Question about Bushnell Trail Scout 11-9830 Digital Camera
Pictures won't record on SD card
I see the camera is taking images, and the screen reads a new number when an image is taken, but it won't go on the SD card. I tried to SD card in my computer, and the card will take files from there. Is there something in the set-up I have missed?
  • 3 Answers
Maybe you are saving pictures to your camera internal memory,if so try to change it in settings for SD card,or it could be that your camera does not accept the type of sd you are using,try any other card and see
Posted on Feb 27, 2009
I have a Nikon D5300. I can see the photo count number increasing, but I cannot view the images and they are not going on the SD card. Where are they? The SD card is not full.
many small Nikon cameras have memory to store images ON THE CAMERA. If you have a memory card installed that the CAMERA CAN READ it will put images on the card. if the memory card is corrupted the camera will not use it.
First Backup all IMAGES on Memory Card to COMPUTER make sure you saved ALL images. This is IMPORTANT.
After you SAVED all images you PUT Memory card back in camera and FORMAT it (Format is in TOOL Menu that looks like a wrench)
Now if you can take an images and it saves to memory card you are done. To see if they go to MEMORY CARD. Turn off camera and remove MEMORY CARD and Check.
If it STILL does not work you may have a defective memory card.
Feb 23, 2017 | Nikon Cameras
Won't take/record photos!
Are you sure it is set to save images to the card and not the camera's internal memory ?
Mar 28, 2017 | Konica Minolta DiMAGE F200 Digital Camera
D60 has SD card full message but the SD card is brand new and formatted.
Have you tried using it in another device that reads/writes SD cards?
It's possible it is a counterfeit SD card. Some counterfeit cards don't work or are not the true capacity. If it it a name brand like SanDisk it will have a serial number. The counterfeit ones typically don't have serial numbers.
Sep 02, 2012 | Nikon D60 Digital Camera
My DMC-TZ3 always stores images in haphazard order, not the exact order in which they were taken. Why? And how can I make it store images in chronological order please?
This is from the manual: "File numbers are reset when new folders are created." "New folders are created in the following cases: 1. When pictures are taken to folders containing files numbered 999. 2. When using cards already containing the same folder number (including pictures taken other cameras, etc.) 3. When recording after performing a 'NO. RESET' (found in the setup menu).
Sep 18, 2010 | Panasonic Lumix DMC-TZ3 Digital Camera
Just put a new memory card in the camera but the screen keeps showing internal memory is full
How to switch the camera over to saving pictures directly onto the SD card.
    1. Menu
    2. Cam settings
    3. Chose AUTO or SD card option and Press OK
Note: If the SD card isn't in the camera or is unreadable the camera will automatically go back to saving you taken pictures on the internal memory.
If you still experience problems:
The lever on your SD card might be turned the wrong way so the SD card is reading protective.
Please turn the lever and try again.
The SD card might not be supported by the model: Your camera Memory card support is SD/MMC up to 1 Gigabyte
The SD card might not be faulty, try another card, since the camera could give you a message like the one you're experiencing.
Try with a different SD card that is supported by the camera.
    After you having successfully switched over to saving onto the SD card. I would guess that you would like to transferre the pictures from your internal memory over to the SD card.:
Question :
How do I transfer pictures from the internal memory of my KODAK Digital Camera to a memory card? Answer :
Follow these steps:
  • On the camera, press Review and then Menu.
  • Select Image Storage.
  • Change to Internal Memory.
  • In the menu listing, scroll down to Copy, and select OK.
  • Select a single picture, or select All.
  • When you have finished copying pictures, reset the Image Storage location to your original setting.
  • Jan 16, 2010 | Kodak EasyShare C643 Digital Camera
    I have a D5000 Nikon and a Panasonic SD/HC 4GB card. I have formatted the card and taken a number of pictures. I have loaded the necessary soft ware supplied with new camera but cannot download any...
    If you are using a card reader of some sort (other than using the camera to download the images), it may not be SDHC compliant. Have you tried using the camera to download the images via the supplied cable? If you've taken the images in RAW format, that could also be the problem. Try using a 2gb or smaller card in the camera to take some images and then download them using your usual method. If it works with the 2gb card but not with the 4gb, it's likely your reader isn't SDHC compliant.
    Sep 27, 2009 | Nikon COOLPIX L3 Digital Camera
    Reads CARD FULL, can't view the pics, reads NO IMAGE
    Sounds like the card has died. unfortunatly this can happen. and could be caused by a number of things including static.
    you can maybe try a disk repair in windows.
    hit your windows key and press r at the same time. in the command line type CMD and hit enter, it will open up a DOS window. type CHKDSK ?: /f where teh question mark is, is the drive letter that windows has assigned the card when you insert it. if it is an error that is repairible this might work.
    Sep 23, 2009 | Olympus SP-560 UZ Digital Camera
    Fe170
    You can add memory to your camera by purchasing an xd memory card.
    Compatible cards
    xD-Picture Card (16MB – 1GB)
    There are two ways to record the pictures you take with this camera.
    Recording pictures to the internal memory
    • Pictures are recorded to the internal memory, and when the number of storable still
    pictures reaches 0, you must connect the camera to a computer to download the
    pictures, and then erase the pictures from the internal memory.
    Using an xD-Picture Card (optional)
    • Pictures are recorded to the card when inserted in the camera. When the card is
    full, you download the pictures to a computer, and then either erase the pictures
    from the card or use a new card.
    • Pictures are not recorded to the internal memory when a card is inserted in the
    camera. Pictures in the internal memory can be copied to the card using the
    [BACKUP] function.
    g“BACKUP Copying pictures in the internal memory to the card” (P.25)
    “The card” (P.60)
    Number of storable still pictures and recording length of movies
    Still pictures
    Movie
    • If you use a non-Olympus card or a card used for another application, such as for
    a computer, the message [CARD ERROR] is displayed. To use this card with this
    camera, use the [FORMAT] function to format the card.
    g“MEMORY FORMAT (FORMAT) Formatting the internal memory/card” (P.24)
    Additional shooting tips and information
    Increasing the number of pictures that can be taken
    IMAGE QUALITY Image size
    Internal memory Card (128 MB)
    SHQ 2816 × 2112 2 25
    HQ 2816 × 2112 6 76
    SQ1 2048 × 1536 8 108
    SQ2 640 × 480 60 726
    Remaining recording time
    HQ 320 × 240 (15 frames/sec.) 32 sec. 6 min. 37 sec.
    SQ 160 × 120 (15 frames/sec.) 2 min. 8 sec. 26 min. 28 sec.
    Dec 15, 2007 | Olympus FE-170 Digital Camera
    Storage path
    On removable memory cards. Panasonic iPalm Digital Cameras are equipped with an SD Card Slot which allows the camera to store images on EITHER an MultiMediaCard (MMC) or an SD Memory Card. Simply insert an MMC or SD Card into the camera, take pictures until the card is full, then remove it or replace it with a fresh card. You can selectively erase any or all of the images from the either the MultiMediaCard or the SD Memory Card and reuse it. Storage capacity for the PV-DC3000-A (based on included 16MB SD Memory Card) SuperFine Mode* (2048x1536/low compression) up to 13 images Fine Mode (2048x1536) up to 27 images Normal/2x Digital Zoom Modes (1024x768) up to 69 images Burst Recording Mode (1024x768) up to 82 images 3x Digital Zoom Mode (640x480) up to 150 images Motion Image Recording Mode (12 sec. max./320x240) 9 sets TIFF Mode (2048x1536/no compression) 1 image Storage capacity for the PV-DC3010 (based on included 32MB SD Memory Card) SuperFine Mode* (2048x1536/low compression) up to 29 images Fine Mode (2048x1536) up to 57 images Normal/2x Digital Zoom Modes (1024x768) up to 145 images Burst Recording Mode (1024x768) up to 172 images 3x Digital Zoom Mode (640x480) up to 315 images Motion Image Recording Mode (12 sec. max./320x240) 19 sets TIFF Mode (2048x1536/no compression) 3 images
    Aug 31, 2005 | Panasonic iPalm PV-DC3010 Digital Camera
    Storage path
    Aug 31, 2005 | Panasonic iPalm PV-DC3000 Digital Camera
    Bushnell Trail Scout 11-9830 Digital Camera Logo
    753 people viewed this question
    Top Bushnell Cameras Experts
    Johnny Massengill
    Johnny Massengill
    Are you a Bushnell Camera Expert? Answer questions, earn points and help others
