Question about Canon Firestore FS-4 Pro Edition (0736B002) Hard Drive
Firestore FS-4 pro Audio sync problems
After transferring video recorded on my FS-4, audio does not sync up in Final Cut Pro. Is this a drop frame/non-drop frame problem? I can't get it all to come together.
  • Anonymous Mar 11, 2009
    I encounter the same problem with my FS-C when connected to my Canon XH-A1 (PAL 25 fps). The audio is delayed 2 frames behind the video.
  • Anonymous May 19, 2009
    Canon xhg1 and fsc are always out of sync bu 2-4 frames why??
SOURCE: Get Final Cut Pro 5.04 to communicate with my XH A1
Many HDV cameras and decks are able to play and record DV as well as the higher-resolution HDV format. Additionally, many of these HDV devices will attempt to automatically change their settings to match the format of the tape that it's playing. Here are some tips for using these types of devices with Final Cut Pro / Final Cut Express.
Tip: Make explicit settings on your HDV device. Instead of using an "Auto" setting, make your own settings on your HDV device to keep the communication going between it and Final Cut Pro / Final Cut Express. This also helps Final Cut Pro / Final Cut Express keep things running smoothly with HDV devices that handle both DV-NTSC and DV-PAL.
For example, say you're using an HDV deck to capture footage from a tape that was recorded as DV-NTSC. Before capturing in Final Cut Pro / Final Cut Express, make sure that you set the deck to DV mode specifically—don't rely on Auto mode. With some devices, you may need to disconnect it from FireWire to change the mode.
For a common capture workflow, this sequence of steps can provide the best results:
  1. Quit Final Cut Pro / Final Cut Express if it's open.
  2. Insert your tape into your HDV deck or camcorder.
  3. Use the device's menus to set it to match the format that's recorded on the tape.
  4. Connect your HDV device to your computer with a FireWire cable.
  5. Open Final Cut Pro / Final Cut Express.
  6. Choose an Easy Setup for DV or HDV (whichever matches the format recorded on your tape).
  7. Proceed to Log and Capture.
Tip: Quit Final Cut Pro / Final Cut Express before changing modes. It's generally a good idea to quit Final Cut Pro / Final Cut Express before you change the mode on your device from DV to HDV, or from HDV to DV, and then re-open the application again.
Tip: Use an Easy Setup to play back non-default HDV format footage on your HDV device. You can use Final Cut Pro / Final Cut Express to make your HDV device play back footage in its non-default HDV format. For example, maybe you have a 1080i60 HDV device and want to play back footage that was recorded as 1080i50. Or perhaps you have a 1808i50 HDV device and you want to play back footage that was recorded as 1080i60. To do this, follow these steps:
  1. Connect your camera to your computer.
  2. In Final Cut Pro / Final Cut Express, choose an HDV preset Easy Setup that matches the format of the tape's footage (you don't need to restart Final Cut Pro / Final Cut Express).
  3. Your device's LCD display should automatically display a switch to 60 or 50, indicating the type of media that's being played.
Playing back non-default DV format footage on your HDV device You can also use your HDV device to play back footage in its non-default DV format too. For example, maybe you have a 1080i60 HDV device and want to play back footage that was recorded as DV-PAL. Or maybe you have a 1080i50 HDV device and want to play back footage that was recorded as DV-NTSC. If so, follow these steps:
  1. Make sure that your device is in DV/DVCAM mode.
  2. Put your device into Play/Pause mode, then open the Log and Capture window in Final Cut Pro / Final Cut Express.
  3. Make sure that your device's LCD (or other readout screen) displays the same format as your tape or Final Cut Pro / Final Cut Express will misinterpret what type of device you have.
Tip: Avoid recording both HDV and DV formats on the same tape. Use separate tapes whenever you want to record in a different format. If you need to record over existing footage in a different format (for example, you have a tape with DV-PAL on it, but you want to record over it with HDV 1080i50), it's a good idea to black and code the tape, or completely record over the old footage with contiguous recording in the new format. If the tape contains even a second of, say, DV in the middle of an HDV tape (or vice versa), it could cause unexpected results later when you try to capture video from that tape.
For more information, see HD and Broadcast Formats and the Final Cut Pro / Final Cut Express User Manual, available under the Final Cut Pro / Final Cut Express Help menu
Posted on Dec 04, 2007
SOURCE: DV In flashing when plugged into computer
Dear njfire,
Test or change your cable !!
(Cable is IEEE 1394 and/or Firewire and/or I.Link, 4-4 pin)
Regards
Posted on Jun 28, 2008
  • 6 Answers
SOURCE: Firestore FS-4
Try a factory reset - it will probably fix the problems you're seeing. These are the instructions I got from Focus Enhancements: FACTORY RESET
a. With the Firestore powered OFF.
b. REMOVE the “battery” and connect the “AC Adaptor”.
c. Press and HOLD down the "ON” and “OFF” buttons for 15' seconds, then release just the “ON” Button.
d. Count to five (5) then release the “OFF” button.
e. The Firestore should be powering back up to the home screen.
(It takes the firestores settings back to the normal setup. This "will not" erase any current footage on the drive) (You may have to re-do current update/upgrade version)
Posted on Aug 27, 2008
SOURCE: Firestore FS-4 does not show up when connected
I own three FS-4 and one of them has the same problem. Two of them connect no problem. The third one says the connection is successful but windows doesn't recognize it. After playing around a bit it appears that I am not getting a good connection with the 6 pin firewire output on the Firestore. I find that with repeated attempts and carefully holding the cable in various positions, I eventually get it (reminds me of analog TV antennas when you have to be in just the right position to get a channel in clearly). The good news is, once it is recognized, it stays recognized until the need for the next download.
So for my unit, I think I simply have a bad jack. Hope this helps.
Lance
Posted on Jan 23, 2009
smartr10U
  • 1305 Answers
SOURCE: My Canon PowerShot not recording audio
Try to reset the camera to default settings.... go to the menu and look for the reset default on the menu...that should override any accidental settings or mutings and get you back if the microphone is still functioning..
K
Posted on Aug 05, 2009
Does Nikon D7000 MOV workable in FCP 6?
MOV format with Prores codec is FCP 6preferred video. So a program which has prores codec output is greatly helpful.As far as I know, two apps can export Prores codec video. One is Clipwrap andanother is Video Converter released by Pavtube. Clipwrap can not achieve yourtask because it only supports AVCHD videos. So please test Pavtube VideoConverter to check if it is helpful. It provides free trial version in Pavtubesite.http://www.pavtube.com/video-converter-mac/
Jun 11, 2012 | Cameras
Tip
Best Conversion to ProRes 422-Convert/Merge Flip Videos to ProRes MOV for FCP on...
The <b>Flip Video</b> is a camcorder for digital video created by Pure Digital Technologies. Variants include the Flip Ultra, the Flip UltraHD, the Flip MinoHD (1hr), the Flip MinoHD (2hrs) and the Flip SlideHD. The great Flip Video camcorders record videos in 640&times;480 resolution at 30 frames per second, using the MPEG-4 ASP video compression. The high definition versions record at 1280 x 720 resolution using H.264 video compression, AAC audio compression and the MP4 file format. <br /><br />However, Flip Video can not edit in iMovie, FCP, FCE etc. How to convert Flip Video to iMovie, FCP, FCE etc for editing Flip Video easily? <br />Now with <b>Aunsoft <a href="http://www.aunsoft.com/video-converter-mac/">Mac Flip Video Converter</a></b>, you can convert Flip Video, Flip HD Video files to Apple ProRes 422 MOV, ProRes 4444 MOV, Apple Intermediate Codec MOV etc with no loss of quality for above uses. At the same time, you can get perfect video/audio synchronization, fast conversion speed and editing your Flip Video by trimming, cropping, merging, adding watermark, effecting and more. <br /><br />Below is the step-by-step guide for you to quickly <b><a href="http://canon-videoconverter.com/2011/06/best-conversion-to-prores-422-convertmerge-flip-videos-to-prores-mov-for-fcp-on-mac/">convert Flip Video to ProRes Codec on Mac</a> (*.mov)</b> for editing in Final Cut Pro. <br /><b>Step1:</b> Download, launch the Aunsoft Flip Video Converter and add your Flip Video files to the program. <br /><b>Step 2. Choose Final Cut Pro-Apple ProRes (*.mov) output format.</b> <br />Click the "Format" option and navigate the mouse cursor to <b>Final Cut Pro &gt; Apple ProRes 422 (*.mov)</b> as output format. The Mac Flip Video to FCP Converter will <b><a href="http://www.aunsoft.com/video-converter-mac/">convert Flip Video to Apple FCP ProRes MOV</a></b> with high quality. (<b>Tip:</b> The Apple ProRes (*.mov), DVCPROHD (*.mov), HDV (*.mov) formats under Final Cut Pro output profile are available when your FCP is installed on Mac). <br /><br />Step 3. <b>Merge Flip footage Video files. (optional)</b> <br />Tick the checkbox for "Merge into one file", and the Flip Video to FCP Converter will join and combine the video clips into a single file as output. <br /><br />Step 4. <b>Convert Flip Footage Video to Apple ProRes (*.MOV) for Final Cut Pro</b>. <br />Click the convert button under the preview window, and the Mac Flip Video to FCP Converter will start the conversion from Flip MP4 Video to Apple ProRes MOV for Final Cut. <br /><br />After the conversion, you can easily <b><a href="http://www.aunsoft.com/video-converter-mac/">Import Apple Prores MOV to Final Cut Pro without rendering</a> for editing</b>. <br /><br /><b>Tips:</b> <br />If you would like to edit Flip MP4 Video with FCE/iMovie, Avid, etc, you can convert Flip Video to Mac itself bring format like Apple Intermediate Codec, DV PAL/NTSC, DVCPRO NTSC/PAL, DVCPRO50 PAL/NTSC (*.MOV) for FCE and iMovie, or transcode flip videoS to Avid DNxHD (*.mov) for Avid on Mac.
on Jun 15, 2011 | Sony Alpha DSLR-A580 Body Only Digital...
Tip
EOS Converter-Transcode Canon DSLR 550D Video to ProRes 422 in Full HD 1080p for...
Convert/Import Canon Rebel T2i/550D 1080/30fps H.264 MOV to ProRes 422 Codec for FCP 6/7 <br /><br />Canon EOS Digital Rebel T2i / 550D recorded videos are saved in H.264 for image and linear PCM for audio. You can choose different recording modes like full HD 1920&times;1080p at 30/25/24 fps, HD/SD 1280&times;720p/640&times;480 at 60/50 fps. Even though the videos are saved in .mov format, you may also face problem importing the video to Final Cut Pro. So you need a Mac Canon EOS Video Converter for converting and importing 550D1080p MOV for Final Cut Pro without rendering. Aunsoft Video Converter for Mac is the recommended <b><a href="http://www.aunsoft.com/video-converter-mac/">Mac Canon EOS Converter</a></b> for you to edit Digital Rebel T2i / 550D videos. <br /><br />Below is the quick guide for those who have a hard time editing Canon EOS Digital Rebel T2i / 550D H.264 MOV files to ProRes 422 at 30fps in Final Cut Pro 6 or 7. <br /><br />Step 1. Download Canon 550D MOV files to Aunsoft Video Converter for Mac. <br />Run Aunsoft Video Converter for Mac as the best <b><a href="http://canon-videoconverter.com/2011/06/convertimport-canon-rebel-t2i550d-108030fps-mov-to-fcp-with-prores-codec/">Canon EOS Rebel T2i H.264 MOV to ProRes MOV converter</a></b> on Mac OS X. Click the "Add" button to import .mov files from the camera. <br /><br />Step 2. Choose MOV format with ProRes 422. <br />Click the "Format" option, and navigate to Final Cut Pro &gt; Apple ProRes 422 (*.mov) as output format. The Mac Digital SLR camera video converter will convert H.264 mov to prores 422 mov. <br /><br />You may notice that there are also other options like Apple ProRes 4444, Apple ProRes 422 (HQ), Apple ProRes 422 (LT), Apple ProRes 422 (Proxy), DVCPRO HD 1920*1080 30fps etc. <br /><br />Step 3. Choose 1080p size with 30fps. <br />Click the "Settings" button and choose 1920*1080 from the video size drop-down box to keep the original HD resolution and 16:9 aspect ratio. Click the drop-down box for frame rate, and you can choose 30fps. <br /><br />Step 4. <b>Convert DSLR video to ProRes 422 HQ MOV for FCP.</b> <br />Click the convert button under the preview window, the <b>Mac Canon 550D DSLR video converter</b> will start <b><a href="http://prores-converter.com/2011/06/eos-converter-transcode-canon-dslr-550d-video-to-prores-422-in-full-hd-1080p-for-fcp-editing/">converting DSLR video to ProRes 422 in full HD 1080p for FCP editing</a></b>. <br /><br />After the conversion, you can import ProRes mov to Final Cut Pro without rendering.Hope you enjoy the optimal way to <b><a href="http://www.aunsoft.com/video-converter-mac/">convert Canon H.264 mov to ProRes 422 for FCP 7 and 6</a></b>, so that you can edit the H.264 files easily.
on Jun 13, 2011 | Sony Alpha DSLR-A580 Body Only Digital...
Audio probelms
You can doremisoft man sansa video converter that can cut your noisy part of your videos.
http://www.doremisoft.net/Sansa-Video-Converter-Mac/
Mar 19, 2008 | Formac Studio DV/TVR (FS 1142-48) Video...
Capturing GR-PD1 Hi-Res clips in Final Cut Pro 6
Check out: http://jvcgr-pd1.blogspot.com/2005/07/dealing-with-pd1s-format-m2t-or-mpeg-2.html Use MPEG Streamclip to convert m2t to a useable file (MPEG).
Aug 27, 2007 | JVC GR-PD1 Mini DV Digital Camcorder
Tip
How to import Kodak video to Final Cut Pro and edit Kodak video with Final Cut...
How to import Kodak video to Final Cut Pro and edit Kodak video with Final Cut Pro?
Final Cut Pro is a professional and all in one video editing, compositing and special effects package for the Macintosh. The software logs and captures video onto a hard drive (internal or external), where it can be edited and processed.
If you are a Kodak video fan and you want to give professional editing to your Kodak videos, Final Cut Pro is the best choice for you. However, Final Cut Pro can edit any QuickTime compatible file format including DV, HDV, MOV, MPEG-4. That is to say, in order to edit your Kodak video with Final Cut Pro, you have to convert Kodak videos to the supported formats by Final Cut Pro with Kodak video to Final Cut Pro Converter for Mac.
Tips:
Kodak records the video files with mov files (i.e. Quicktime files) does not mean they are perfect for editing in FCP. The fact is, all of the small video cams, including the Kodak Zi8 Cams, records highly compressed codecs that are known as delivery codecs, not editing codecs. You need one third-party software to convert HD mov files to some formats like DV, HDV , MPEG-4 that FCP is happy to edit.
Kodak video to Final Cut Pro Converter for Mac is one simple-to-use solution with the minimum amount of buttons and a small menu for converting Kodak video (Kodak Zx1, Kodak zi6, Kodak Zi8 and Kodak PLAYSPORT) to DV, HDV, MPEG-4, etc., for importing Kodak videos to Final Cut Pro. Besides, it is also an easy-to-use editing tool that assist you for making personalized video. You can trim the video to a certain length to convert, adjust video aspect ration by using crop function, add special effect like Gray, Emboss, Old film into video to make it more artistic, join several files or set the video output parameters. All this can be done with a few mouse clicks.
Part one: How to import Kodak video to Final Cut Pro and edit Kodak video with Final Cut Pro?
Step 1:Free download and install Mac Kodak video to Final Cut Pro Converter
Download Kodak Video to Final Cut Pro Converter For Mac and double click the downloaded . dmg files to install. A user-friendly interface will pop up.
Step 2:Load Kodak video files
First: Connect Kodak camcorder to computer and transfer mov files to iMac, Mac book.
Second: Hit the File button on the top left panel or click "Add Video" button to select Kodak MOV files to this converter.
Step 3:Select the output format and destination
Click the downward arrow beside Settings to choose the proper Final Cut Pro format from the drop-down list. And then click Browse button to specify the output location.
Tips: Select DV, HDV or MOV format for FCP in the pull-up list next to Profile field. And then click Browse button to specify the output location.
Step 4:Start the conversion
After all the necessary setting has been done, hit the "Start" button to start converting. Click the Open button to select the converted DV, HDV files to Final Cut Pro for further editing upon completion.
Part Two: Import Kodak videos to Final Cut Pro and edit Kodak video in Final Cut Pro.
Step 1:Import Kodak videos to Final Cut Pro
Launch Final Cut Pro and click "Import"-"Files" and then select the converted Kodak files. Find the file in the resources list for the project and drag the file into the Timeline, and then save the project.
Step 2:Edit Kodak video in Final Cut Pro
Apple's Final Cut Pro Software is an all in one video editing, compositing, and special effects package for the Macintosh. The following steps will show you how to use the Timeline:
One: Edit video and audio timing
There are three tracks on the Timeline, one for video and the other two for audio. And you can cut the video and audio tracks all at once in the same place.
Choose the razor blade tool in your menu, and click the times that you want to split it. You can also set input and output times on the Viewer window. Final Cut Pro also allows you to layer video tracks on top of each other.
Two: Add transitions
For Kodak videos, you might want to use simple and non-distracting transitions. Then you can just select Fade Out or Cross-Fade transitions.
Three: Export video
Once you are finished with editing your video, click on File and point to Export, then you will see a list of options of how you can export the edited file. For example, if you want to publish your video to the web, you can click on "Export using QuickTime Conversion". When you see the naming dialog box, input the name you prefer and at the bottom, select "MPEG-4" at the bottom, and then select "Broadband-High" under the format setting. And now click on Save.
on Sep 17, 2010 | Computers & Internet
Tip
Import flip video to Final Cut Pro and edit flip video Final Cut Pro Final Cut...
Final Cut Pro is a professional video editing application for Mac users and it is widely used even by many Hollywood people on professional movie post-production. If you are a flip video fan and you want to give professional editing to your flip videos, Final Cut Pro is a great choice. However, Final Cut Pro does not allow raw flip videos to be imported to Final Cut Pro and you will need to convert flip video to Final Cut Pro supported formats. Thus, to edit flip video in Final Cut Pro, you can follow the three parts below:
Part One: Convert flip to Final Cut Pro video
Download Doremisoft Mac Flip Converter and refer to the following steps to import flip video to Final Cut Pro.
Step 1: Add flip videos
Click the "Add File" button to add the flip videos you want to edit in Final Cut Pro to Mac Flip Converter.
Step 2: Select a Final Cut Pro supported output format
Click the Profile drop-up list and select
Step3: Convert flip video to Final Cut Pro
Click the "Start" button on the lower right of the interface to start converting flip video to Final Cut Pro.
Part Two: Import converted videos to Final Cut Pro
Step 1: Launch Final Cut Pro and you can see the layout of the Final Cut Pro Interface. From under the File command at the top of the interface, select "Import" and "Files". Thenselect one converted file from the Choose a File window and press the "Choose" button to choose this file.
Step 2: Find the file in the resources list for the project.
Step 3: Drag the file into the Timeline and then save the project.
Part Three: Edit flip video in Final Cut Pro
Final Cut Pro is a very professional tool with many functions. The following steps will show you how to use the Timeline:
Step1: Edit video and audio timing
Step2: Add transitions
For flip videos, you might want to use simple and non-distracting transitions. Then you can just select Fade Out or Cross-Fade transitions.
Step3: Export video
As mentioned above, Final Cut Pro is a very good tool for professionals. If you want to know better about using Final Cut Pro, you can go to certain Final Cut Pro forums. The most popular one is Los Angeles Final Cut Pro User Groupn and you can find a lot of useful info there.
You might also want to buy a book and study how to use Final Cut Pro, such as Apple Pro Training Series: Final Cut Pro 7 and learn how to professional edit your videos with Final Cut Pro.
If you just want to do some basic editing such as cropping, length trimming and video effect adjustments, you can just use Doremisoft Mac Flip Converter to get the job done by following How to edit flip video with Doremisoft Ma Flip Converter.
on Aug 13, 2010 | Computers & Internet
Voice out of sync on transfer to computer
hiya, your camcorder i presume must use MPG2 and audio with 48k. if u r using adobe premiere to store, then u have to choose the 48k audio format. if ur using any other thing to store, i would recommend final cut pro... pls correct me if i'm wrong.... happy troubleshooting
Feb 28, 2007 | Sony Handycam DCR-TRV480 Digital Camcorder
142 people viewed this question
old marine
old marine
