Question about Samsung TXN3245FP 32" TV
No power on Samsung model TXN3245FPX/XAA
I have owned this TV for abouth three years. One morning I watched it then shut it off. Two hours later it would not power up. The small red light that is always lit on the front was also out. Any ideas?
  • 2 more comments
  • Anonymous Dec 01, 2007
    I HAD THE SAME THING HAPPEN TO MY SET - ITS A 03 SAMSUNG
    3245FP - WAS WATCHING AND IT WENT OFF AND WOULD NOT COME
    BACK ON - WHEN I TURN IT ON THE ONLY THING IT DOSE IS MAKE
    A CLICKING SOUND AND NOTHING HAPPENS
  • comperson Dec 22, 2007
    I was going to play a game and the power went on for a sec before it went off. I tried power and that was fine. Need help
  • Quigley125 Mar 28, 2008
    Note I have the same problem with my TV. Would like to check and see if the fuse is blown as indicated. However, I need specific point by point instructions on how to take the back off the TV and where to look for the fuse. Can someone help?
    Thanks.
  • bwagstaff Jul 12, 2008
    Anyone know how I would even check the fuse? Model is Samsung TXN3298HF. I REALLY appreciate it!
  • 35 Answers
I've had the same problem multiple times on my set... it always been a blown fuse.
Posted on Dec 13, 2007
    Genius:
  • 1,074 Answers
Your tv has a problem in the power supply check the 10mf 200 volts cap that is located in the power supply near the regulator.it is open change it and you are on.good luck
Posted on Aug 04, 2007
It was a blown line fuse.
Posted on Oct 10, 2007
SOURCE:
TV lamp has been replaced, still won't come on, no picture. When turned on, I can see a blue, kind of sparking light and noise starts and does this about three times. TV powers down and does this again....
Samsung DLP TV Repair - No Picture - Replacing ...
? 2:41
https://www.youtube.com/watch?v=pBTgk_C5FVU
Jun 11, 2012 - Uploaded by ShopJimmy.com
DLP TV Repair No Picture Bad Lamp Bad Bulb TV Won't Turn On DIY Samsung DLP TV Repair How to replace Faulty LampTutorial Click Here to ... Rating is available when the video has been rented. ... is a replacement for the following DLP Rear Projection TV models: ... SAMSUNG HLR6167WX/XAA
Samsung DLP problems - Help! - ecoustics.com
www.ecoustics.com > ... > Home Video Forum > Projection TV Forum
Oct 26, 2009 - I have attached a picture of to show where the "Light Tunnel" is located. Upload ... So now I have a Samsung HLN5065W/XAA that I am willing to part out or sell as is. ... I replaced the ballast but the TV still won't turn on. .... The lamp has been sitting on a shelf until two weeks ago, when the TV went dark. Samsung DLP Light Ballast
Apr 10, 2009
Archive through October 26, 2009 - Samsung DLP problems ...
Apr 8, 2009
Samsung DLP Flashing Standby light
Jul 1, 2006
More results from www.ecoustics.com
Jan 19, 2016 | Samsung SELECT HLR6167WX/XAA Rear...
Samsung HLS5086WX/XAA made popping noise and shut off, then made whirring noise.
When my TV did this in the past it ended up being the color wheel. I had someone replace it and it worked fine. I asked it if had to be calibrated after it is installed and he said no. Also make sure the door switch is pushed down when you install the back bulb door. Sometimes this switch can go bad as well.
Jan 10, 2013 | Samsung HLS5086WX/XAA
Samsung hls5086wx/xaa turns off at random
Go to website Encompass Electronics.com type in your model number it will list part and part number ,you can also look for Lamp on E-Bay Encompass 1-800-638-3328 Also ck Color Wheel remove lamp take a flash light to watch when you turn TV on see if the color wheel is turning if it is defective set will shut OFF. But most likely its your Lamp.
Oct 05, 2009 | Televison & Video
Samsung HPT4254X/XAA plasma turns off and on by itself, clicking.
had the same problem, same tv... bad connection on a transistor....
Jan 07, 2009 | Samsung HP-R4262 42 in. Plasma Television
Samsung HL-r5667w TV shuts down on its own.
You may have a colorwheel going bad. The bearings start going out and this is an indication of the failure. The colorwheel is located in the light engin e therefore you may want to get a qualified tech to look at it
Dec 16, 2008 | Samsung HL-R5667W 56" HDTV
Tv shuts itself off
Look for the computer processor inside the TV. It needs to be cleaned. A can of compressed air will work. The processor is overheating and causing the tv to shut off. Look for the small fan that is supposed to keep the processor cool then remove the dust.
Oct 22, 2008 | Samsung DLP HL-P4663W 46" Rear Projection...
We have a Samsung HLP5674WX/XAA which seems to have a mind of it's own. It will automatically shut off or when we turn it own, there will be no picture with sound or once it turns on, the TV will shut...
I have a Samsung HLP5474WX/XAA. The ballast was replace 2 months ago. I just installed the lamp, i notice green flashing occur on the LAMP when i turn it on. The tv takes 10 to 15 second to turn on the picture, the sound as soon as i power up i can hear it. Any advice??
Mar 18, 2008 | Televison & Video
Samsung TXN3245FP 32" TV Logo
286 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
