Question about Numark BATTLE PAK v.4 Turntable
Numark tt1625 speed issue
My tt1625 after a hour of playing them , when i touch the record slightly the platter almost stops and then takes ages to return to speed . they are a year old and i have only had them for 3 days. please if you could help it would be much appreciated .
thanks
nikky
  • nickybloggs Feb 27, 2009
    thanks for the reply
    i mean it almost stop when i touch the record its acting like i pressed the stop button then slowly picks back up again it takes around 6 long seconds , im wondering if the motor is broken .
    they are a year old and i have only had them 3 days
    plz help
    New Friend:
  • 27 Answers
Hi nikki,
when you say ages to get back to speed how long is that exactly? even on my technics for cueing i give a slight throw to hit my cue points.
also your slip mat may be an issue. do not use the rubber mats use the soft nylon foam one that came with it only.
Posted on Feb 27, 2009
  • marnoel calizo
    marnoel calizo Feb 27, 2009
    so this happens only on one?
  • marnoel calizo
    honestly its sounds like a bad motor.
Numark x2 motor problem
I would like to know if it possible to use my Numark DXM09 mixer ... with two Numark ICDX players and use Numark Cue software
Oct 14, 2009 | Numark x2 Hybrid Turntable
Numark tt1625 turntable wavey sound
Your belt is probably worn and needs replacing. Lift felt on platter and and lift the platter section off the unit by putting your thumb and forefinger through the two large holes and pull upwards.There should not be any special routing for the belt and should go directly onto the spindle motor to your platter. Place the belt around the inside rim of the platter while it is still off the unit. Now replace the platter and move the platter around until you see the spindle motor through one of the holes. Use some tweezers to manouvre the belt onto the spindle motor. On some units you will have to lay the belt out inside the unit, replace the platter and manouvre the belt onto the platter. Hope this helps
May 28, 2009 | Numark BATTLE PAK v.4 Turntable
Numark tt500 does not turn
looks like u have a problem with ur motor....if u have a belt drive check the belt and replace it....lift turntable off and start the player u will be able whats going on...and go from there
Mar 14, 2009 | Numark TT500 Turntable
How do I remove the Numark TTX platter
Nope, nothing to it. The platter is just held down by gravity. Take a mallet or a piece of 2x4 block, and give the spindle a little whack. Not too hard, just enough to break the hold.
- OPTiC
Numark Repair Videos
Numark DJ Repair
DJ Equipment Sales
Numark Parts
Jan 04, 2009 | Numark TTX1 Turntable
When i turn my turntable on,they is a slight dip and rise in the platter is this normal.if not what should i do to mend it.
Is the platter itself moving up and down or the record? It could just be the record's wear and tear (warped) which raises the tone-arm which in turn makes it move up and down on certain sections of the record. Try bending the record (very very slightly) to straighten it out or put more weight on the tonearm.
Sep 11, 2008 | Numark BATTLE PAK v.4 Turntable
Numark tt1625 keeps on jumping
If your weight and such are correctly set, then the only other issue might be a worn stylus, or your tonearm might be damaged.
- Davis
We are the Turntable Experts!
DIGITAL ANALOG THERAPY
Aug 08, 2008 | Numark Audio Players & Recorders
Numark cdx
have you checked the brake and start up settings they are the dials by the start and stop buttons it it is turned too far the platter will start up slow, you just trun to dial till you get the right start up speed you want
Jul 25, 2008 | Nu Mark Numark Cdx Table Top CD Player CD...
Numark tt1625
These are direct drive turntables, so if your having speed issues, the problem is probably one of the drive circuits. Unfortunately, not an easy fix. So I suggest taking it to a service center for repair.
- Davis
DJ Pro Audio
www.djproaudio.com
www.repairnyc.com
www.1200s.com
Jul 15, 2008 | Numark BATTLE PAK v.4 Turntable
My numark tt1625 turntables keep slowing down
If you could be a little more specific, we might be able to help you out better.
Does it slow down, when you do anything, or after a long period of time of being on/used? Or as soon as you turn it on, it slows down?
Any specific information would be greatly appreciated.
- Davis
DJ Pro Audio
www.djproaudio.com
Jul 14, 2008 | Numark BATTLE PAK v.4 Turntable
Numark BATTLE PAK v.4 Turntable Logo
456 people viewed this question
Top Numark Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Are you a Numark Audio Player and Recorder Expert? Answer questions, earn points and help others
