Question about Singer 3116 Simple
Singer simple 3116 will not reverse
My singer simple 3116 was reversing just fine until i went to sew yesterday. I pushed the lever down and it made a click noise, a noise i have never heard it make, and now it won't reverse. anyone have an idea as to why it's not working anymore?
    Genius:
  • 1,788 Answers
Sounds like spring or something disconnected from the lever. Take it in to your dealer or look at yourself carefully.
Posted on Aug 15, 2010
My sewing machine will only sew in reverse
The stitch length lever on some machines will back stitch when the lever is in the uppermost position. Bring the lever down to an appropriate stitch length and your machine should stitch forward.
Oct 11, 2014 | Singer 3116 Simple
Sewing in reverse
Take it to a repair shop for assessment, you will not get into it...got a warantee ??
Nov 20, 2011 | Singer 3116 Simple
My reverse stitch control is worn and does not work. How can I get a replacement?
After seeing this, I went onto sewingpartsonline.com and was able to order a new reverse lever for $7.95. Considerably cheaper than taking it in for repair.
Nov 15, 2010 | Singer 3116 Simple
Is there a reverse stitch button on singer 457
On the right is a lever .. Bottom has numbers .. Mid says "fine" .. Move that lever up to the top for reverse
May 08, 2010 | Singer 3116 Simple
Reverse Lever isn't working...
Most likely the "dogs" inside the lever are broken off. Oil/grease on the metal rod cause chemical attack to the plastic lever and the "dogs" break. Singer should know to degrease this rod before assembly.
Oct 10, 2009 | Singer 3116 Simple
Reverse Lever broke off
First of all, make sure that the machine is in straight stitch forward position. If it is and you are still having a problem, take the top of the machine off and blow hot air from a hair dryer down towards the reverse mechanism. That will unfreeze it.
Jul 19, 2009 | Singer 3116 Simple
How to reverse
Push down on the lever arm on the front of the machine.
Jul 13, 2009 | Singer 3116 Simple
Singer 3116 won't go into reverse
here is a download for your manual
http://safemanuals.com/user-guide-instructions-owner-manual/SINGER/3116-_M
pg 32 talks about sewing in reverse sewing.
but doesn't give much on trouble shooting other than hold the lever while sewing. If that's not the case, then I think your feed dogs are the issue. check your feed dog drop. pg 9 part 12
If you think the reverse lever is sloppy, professional action should be taken, (take it in to be repaired under warranty?)
I hope this was helpful.
Jan 11, 2009 | Singer 3116 Simple
3116 just goes in reverse
It is possible the reverse lever is stuck in the wrong position Move it back to the forward position and see if it will work. Failing that, it's possible the machine is in buttonhole mode. Put it back to normal mode. If it still won't work, you probably have a seized mechanism which will require a technician to repair. If the machine is new enough to be under warranty return it to the store you bought it from for replacement or send it to the Singer warranty center listed on the paperwork that came with your machine.
sewman7
Jun 28, 2008 | Singer 3116 Simple
Singer 3116 Simple Logo
234 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
