Question about JBL On Stage Micro Portable Speaker Dock for Apple iPod - Black
Will the jbl on stage micro charge the new ipod touch
I purchased the jbl on stage micro and befor I open it I want to be sure that my new ipod touch will play and charge in this speaker. I'm pretty sure it will play music, but I can't be sure that it will charge my ipod while docked. Please help.
  • Anonymous Mar 27, 2009
    I have the same problem and here's my answer from JBL.
    Good evening and thank you for your inquiry. The JBL On Stage was made
    in 2004. It is not compatible with the new iPod touch using the dock.
    For audio you would need to use the auxiliary connection and connect
    that to the headphone jack of your iPod touch.
    I hope this helps.
    Best Regards,
    Vu Le
    Internet Support Specialist
    Harman Consumer Group
    Northridge, CA
    The cable was included with the JBL On Stage package. If you lost
    it, you can purchase another one from your local electronics retailer, such as
    Best Buy or Radio Shack. It is a standard 3.5mm male to male
    cable.
    I
    hope this helps.
    Best Regards,
    Vu Le
    Northridge,
    CA
  • kellybohemia
    kellybohemia Jan 27, 2013
    How do I set up the remote it came with?
I can tell you that I have the on stage micro, bought this past winter. And it does charge my iPhone 3G. Works great, I love it.
Posted on Jun 19, 2009
It charges my Touch!
Posted on May 01, 2009
I am thinking of getting and Ipod touch 3G. I have JBL on stage micro Speakers. I've charged a Ipod touch 2G, but I want a 3G! Please Help!
When the OnStage speakers first came out, the charger was not compatible with 3g iPods or iPhones. Newer speakers have an upgraded charger and will charge all current iPods/iPhones (up to and including iPhone 3Gs)
Bad news is that there's no way to upgrade an old OnStage.
You can test yours by trying an iPhone 3G (if you have a friend with one, for example) to see if you have the old or the new charging circuit.
Jan 23, 2010 | JBL On Stage Micro Speaker Dock for Apple...
Ipod does not charge - ipod and speakers are new
Hello :
You have problem with the charging jack . Take it to the service .
good luck .
please rate !
Nov 01, 2009 | JBL On Stage Micro Speaker Dock for Apple...
IPod Adapters problem
just go to jbl's website there download a pdf regarding the dock adapter or 5742d08.jpg
Aug 01, 2009 | JBL On Stage Micro Speaker Dock for Apple...
JBL on stage micro will not charge my ipod any more. It plays songs fine from the ipod but for some reason is not charging it. Any suggestions?
The JBL Onstage Micro is supposed to disable recharging of the iPod when running off AAA batteries to avoid draining them, but sometimes this setting gets stuck even when the unit is plugged in through the AC adaptor. The workaround that I found is pulling out and reconnecting the iPod to the Onstage Micro (while both are powered on) and then unplugging and reconnecting the AC adaptor. Sometimes you have to repeat this process, but the iPod should start recharging after that. I tried it on the new 5th generation nano and this seems to work.
Jun 14, 2009 | JBL On Stage Micro Portable Speaker Dock...
When plugged in, the ipod batteries go low immediately.
The JBL On Stage Micro is supposed to disable recharging of the iPod when running off AAA batteries to avoid draining them, but sometimes this setting gets stuck even when the unit is plugged in through the AC adapter. The workaround that I found is pulling out and reconnecting the iPod to the Onstage Micro (while both are powered on) and then unplugging and reconnecting the AC adapter. Sometimes you have to repeat this process, but the iPod should start recharging after that. I tried this on different versions of the iPod nano and this seems to work.
Apr 16, 2009 | JBL On Stage Micro Portable Speaker Dock...
Will not charge a ipod touch 2
If you're willing to spend $40, there's an adapter available from Scosche Accessories. It comes in both black and white and they say it will convert any docking device to the new charging format. (The problem is that Apple has discontinued charging via the FireWire pin - which virtually all accessories - even including Bose - have used up to now. All the 2nd Generation stuff now uses direct USB charging, not FireWire.
Check out the convertor at:
http://scosche.com/products/sfID1/210/sfID2/339/sfID3/318/productID/1694
Dave
Dec 29, 2008 | JBL On Stage II with Remote Remote Control...
Compatability with 4th gen nano
I have had exactly the same problem having bought a JBL Radial Micro for my partner for Xmas for use with the Ipod Nano, i contacted JBL via their website and was advised to contact Harmen on 01707278100. I was advised that the new ipod nano (chromatic) would not charge on the JBL radial micro. They stated that this was due to Apple changing the charging pin in the new nano. I have since bought a JBL Stage III. I contacted Harmen before buying this and was advised that the Stage II would not work. Hope that this is of use.
Sep 26, 2008 | JBL (JBLRADIALWHT) Speaker System, Docking...
JBL On Stage Micro Portable Speaker Dock for Apple iPod - Black Logo
1,786 people viewed this question
Top JBL Audio Players & Recorders Experts
Michael Edwards
Michael Edwards
Level 1 Expert
 Grubhead
Grubhead
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
