Question about Apple iPhone Smartphone
Iphone 3G, #3 connecter
Using your step by step text and photos I had no problem taking  my nieces 3G Iphone apart. First problem  when I returned after a few days for the dried out period. I noticed someone had tampered with the LCD screen There were which looked like darker  moisture blotches  I wanted to see how much damage was done to check  the logic,etc, I assembled every thing to it's original state...except the  ribbon #3, I don't remember how it was when I seperated  display from the main... I tried many times but failed ,also your step on this.  says  a white tab, which isn't there  but a blk half moon shaped cover,,     Now is there any where on the web to  get a close up view and text to connect #3?       OK here's a long shot question and properly a impractical one at that..Before my niece has to go to replacing this LCD screen is there any way of repairing this myself,can it be take apart without destroying it?   NickyD
  • 4nicks1 Feb 28, 2009
     Sorry, I get the two sites mixed up,  I used Ifixit's step by step. But doesn't give me a close uo of what the connecting  tabs of both ends look like and how it connects and yes I'm aware of Apples no coverage of watered  damaged iphones..And the many online stores of replacement parts. Just like a new car. I still need a key to start it.
         Again, I repeat, before buying a LCD replacement, I want to connect the damaged lcd to make sure that it's just the screen that's damaged...If it's also the logic board then my niece is better off by purchasing a new Iphone, Agree?  So I'm hoping someone out there will show me a close up,description on how to connect #3...nickyd
  • 4nicks1 Mar 03, 2009
      In reply to this photo;
     This photo would be of big help, but as you see the resolution is set too high, therefor distorting the image..
      if this ribbon wasn't already out,maybe the white tab didn't lock or the ribbon wasn't inserted deep enough. I would of had a better up front view of  what it should look like. Now I have every thing back to it's original state except, trying to  insert 3 is like trying to stick a wet noodle into a ****'s mouth.4nicks1
  • Apple Master
  • 13,433 Answers
It is best to replace the lcd screen if it has got wet or damaged. Could you give me a link to where you have been following the instructions?
Posted on Feb 27, 2009
How do you retrieve deleted text messages on iphone 4
Well, iPhone Data Recovery may help you solve your problem. You know, it is good at recovering iPhone data such as sms, contacts and more. You can follow the steps here in the following:
Step 1: Launch the program and scan to recoverStep 2: recover deleted SMS from iTunes backup files
Step 3: Start to recover iPhone text messages
For more details, read this guide:
Retrieve Deleted Text Messages on iPhone
Apr 12, 2013 | Apple iPhone 4 Black Smartphone
Tip
How to Transfer Photos from iPhone to iPhone 6
For the people who just upgraded from a relatively old iPhone to the new iPhone 6, they may like to transfer some of the wonderful photos from the old device to the new one. Every iPhone user knows that we can transfer photos from iPhone to iPhone via Photo Stream. However, it requires two device are log into the same Apple ID and iCloud account, and it only sync when the 3G/4G/Wi-fi network is available. What if the network is not stable and you want to selectively transfer photos from iPhone to iPhone 6? So, in this tip, I will talk about how to transfer pictures from iPhone to iPhone 6 via Photo Stream and an iPhone content manager - AnyTrans.
How to Transfer Photos from iPhone to iPhone 6 via Photo Stream
Step 1. Go to Settings from your iPhone > Scroll down to Photos & Camera >Toggle "My Photo Stream" to ON position.
Step 2. Do the same with your iPad. Make sure the same iCloud account is connected to both devices by going to Settings > iCloud.
How to Transfer Photos from iPhone to iPhone 6 via AnyTrans
Step 1. Open up AnyTrans, and connect both your iPhone 6 and iPad to computer. Enter the manage page of your iPhone.
Step 2. Select "Photos" > Choose photos you want to transfer from Camera Roll/Photo Stream/Photos Library/Photo Share/Album/Panoramas.
Step 3. Choose the photos you want to transfer, and click the To Device button to transfer pictures from iPhone to iPad.
Resource from
How to Transfer Photos from iPhone to iPhone 6 Plus Directly
on Dec 23, 2014 | Apple iPhone 6
Tip
I used  the 3G guide from, ifixit.com. it list each of the components, from...
Got this great instructions from - www.rapidrepair.com.
Tools required:
Small Phillips Screw Driver
Small Flathead or exacto razor
Safe Open Tool
Remove the sim tray, use the included sim card removal tool (or a paper clip if you've lost the tool.)
Holding your device on end you will notice two small screws on either side of the dock. These screws must be removed in order to open the case.
Insert a small thin tool between the chrome ring and front panel glass directly above one of the screw holes. You will need to exert a small amount of pressure to separate the display from the back panel.
Lift the panel up from the dock end being careful not to tear or break any ribbons connected near the other end.
Unplug ribbons 1 and 2 by lifting them from the main board. Under ribbon 2 you will need to find and unclip ribbon 3, then carefully remove the display assembly.
Remove the seven screws circled in red. Note: One screw is located under the DO NOT REMOVE sticker.
Unplug ribbon 4.
Lift the mother board out taking note of the camera which is still connected to the underside of the board. You will need to unplug the ribbon circled in red.
Place the mother board to the side.
Use the attached tab to pull up on the battery, there is a mild adhesive on the back side, so it will take a bit of force.
Remove the screw circled in red.
Carefully remove the camera.
Remove the nine screws circled in red.
Remove the headphone jack and attached flex cable.
Remove the speaker assembly which also contains the dock connector, antennae and home button as well.
Remove the 2 screws circled in red.
Place the ******** assembly to the side.
Remove the 2 screws circled in red. You will find 3 screws on the opposite side which must be removed as well.
Lift the LCD free from the front panel glass.
Pictured is every component inside the iPhone 3G.
You did it!
on Feb 25, 2009 | Apple iPhone 3G
How do i unlock my iphone using itunes
You can unlock an iPhone 3G through remote unlocking method. This method of unlocking is safe simple and affordable. You can get the remote unlocking for an iPhone 3G from www.Classicunlocking.com . Here are the steps for unlocking an iPhone 3G,
1. Wait for to send you an email saying your phone has been activated or remotely unlocked.
2. Install the latest version of iTunes.
3. Make sure your Apple iPhone 3G phone software is updated to the latest version using the iTunes software.
4. Connect your Apple iPhone 3G to iTunes with a NOT ACCEPTED SIM card.
5. Wait until iTunes detects your Apple iPhone 3G.
6. Disconnect your Apple iPhone 3G and reconnect it after 10 seconds.
7. Your Apple iPhone 3G is now unlocked.
Jul 01, 2012 | Apple iPhone 3G
Unlock iphone3g using itunes
Jul 01, 2012 | Computers & Internet
No problem. i just want an basic instruction manual for my iphone 3g,
Basic Information- You can call, join up many people while on the phone app, iPod plays music, videos, and displays photos. You could jailbreak it, like run 3rd party apps like snes4iphone and so on. Use spirit to do it. Back to basics. You can download photos from the web using Safari app, Check E-Mail, SMS Text, Camera to take photos, calender for dates, time, plans. Notes for taking notes. Clock for time zones, weather to check weather, calculator to add, subtract, multiply, iTunes to download music without computer, App Store to download apps directly without computer, Stocks for economy, and so on...
Jul 13, 2010 | Apple iPhone 3G
How to recover accidentally deleted sms for iphone
I'd recommend that you try this iPhone data recovery software that helped me before
http://www.001-software.com/iphone-data-recovery.html
hope this helps.
Jun 24, 2010 | Apple iPhone 3G
Iphone 3G screen not working after dropping. Not
It sounds like you have some internal screen damage, your LCD may be damaged or your digitizer. A professional will need to take your phone apart and determine the cause.
Dec 31, 2009 | Apple iPhone 3G
Got unlocked iphone, tried to restore factory settings now its stuck on bitten pineapple...any help plz just got this phone?
Here u can follow the steps
Step 1: Make sure you have downloaded the latest version of iTunes if you haven’t already. Download iTunes 8.2 from the link given below.
Step 2: Now connect your iPhone with your PC. You must connect it to a single usb port on the backside of your computer. Do not use any usb hub or the ports in the front as this could cause an error during update process.
Step 3: Start iTunes 8.2. Sync your iPhone with your PC so that iTunes backs-up all your important data including settings, apps, music, contacts and photos.
Step 4: You will now have to download a custom cooked firmware for your iPhone version (2G or 3G). I can’t post the download links for these files for the reasons you all know very well. Just Google “iPhone 2G Custom 3.0” (If you are using iPhone 2G) or “iPhone 3G Custom 3.0” (If you are using iPhone 3G) and use one of the torrent links to download the custom created .ipsw file.
Step 5: Once you have downloaded the required .ipsw file, Copy/Paste it into this location:
“C:\Users\[username]\AppData\Roaming\Apple Computer\iTunes\iPhone Software Updates\” (Windows 7)
“C:\Users\[username]\AppData\Roaming\Apple Computer\iTunes\iPhone Software Updates\” (Windows Vista)
“C:\Documents and Settings\[username]\Application Data\Apple Computer\iTunes\iPhone Software Update\” (Windows XP)
Step 6: Restart iTunes. You will now be prompted to install this firmware you just download. Just close this prompt dialog by clicking on “x” from the top right-most corner of the window.
Step 7: Now you will have to restore your iPhone to this custom firmware 3.0 that you just downloaded. Click on your phone from the sidebar in iTunes to get to this screen as shown in the screenshot below:
Now press and hold left “Shift” button on the keyboard and then click on “Restore” (Not “Update) button in the iTunes and then release the “Shift” button.
This will make iTunes prompt you to select the location for your downloaded custom firmware 3.0. Select the downloaded .ipsw file and click on “Open”.
Step 8: Now sit back and enjoy as iTunes does the rest for you. This will involve a series of automated steps some of which are highlighted below:
Don’t do anything silly at this point. Just wait while iTunes installs the new firmware 3.0 on your iPhone. Your iPhone screen at this point will be showing a progress bar indicating installation progress. After the installation is done, iPhone will restart automatically and you should now have a fully unlocked and jailbroken iPhone 2G. iPhone 3G on the hand will only be jailbroken, not unlocked. iPhone 3G users will have to wait for Dev-Team to release ultrasn0w on Cydia in order to unlock their phones.
Step 9: Once you are done with the unlocking and jailbreak process. You can now restore all your settings, apps, music, contacts and photos to the newly installed firmware version 3.0 by restoring the backup that you made in Step 3 from iTunes.
Feel free to ask me any question here should you run into any problem during the update process.
Disclaimer: This guide is for testing & educational purposes only. I’m not responsible for any loss of important data or malfunctioning of your iPhone.
Download Links:
Download iTunes 8.2
Download iPhone OS 3.0 Custom Firmware (iPhone 2G) [Screenshot]
Download iPhone OS 3.0 Custom Firmware (iPhone 3G) [Screenshot]
/**/ Thanks
Thiru
Jun 20, 2009 | Apple iPhone Smartphone
IPhone 3G Error 0xE8000001
I just had this problem and it turned out to be... It didn't like my iPod cable. Switched to the iPhone cable and it worked.
Seems to be an iPhone 2.0 prob, or 3g prob, since I was using the iPod cable to sync my old iPhone just fine.
Jul 13, 2008 | Apple iPhone 3G
Apple iPhone Smartphone Logo
Top Apple Cell Phones Experts
David
Martin Murray
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
