Question about Baxter Ovens
Oven with an attitude
We have a Baxter OV-210 that was made in 93'. What it's doing is when you open the oven door to remove the oven rack, if you do not let the rack carrage come all the way down to the home position before you close the door again it will continue to drive down past the lift motor stop switch. If you let it come all the way down before you close the door again it works fine. Our other OV-210's change direction as soon as you close the door and begin to lift again until they hit the rack lift stop switch. This oven has new relays a new lift motor, all new swiches for the door and rack lift and drop stops. All wire check out for our wiring diagram for that oven. Our Maintenance crew has many years of experience with these oven, but can not figure this one out. Please help.
  • This doesn't sound like a worn out motor brake, as described below, or rather some sort of electrical issue. Usually when I come across an issue like this I will try swapping control boards with adjacent ovens to see if the problem "follows" the board or if it stays with the oven. Doing this will either identify the problem as being a malfunction in the board, or it will rule it out.
Check the lineator actuator motor. If you remove the top cover there should be a strip of metal stuck on the cover to put pressure on the gear to keep it from free wheeling down. These is a tiny button/nipple that sits in the hole in the top of the gear shaft. Lose it and you're sunk. Work with good light and watch the grease. Good luck
Posted on Apr 20, 2009
I have a baxter oven single rack ant the burner dont allways come on
More than likely the element is going bad. Get your hands on a continuity meter, pull the element and touch the red wire to one end of the element; the black wire to the other. Move the element around a bit (bend it slightly). if the needle on the meter registers nothing or flips up and down on the register, you've got a dying element. If it were me, I'd go ahead and simply order a new element. They're not hard to remove or install (they either slip in, male to female, or involve the removal of several small screws. Obviously, make certain your oven is OFF when you repair it.
Jul 14, 2017 | Baxter Ovens
How do I fix the flame sensor in a baxter oven?
Take off the right side panel and open the control panel door. Take a long screw driver and stick it in the hole where the flame sensor wire goes and remove the screw holding the flame sensor in place. Clean the metal rod on the flame sensor with a piece of fine grit sandpaper or emory cloth. Put flame sensor back in, make sure no insulation is touching the exposed metal part of the wire connector.
Feb 24, 2012 | Baxter OV300E Stainless Steel Electric...
I will need to get a Baxter OV300EDD oven through a 35" wide door frame. Considering the oven is 37.49" deep, could I remove the doors off the front of the unit so that it will fit through the...
You can remove the oven doors, hinges, control panel door, and top oven trim, if needed. That will definitely reduce the width enough to squeeze it in.
Aug 17, 2011 | Baxter OV300E Stainless Steel Electric...
I have a Baxter oven OV210G, When the door is open the rack will not stop or lower. The micro switches all work and relays seem to work but I can't find the MR3 cantactor and don't if that is the problem...
When you open the door check to see if your burner and circulation fan remain on, if they do you have an issue with your door switch.
Also if your rotation micro-switch was bad you would get a buzzer every 1 second because the oven would think the carrier isn't rotating.
It's hard to troubleshoot beyond that without seeing the oven, its possible you could have a bad relay on your control board. In this case I would call an authorized service provider to have to check the oven out.
Dec 07, 2010 | Baxter BXA2G Stainless Steel Gas Single...
The rack inside has stopped rotating
On top of the oven is a cover with 6 screws in it, loosen the screws and remove the cover. You will see two pulleys, most likely one of the pulleys are loose, try tightening the set screws, the one on the right can be tricky because the set screw is under the pulley. Good luck!
Dec 04, 2010 | Baxter OV300E Stainless Steel Electric...
Rack does not stop at the right positin
This could potentially be a very easy solution. First you need to verify if when you open the door does the carrier stop immediately regardless of where it is in its rotation or does it continue to a certain point every time and stop in the same place?
If it stops in the same place you need to adjust the alignment bar on top of the shaft. On top of the oven remove the metal shields covering the rotation and lift assembly. You will see a steel ring with two small bars coming out of it attached to the top of the shaft, these bars strike the rack alignment switch when the come around. Have someone on the ground center the rack carrier. Loose the metal ring set screw and turn it until it is sticking the switch, you'll hear it click. Tighten it a little bit and have them start the oven and open the door to see if it stops straight. Continue making adjustments until it is stopping straight.
If when you open the door the rotation stops immediately regardless of which way the carrier is pointing then you have an issue with your rack alignment or pointer switch. Usually in this case the switch needs to be replaced, but sometimes its just a matter of a wire fell off the switch. Before you try to replace any wires make sure the power to the oven is off.
Jun 05, 2010 | Baxter BXA2G Stainless Steel Gas Single...
I have a baxter mini rack electric oven and water started leaking out of the right side of the oven while cooking bagels. any ideas on what is causing this
Sounds like you have a water leak! The right side panel needs to come off. Here you will see your copper water lines. Try steaming while watching to see where the water is coming from, most likely its coming from the two spray nozzles that enter the oven near the top in the front and rear. If the leak isn't obvious have an authorized technician service the oven. A leak in this part of the oven left unattended could cause more damage and potentially a fire.
Feb 03, 2009 | Baxter OV300E Stainless Steel Electric...
Kenmore oven 41775790 locked door
after self cleaning with the racks still in oven, i cannot get the oven door open, locked down, does this have something to do with the racks left in oven during cleaning. what do i need to do
Jan 17, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Ovens Logo
228 people viewed this question
Top Baxter Ovens Experts
Owen Barnes
ray gallant
Are you a Baxter Oven Expert? Answer questions, earn points and help others
