longer available.
Aug 20, 2010 | Kenwood KM800 Major Classic Stand Mixer
I have Kenwood Major Classic (Grey colour) will a mincer A720
Hi. I've checked the Kenwood Service website and from what it looks like, A720 mincer is only suitable for A701, A701A, A702, and for Major models A707, A707A, A717.
The mincer specified for the KM800 (from it's owners manual) is the
A950.
May 20, 2010 | Kenwood KM800 Major Classic Stand Mixer
Kenwood chef a701 beater shaft is broke can i buy a new one
yes go to kenwood web site look for dealers who still support a701 mixers.
Apr 06, 2010 | Kenwood KM800 Major Classic Stand Mixer
My KitchenAid Professional 6 mixer has been used about 2 years. Lately it leaves a black trail in my icing/batter/whatever from the finish being worn off the metal beater--the triangular one. The bowl has...
It sounds like you have two problems. First, the black marks are usually because of a reaction between the beater and certain chemicals used in dishwashers. Try washing the beater by hand and scrubbing it throughly to remove any residue. If this works, don't use the dishwasher again. You could also buy a plastic coated beater.
It also sounds like the bowl height needs adjusting. There is a screw just under the head for this.
Jan 08, 2010 | KitchenAid K5SS Heavy Duty Commercial...
I recently bought a used 901 Kenwood mixer from a second-hand dealer. The attachments seem to have a coating which may be deteriorating, as a black, greasy smear appears when I wash them. Any ideas ??
Yes its when the attachments have been through a dishwasher it damages the surface. you can still buy new attachments you have to change the shaft from the old attachment to the new one
Nov 28, 2009 | Kenwood KM800 Major Classic Stand Mixer
New Kenwood chef km 001 - I can't get the beaters out!
Try turning the beater in the reverse direction to the direction it normally turns - clockwise looking at the beater (I think), this should make the shaft pins ride up on some cams which should release the beater.
Sep 23, 2008 | Kenwood KM800 Major Classic Stand Mixer
Beaters fall down
You have to change the planet hub and the beater.
Nov 06, 2007 | Kenwood KM800 Major Classic Stand Mixer
Kenwood KM800 Major Classic Stand Mixer Logo
633 people viewed this question
Top Kenwood Food Mixers Experts
ashburton
jason
Are you a Kenwood Food Mixer Expert? Answer questions, earn points and help others
